Electrolux EWT 1015 Washing Machine - E20 Error Despite Replacing Pump & Checking Drain
pecil 113881 15
Why does my Electrolux EWT 1015 keep showing E20 after replacing the drain pump and checking the drain hose, and what else should I inspect?
The E20 error can still be caused by a blockage in the water path from the drum to the pump/filter, even if the pump itself was replaced; in this case the real fault was a sock stuck in the hose between the drum and the mesh filter chamber [#4367765][#4369899] Check the hose connecting the washing tub to the filter chamber carefully, because something can sit there and block the flow from the drum [#4367103] Also inspect the entire drainage route from the tank to the end of the drain hose for patency, since the machine remembers the error but it clears once the cause is removed [#4369566]
  • #1 4366981
    pecil
    Rate: 24
    Hello everyone
    I am the owner of a washing machine as in the subject, it served almost 3 years without any problems. Until last Sunday, She made a stop during washing and the display shows error E20 ... In the operating manual it is described as a failure of the sewage pump or a blocked sewage system.
    I bought the right pump, disassembled the casings (note there are very sharp edges), I miraculously discovered the tiny pump hooks on the bottom of the washing machine, replaced the pump, checked and rinsed the sewage drain, checked the sewage system, assembled the washing machine ... the drain hose is at a good height and it is not broken
    I started and waited, and here the same error E20 crashes during the next draining of the water - now I do not know what to do (except for the phone to the authorized service).
    Please help :cry:
  • #2 4367032
    mrhari
    Help: 835
    Rate: 3239
    This washing machine has a jet system and therefore has two pumps. Are you sure you replaced what you need?
  • #3 4367103
    mirr.
    Help: 9
    Rate: 52
    Check the hose connecting the washing unit with the filter chamber (unscrew it and check it carefully)
  • #4 4367128
    nares
    Home appliances specialist
    Help: 1515
    Rate: 3386
    And maybe write if it drains water now and is it quite intense?
  • #5 4367137
    pecil
    Rate: 24
    Answers:
    1- I replaced the pump between the mesh filter (the one that is available to the average user under the flap) and the discharge hose. Where is the other pump?
    2- Hose between the washing chamber and the pump - do you think that something is sitting there and is blocking the flow of water from the drum? I'll check of course.
    3- It drains the water quite intensively - unfortunately, when it was new and operational, it did not occur to me to observe the stream of water discharged into the sewage
  • #6 4367755
    mrhari
    Help: 835
    Rate: 3239
    Sorry, yesterday I was sure it has two pumps.
    Today I checked and it turns out that I was wrong. :cry:
    mirr.
    Help: 9
    Rate: 52
    [i] 2- The hose between the washing chamber and the pump - do you think that something is sitting there and is blocking the flow of water from the drum?
    Yes
  • #8 4368198
    pecil
    Rate: 24
    Yes
    That is, analyzing the operation of the pump - which is 100% not a self-priming pump and should be flooded by gravity. This pump dries (pumps out any water that may have leaked) and then runs in dry running, which can generate an E20 alarm.
    When I get home, I'll check it out.
    I have another question: Does this model of washing machine have a water quantity sensor? What is the stop of the wastewater pump controlled from?
  • #9 4368957
    axxx
    Help: 376
    Rate: 1720
    Each washing machine has a water quantity sensor called a hydrostat.
  • #10 4369423
  • #11 4369482
    pecil
    Rate: 24
    skryn wrote:
    Without giving PNC (nameplate), we can only ask ...
    The washing machine has an LCD or LED display?
    I am asking for the data from the data plate
    type 98P22599
    PROD N 91320274102
    SERIES NO.44700220
    and the display is red LED
    if you know something, please help
  • #12 4369566
  • #13 4369899
    pecil
    Rate: 24
    welcome back
    20-minute operation of checking the hose between the drum and the mesh filter and it is ......- my 15-month-old son's sock.
    I showed it to my wife and she says she thought one sock is missing, only one?
    I think the problem has been fixed. Quick water tests: fill, drain water and it's OK
    My costs: - injured hand - sharp edges of the inner plates of the washing machine
    -purchase a pump, actually a motor with an impeller (replacement) 33PLN
    - pump replacement
    -nerves and searching for the cause
    My profits: -I found this forum and people who want to help
    Proposed action plan for this type of accident - E20
    -do not panic
    -check the completeness and quantity of small garments :D
    -do not believe the household members that everything is correct :D
    - unfortunately, as it is correct, check the patency of the entire drainage and sewage system if it is Ok
    -check the pump
    I would like to thank everyone who contributed to the removal of the failure.
    Especially the secretaries; mirr- which was the first to suggest a solution.
  • #14 4369978
    mirr.
    Help: 9
    Rate: 52
    I showed her to my wife, and she says she thought one sock is missing, only one?
    I think the problem has been fixed. Fast water tests: fill, drain water and it's OK
    - pump replacement
    -do not panic
    -check the pump
    :D :D Purchase a net for washing small items
  • #15 4370008
    libretto4
    Help: 53
    Rate: 141
    The drum in the top loading machine is closed during washing, so the sock fell in when putting on or taking out clothes.
  • #16 4370676
The discussion revolves around an Electrolux EWT 1015 washing machine displaying an E20 error, indicating a sewage pump failure or blockage. The owner replaced the pump and checked the drainage system but continued to encounter the error. Forum members suggested inspecting the hose between the washing chamber and the pump for blockages. The owner later discovered a sock obstructing the hose, which resolved the issue. The conversation highlighted the importance of checking for small items in the drum and ensuring the entire drainage system is clear to prevent similar errors in the future.
