FDD Emulator: Keyboard Instrument USB - Format 1.4MB Partitions, File Manager Programs
Darek A. 13674 16
How can I format a USB stick for a floppy disk emulator into 100 x 1.4 MB disk images and manage the files inside those images on a PC?
Use the USB_Floppy_Manager_v140i / UFloppyManagerII_140411_EN tool from IPCAS; it automatically formats the USB stick for the selected floppy type and presents one “Floppy” volume containing 100 folders/images from 00 to 99 [#16748088] It also works like a simple file manager, so you can paste, copy, delete, and otherwise edit the contents of each floppy image [#16748088] When writing data, keep each image under 1.39 MB; select the target floppy number and then click the download/write floppy icon at the top to load that image onto the emulator [#16748088] The USB stick is not visible in Windows as normal partitions, but it works correctly on the instrument [#16748088]
  • #1 16736778
    Darek A.
    Help: 39
    Rate: 204
    I have a serious keyboard instrument whose old FDD floppy disk drive has been replaced with an emulator with a USB port. The USB stick must be formatted into 100 partitions with a size of 1.4MB (diskette size 3.5 "), selecting a specific number in the emulator on the digital display as if loading one of a hundred diskettes.
    I am looking for:
    - a program that will automatically format my "pena" for such partitions in the appropriate file format as floppy disks characterized, and:
    - a program that will be a file manager that allows you to make changes to any partition (copying files, deleting etc.), because such a "sliced whistle" partitions are unfortunately not seen on the computer.
    It's best if both of these functions could be done by one applet.
    I found myself practically all day and found nothing wise.
    Maybe there is a musician or a familiar keyboard instrumentalist who will help me?
    Regards.
  • #2 16736837
    mariuszp19
    Help: 310
    Rate: 409
    I have such a program provided with the emulator. When I get home, I'll share it with you.
  • #3 16737613
    Darek A.
    Help: 39
    Rate: 204
    It would be very nice :)
    Can he format to the above form and at the same time explore the partitions created in this way?
  • #5 16737903
    Darek A.
    Help: 39
    Rate: 204
    I will patiently wait for my colleague @ mariuszp19, because the files from the link given above scream in my antivirus program, and this one immediately deletes them.
  • #6 16747678
    mariuszp19
    Help: 310
    Rate: 409
    And what works? I sent a prv.
  • #7 16747689
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    @ mariuszp19 is this different from what is on the site?
  • #8 16747759
    mariuszp19
    Help: 310
    Rate: 409
    I have no idea, I haven't tried it. I got a program with the emulator and I use it. So far he's doing well, so I'm not looking for anything else. But out of curiosity I will test it.
    I downloaded and it works. There is only one problem for China, I can't change "floppy disks" and freely save files in any file manager. Only FLOPPY0 is still active. In this program that I have, I switch to floppy disks freely and I can save files on them in any manager. Probably it is possible and here, if you have any tips, I will gladly use it.
  • #9 16748088
    Darek A.
    Help: 39
    Rate: 204
    I downloaded this applet (USB_Floppy_Manager_v140i)
    http://www.ipcas.com/download/products/usb-floppy/usb-floppy-emulator-tool-v1.40i.zip " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://www.ipcas.com/download/products/usb-floppy/usb-floppy-emulator-tool-v1.40i.zip , it's very cool and simple, formats "pena" automatically with the selected diskette type.
    When entering my computer, but in this program, there is only one disk called Floppy, but it already has a hundred directories from 00 - to 99. Folders have a characteristic floppy icon and open like typical Windows windows. Here, nothing else, just paste, copy, remove, etc.
    Now the most important:
    - you must not exceed 1.39 MB, because after loading say, diskettes 05, you need to select position 05 in the program and press the Download floppy disk boot icon at the top, only then the files will load on our diskette 05, and if there are too many of them, the program will communicate that something should be removed because we are exceeding 1.39 (for 1.4 diskettes).
    Everything works, unfortunately such a pen is not seen by Windows, but it works great on the instrument.
    I also know for sure that there are many types of emulators and the program is not compatible with some, they must have a different, own application to use.
    Regards
  • #10 18143206
    Darek A.
    Help: 39
    Rate: 204
    I have a new, different floppy emulator that supports a pen divided not in 100, but in 1000 partitions, to manage such a divided pen is another program is not suitable for this described in this post. If anyone needs the program mentioned here, please e-mail me, I will attach it to the answer along with a description of the service.
  • #11 19549495
    WitoldHolli
    If this is still up-to-date and the program works on Windows 10, I would like to ask.
  • Gotek with FlashFloppy and jumper configuration
    #12 19551594
    Gelip
    Level 36  
    Help: 324
    Rate: 611
    Today, the best emulator is probably Gotek with FF (Flash Floppy) firmware, but I don't know if it would work with the keyboard - probably yes, but you need to configure it with jumpers:
    https://www.elektroda.pl/rtvforum/topic3790289.html#19337473 " target="_blank" class="postlink inline" title="" > https://www.elektroda.pl/rtvforum/topic3790289.html#19337473
    ATTENTION! From April this year, Gotek emulators with a new processor appeared on sale and there you probably need a different version of Flash Floppy and different settings:
    Roland and Gotek samplers
    Gotek with the new Artery AT32F415 chip
    It seems that as of today there is a new version of Flash Floppy supporting the new Gotek models
    Gotek Floppy Emulator: NEW 2021 FlashFloppy and Mods Procedure!
  • USB Floppy Manager II V1.31T writes MIDI unreliably
    #13 21369935
    pensjonat3
    >>16736837 I have the emulator installed in a Yamaha 1000, works fine and much faster than the floppy drive. There's a problem, I've replaced the Windows and running software on the PC, the original disc hits, it cuts in too. The softy from the internet is a fake. If you could send your tested soft, that would be ok, my email: pensjnat3(_at_)gmail.com
    Added after 16 [minutes]: .
    >>16736837 I also need PC software for the Yamaha 1000 floppy drive emulator.
    Added after 12 [minutes]:
    >>21369935 I downloaded the Floppy EmulatorUSB_Floppy_ManagerII_V1.31T software, unfortunately it doesn't work properly. It divides pen into 100 partitions, unfortunately it doesn't want to write MIDI file on them. Sometimes it will write, but not always, it muddles.
    Added after 8 [hours] 12 [minutes]: .
    Due to the disappearance of my software I have decided to purchase a new station for Yamaha with the software I have I will have two stations I will be happy to resell one at a low price Recording studio with keyboard and laptop set up for recording.
  • #14 21374116
    pensjonat3
    Tomorrow I will receive a package with the new station and software I have purchased; I will test it and report back.
  • #15 21377274
    pensjonat3
    I have received the shipment with the emulator and the software I have installed the UFloppyManagerII_140411_EN software on Windows 10 everything works fine maybe someone has midi kar - Budki Suflera I would be happy to exchange I have the emulator with the software for resale
  • #16 21382445
    pensjonat3
    >>16736778 I already have the original software working; what is on the internet does not work.
  • Requesting instructions and software for 1.44 MB USB FDD emulator
    #17 21771129
    jansobczak9992
    Darek A. wrote:
    I have a new, different floppy disk emulator, which supports a pen divided not into 100, but into 1000 partitions, to manage such a divided pen is another program is not suitable for this the one described in this post. However, if someone needs this program mentioned here please send me an email, I will attach it to the answer along with a description of the operation.
    I need the instructions and the program. I have a new 1.44 MB, USB, 32 bit, 500 kb/s floppy drive emulator. My email janek1957sobczak(_at_)tlen.pl. Please help.
The discussion concerns USB floppy disk emulators used in keyboard instruments, where a USB flash drive must be divided into 100 virtual 1.4 MB floppy partitions and managed as if they were individual diskettes. The main need is software that can automatically format the USB stick into the required floppy-image structure and provide a file manager for copying, deleting, and editing files inside each partition, since the partitions are not visible in Windows Explorer. A working solution is identified as IPCAS USB_Floppy_Manager / USB_Floppy_ManagerII, which formats the media automatically, shows the 00–99 virtual floppy directories, and enforces the 1.39 MB size limit per partition. Later replies mention compatibility issues with some downloaded versions, Windows 10, and alternative emulator hardware such as Gotek with FlashFloppy firmware, including newer Gotek revisions requiring updated firmware and settings.
TL;DR: For USB FDD emulators, format the stick into 100×1.44 MB slots (effective ~1.39 MB each); the bundled manager “formats ‘pena’ automatically with the selected diskette type.” [Elektroda, Darek A., post #16748088]
Why it matters: This FAQ helps keyboard players and studio techs set up, manage, and troubleshoot USB floppy emulators without corrupting song files.
How do I format a USB stick into 100 floppy partitions for my keyboard?
Install USB_Floppy_Manager v1.40i. Choose the 1.44 MB type and let it auto‑format the stick into 00–99 slots. The app handles creating the structure and icons. Keep each virtual disk within size limits and use the app’s buttons to load content into a selected slot. “Formats ‘pena’ automatically with the selected diskette type.” [Elektroda, Darek A., post #16748088]
Why do I only see one “Floppy” in Windows, and how do I copy files to slot 05, 12, etc.?
Windows sees one mounted volume via the manager. Open the 00–99 folders to stage files. Select the desired slot number in the app, then click the Download/Load floppy icon to commit data to that virtual disk. Without this step, the keyboard will not see the new files. [Elektroda, Darek A., post #16748088]
What’s the real per‑disk size limit on a 1.44 MB virtual floppy?
Stay under ~1.39 MB. If you exceed this when loading a slot, the manager warns you to remove files. Respecting this limit prevents write failures and ensures the instrument reads the disk image correctly every time. [Elektroda, Darek A., post #16748088]
My tool only writes to FLOPPY0 and won’t switch slots—how do I fix it?
That symptom points to software–hardware mismatch. One user reported only FLOPPY0 was active in a certain Chinese tool, while their bundled manager switched slots fine. Use the software supplied with your emulator or a known‑compatible version for your model. [Elektroda, mariuszp19, post #16747759]
Antivirus flags the vendor download—how can I proceed safely?
A user noted their antivirus deleted files from a linked site. If this happens, avoid that package and request the known‑good installer from your emulator’s supplier or a trusted owner via private message or email. Safety beats speed. [Elektroda, Darek A., post #16737903]
Does the floppy manager work on Windows 10 for keyboard use?
Yes. UFloppyManagerII_140411_EN was reported working on Windows 10 with a Yamaha setup. After installation, slot switching and file writes behaved as expected, enabling reliable MIDI file transfers. [Elektroda, pensjonat3, post #21377274]
I need 1000 partitions instead of 100—what software should I use?
Use the manager that ships with your 1000‑slot emulator. The 100‑slot tools discussed here are not compatible. The original poster confirmed different software is required for 1000‑partition models. [Elektroda, Darek A., post #18143206]
What are Gotek and FlashFloppy, and will they work with keyboards?
Gotek is a USB floppy emulator drive. FlashFloppy is open firmware for Gotek, adding broad instrument compatibility. A contributor recommends Gotek with FlashFloppy and notes new 2021 processors need the correct FF release and jumper settings for success. [Elektroda, Gelip, post #19551594]
What interface speed do some USB floppy emulators target?
One user cited a 1.44 MB USB emulator rated 500 kb/s and 32‑bit. This matches typical FDD data rates expected by many instruments and samplers. Verify your unit’s label and match software accordingly to avoid timing mismatches. [Elektroda, jansobczak9992, post #21771129]
How do I migrate songs from real floppies to a Yamaha PSR‑1000 USB emulator without corruption?
Use the original software supplied with your emulator. A Yamaha user reported that internet‑found tools caused issues, while the original package solved file reliability. Keep each slot under size limits and load via the manager before testing on the keyboard. [Elektroda, pensjonat3, post #21382445]
Quick 3‑step: How do I load files into slot 05 correctly?
  1. Open USB_Floppy_Manager v1.40i and select slot 05.
  2. Copy files into folder 05, keeping total under ~1.39 MB.
  3. Click the Download/Load floppy icon to commit data, then test on the instrument. [Elektroda, Darek A., post #16748088]
Why do some managers show folders 00–99 but my PC can’t mount each partition?
These tools virtualize slots; Windows mounts one management volume instead of 100 partitions. The folder view is a staging area. Use the app’s slot‑load command to write a disk image the keyboard understands. Attempting to mount each slot in Windows will fail. [Elektroda, Darek A., post #16748088]
Is there a known fix if MIDI files “sometimes write, sometimes muddle” on 100‑slot tools?
That behavior suggests incompatible software. One Yamaha user saw unreliable writes with USB_Floppy_ManagerII_V1.31T, then switched to a working package tied to their emulator. Match software to hardware to restore consistent writes. [Elektroda, pensjonat3, post #21369935]
Where can I request the older 100‑slot program and instructions?
The original poster offered to share the program and usage notes via email on request. Reach out directly to obtain the same tested package they used for 100‑slot emulators. [Elektroda, Darek A., post #18143206]
Expert tip: what’s the most common failure to avoid?
Overfilling a slot. Users report the manager rejects loads above ~1.39 MB. Keep files lean and always hit the Load button after copying. “Only then the files will load on our diskette 05.” [Elektroda, Darek A., post #16748088]
