Lost 4-Digit Code for Bicycle Cable Lock - How to Open Without Damaging or Trying All Combinations
Mychatel 60438 8
  • #1 5918067
    Mychatel
    Rate: 52
    Hello, I have a bicycle cable secured with a four-digit code.
    In this line, the code can be changed, and I used to change it out of boredom, and I had to leave for a moment, when I came back and entered the code, it turned out that it was not this one. I just got it wrong and now I can't figure out what the code is.
    Or maybe someone is good enough and knows how to open it without damaging the rope and not twisting all the combinations?
  • #2 5918120
    lowbird
    Help: 36
    Rate: 45
    For a good thing, twisting all the combinations, it's only a few hours, so in a few days on TV, you will do it on a lighter basis. After all, you don't have to look at it.
  • #3 5918352
    DJ Volt
    Help: 29
    Rate: 47
    These lines are terribly lame, I forgot to remove one from the wheel, I turned the wheel a little while starting and the whole mechanism fell apart from the closure. I recommend you to cut this line and throw it into the bin, because it is no protection. A strong jerk is enough and anyone can roll up your bike from the store.
  • #4 5919074
    Mychatel
    Rate: 52
    Oh no. Mine is thick and solid, I got angry with her more than once and, stepping on my feet with my hands, I pulled up with all my strength and nothing.
    And with this twisting it is not so easy, because she walks hard and after a hundred combinations my fingers hurt and the skin was peeling off their tips.
  • #5 5920812
  • #6 5922293
    Artur k.
    Help: 1279
    Rate: 1698
    Opening such a padlock is quite simple, I will not describe it, because it may be used by someone for the wrong purpose.
    My advice:
    Buy a second one of the same and look at how such a mechanism works, if you have a technical mind and a little imagination, you will figure out how to open it and not break it ;)
    PS
    The best are key padlocks - you can't easily open them like that, and you won't forget the code ;)
  • #7 5922594
    Stary1952
    Level 32  
    Help: 164
    Rate: 242
    There is a very rare profession called "sworn locksmith". Such a guy legally opens locks, cassettes, armored cabinets, etc., but I'm afraid you won't be able to afford him. :cry:
    Greetings .
  • #8 5924021
    Mychatel
    Rate: 52
    Well, I'll try this stretching, maybe it will work.
✨ A user is seeking assistance to unlock a bicycle cable lock with a forgotten four-digit code without causing damage or trying all possible combinations. Responses suggest various methods, including pulling the cable while turning the last digit to find the correct number, and the idea of purchasing a similar lock to understand the mechanism. Some users express frustration with the lock's security, while others recommend against using such locks due to their vulnerability. A mention of a "sworn locksmith" indicates a professional option, albeit potentially costly. The discussion highlights the challenges of using combination locks and suggests alternatives like key padlocks for better security.
