Program to Bind Sound Samples to Keyboard Keys - Computer Drums, Audio Assignment
goliat2606 49188 15
How can I assign my own WAV sound samples to computer keyboard keys so each key plays a different one-shot sound like keyboard drums?
Use a sample-based program rather than a simple virtual piano: Virtual DJ can assign 12 samples to keyboard keys, but it works as a toggle on/off player, not the one-shot behavior you want [#5785479][#5785500] A tracker like ModPlug lets you create a new instrument and assign your own wave to each note, which is closer to mapping custom sounds [#5788926] Another suggestion was a generic “sound effect player” or drum software such as EZ Drummer [#5785608] Other programs mentioned for sample playback included Music 2000, Beatcraft, and Fruity Loops/FL Studio, which also has sampling support [#5803810][#6256451]
  • #1 5775642
    goliat2606
    Rate: 16
    Hello to everything.
    I have a question, does anyone know a program in which it is possible to bind sounds to keyboard keys. It was supposed to resemble "computer drums", loads a few samples for different keys and play. I was looking for but nowhere can I find something like this: /. Thanks in advance.
  • #3 5775862
    goliat2606
    Rate: 16
    But I meant something for which I will give the sounds myself and choose the keys: /. Maybe someone has something similar to what I'm looking for?
  • #4 5779663
    goliat2606
    Rate: 16
    Can someone please help me?
  • #5 5784478
    goliat2606
    Rate: 16
    Would someone be so kind and help me?
  • #6 5784511
    adamas_nt
    Help: 1508
    Rate: 659
    I think that not only I have unsuccessfully searched Google.
    I remember that in the days of Win 3.11 there was such a program along with the Sound Blaster drivers. Maybe someone will remember something based on this information.
    For my part, I looked through my resources (2 shoe boxes) and did not find. I still have a cardboard box with floppy disks. In the evening I will work on it, if I find I will let you know.
  • #8 5785479
    chemicalkash
    Level 19  
    Help: 32
    virtual DJ has a function that allows you to assign 12 samples to the keyboard keys.
  • #9 5785500
    goliat2606
    Rate: 16
    I do not mean a synthesizer, but a program for which I will give sounds myself and assign them to selected keys on the keyboard.
    But from what I remember, in Virtual Dj it worked so that when you pressed the samples, the samples turned on and when you pressed a second time, you turned them off. My point is that the sample should turn off by itself, as I wrote in the first post, it would be a kind of "percussion on the keyboard" so the VDJ option is unfortunately not suitable.
  • #11 5785765
    goliat2606
    Rate: 16
    And in EZ Drummer there is an option to play from the keyboard ??
    Added after 5 [hours] 22 [minutes]:
    Is there any free program ??
    I probably searched everything I can, it is a simple program that only assigns the appropriate sound to the key and nowhere can I find such something: /.
  • #12 5788926
    wrkq
    Help: 40
    Rate: 22
    Krucafuks ... modplug is a tracker. Something where you take "samples" from waves. Normally a sample is taken from one or a few notes and the rest of the keys are interpolated, but you can create a new instrument and assign your own wave to each note. http://en.wikipedia.org/wiki/Tracker
  • #13 5789190
    goliat2606
    Rate: 16
    My point is that I can "play the keyboard". I need a program in which I could assign a different key of a computer keyboard different wavy with drum sounds. For example, the "q" key will switch to the "1.wav" file, and the "w" key will switch to the "2.wav" file. And so I would like to make "keyboard drums".
  • #14 5800861
    goliat2606
    Rate: 16
    Someone may have finally come across such a program?
  • #15 5803810
    DriverMSG
    Help: 3984
    Rate: 4883
    Music 2000 by Codemasters, very hard to get - I don't know the website address.
    Somewhere, I have a demo version on CD, maybe I'll find it.
    As for the paid ones, I recommend Addictive Drums
    PS. It's worth missing here:
    http://www.guitar.sk/drums/drum_patterns.htm
    http://www.kenbrashear.com/
    http://download.chip.eu/pl/download_pl_548411.html
    http://www.acoustica.com/beatcraft/
    http://www.programosy.pl/program,fruity-loops.html
  • #16 6256451
    Alchemik2600
    Help: 39
    Rate: 14
    FL also has the ability to sample. Even cool stuff when you record a text with your own voice and then sample it. That's it.
    Besides, the program sucks.
The discussion revolves around finding a software program that allows users to bind custom sound samples to keyboard keys, effectively creating a "computer drums" setup. The original poster seeks a simple solution where they can assign specific audio files to designated keys, enabling a percussion-like experience. Various suggestions are made, including Virtual DJ, EZ Drummer, and ModPlug, but the original poster clarifies that they require a program that allows for automatic sample playback without needing to toggle them on and off. Other mentioned software includes Music 2000 by Codemasters, Addictive Drums, and FL Studio, with some users reminiscing about older programs from the Win 3.11 era. The search for a free and straightforward solution continues, with users expressing frustration over the lack of suitable options.
