ABUS cylinder lock key stuck—how to safely remove without damaging the lock?
Achim0807 76401 2
  • #1 14270880
    Achim0807
    Rate: 11
    This morning, as usual, I wanted to close the door to my apartment and unfortunately, after turning the key, I could not remove it anymore. I can turn the key, lock and unlock the door, but unfortunately I cannot remove the key. WD40 and pliers are not helping yet. The lock is ABUS, although I do not know the model, it is definitely a cylinder. Thank you in advance.
  • #2 14271483
    stanislaw1954
    Help: 2003
    Rate: 4624
    Unscrew the bolt on the front of the slide that holds the lock and remove the lock from the lock. Buy a new cylinder of the same size and install it in the lock.
  • #3 14271575
    Achim0807
    Rate: 11
    Thanks for your comprehensive answer. So I thought that I would not avoid it, but you can always hope. The key is jammed amen. WD 40 and pliers and combining in all possible ways did not help. It's funny how these things happen in an instant with almost no warning ;)
