Reattaching Amica Oven Glass: Best Adhesive for Enamel Door Bonding
rtomek 56464 2
  • #1 550378
    rtomek
    Level 19  
    Help: 26
    Rate: 60
    What glue to use to glue the oven glass with the door (enamel sheet) - in the original, probably some colorless silicone - peeled off at the bottom of the door on both sides. Thanks for all answers and best regards to the whole forum.
  • #2 550538
    skwiro
    Rate: 42
    This can be glued with silicone :) .Only high temperature, one that can withstand at least 300 ° C *. They are on sale.
    Ovens reach a max of 280C *, and this is the outer pane - So no worries :)
    The manufacturer also uses silicone.
    Good luck.
