Dangerous Tension: Can a 12V 40Ah Battery Hurt or Kill a Person? Current Lethality Explained
cinek13 49983 30
Can a 12 V 40 Ah battery hurt or kill a person, and what current level is dangerous?
An ordinary 12 V battery is generally considered safe and is not expected to kill a healthy person under normal dry conditions, because the dangerous factor is the current that actually flows through your body, which depends on body impedance and the path it takes [#1283534][#1283533][#1284816] Currents around 1 mA are felt, 6–10 mA can cause muscle spasm and inability to let go, above 20 mA can stop breathing, and above 30 mA can disturb heart rhythm; SEP was also cited as treating 24 mA as harmful/life-threatening [#1283533][#1283224][#1283739] The most dangerous path is through the heart, and moist or tongue contact lowers resistance, so a 12 V source can sting or damage tissue even if it is usually not lethal [#1283224][#1282854]
  • #1 1282833
    cinek13
    Help: 7
    Rate: 20
    I was wondering what amount of current can kill a person, i.e. can touching a battery with 12 V and 40 Ah can hurt or kill?
  • #2 1282854
    zoltar
    Help: 12
    Rate: 24
    If you put the poles to the tongue, the shock and the related consequences may occur.
  • #3 1282863
    grzesiox
    Level 19  
    Help: 20
    oh yes oh yes :)
    What is dangerous? read books about electricity, but if I remember correctly, the residual current circuit breaker is about 40mA (?) - are you saying that? and this is just a harmful dose, and very much at that ;)
  • #4 1282885
    wzagra
    Help: 224
    Rate: 278
    70 mA kills ..
  • #5 1283224
    lordac
    Help: 9
    Rate: 32
    in fact, 10mA, which, for example, flows through the bloodstream, kills (this is the acceptable standard for medical equipment) ... but first you have to overcome the insulator in the form of the epidermis. Rather, sticking to a tongue may damage the tongue :) unless you connect the second electrode to another moist place devoid of keratinized epidermis, so that the current will flow, for example, through the aorta.
  • #6 1283429
    cinek13
    Help: 7
    Rate: 20
    And what's more dangerous: voltage or current?
  • #7 1283513
    prokopcio
    Help: 39
    Rate: 143
    not the voltage but the current kills - e.g. when removing a sweater, when you hear that it shoots electrified (sparks can be seen at night), it can reach several thousand. Volt will not kill us because the current is too low ... a person without a skin has a hand-to-hand resistance above 1kohm, therefore it is considered a free voltage up to about 30V - then in the worst possible cases it can max. current flow below 30mA (Ohm's law), which is considered the upper safety limit.
    So 12V from the battery, even if you remove the skin, it is nema right to hurt you a lot.
    But I neglected ... hi
  • #8 1283534
    Gosia2k
    Help: 11
    The 12 V voltage is as safe as possible. Nothing will happen to you if you touch it. A: for your last post: Only voltage can strike you, for example: wires stick out of a damaged contact from the wall, you can measure the voltage between them, there is no current, because the current does not flow, only after touching the phase wire with ground (earth) the current that flows is the result of the voltage (potential difference between the phase conductor and the earth) and "your internal resistance" (different when, for example, you touch one cable with your hand and the other with your foot, and ninna in the case of head - hand). Safe voltage ranges in the appendix below. Personally, I touched the conductor through which 40 kA of very low voltage was flowing; alive, I feel great ;)
    • Dangerous Tension: Can a 12V 40Ah Battery Hurt or Kill a Person? Current Lethality Explained nap. bezpieczne.JPG (42.99 KB) You must be logged in to download this attachment.
  • #9 1283533
    telewizory
    Help: 30
    Rate: 16
    It is accepted:
    Feeling the current flow - at a current> 1mA
    Muscle spasm and inability to release on its own> 6mA in women, 10 in men
    Chest muscle contraction and> 20mA breath loss
    Disturbed heart rate> 30mA
    The current that will flow through a person depends on the impedance it will provide for the voltage source. The epidermis is the greatest resistance (at voltages exceeding 150V, the epidermis is punctured), the internal human resistance is much lower (therefore removing wire insulation with teeth is not recommended). Of course, human impedance depends on the path the current travels. Under normal conditions, 50V alternating voltage and 120V direct voltage are assumed as completely safe. If you don't have a pacemaker or other serious heart problems, you'll be fine.
    The most dangerous is mains frequency, not direct current.
    The path it travels depends on what part of it will flow through the heart, and the current flowing through the heart has the greatest impact on a person's life. Electricity can have many other effects on skin, blood, brain, muscles and bones.
    Many people check the efficiency of a 9V battery by shorting its terminals with their tongue and nobody has been hurt because of it.
  • #11 1283575
    Gosia2k
    Help: 11
    And the first application of alternating current is in the electric chair. But the effects of DC voltage are much worse than that of AC (high DC voltage)
  • #12 1283713
    grzesiox
    Level 19  
    Help: 20
    Gosia and why do you think so?
    In my opinion, one stick that hurts you above a certain limit (e.g. just 40mA)
    And the voltage affects the electricity, but the current hurts you ;)
    And the fact that the cable was ticking with 40kA current, it was such a current for a very low resistance, and when you grabbed it, it was flowing through you, either very small or at all, because it was flowing through a lower resistance ...
    Ohm and Kirchoff's laws, friend ;)
    So electricity kills tension.
  • #13 1283720
    cinek13
    Help: 7
    Rate: 20
    And with water, how is it? what (min.) voltage of the sea conducts the water ???
  • #14 1283728
    grzesiox
    Level 19  
    Help: 20
    depends on water or heavily mineralized, etc ...
    distilled theoretically is not conductive because there is nothing to conduct in it, so it can be used to clean a wet phone, etc ...
  • #15 1283739
    bullo
    Rate: 10
    according to ..... SEP regulations, the intensity of 24mA is already harmful to humans ... and is life-threatening ... it depends on the place of flow through the body ...
    Added after 11 [minutes]:
    and then a reference to the reading book ... www.sep.com.pl / studies
    / Selected issues of protection against electric shock in electrical installations up to 1 kV - mgr inż. Andrzej Boczkowski, Chairman of the Section of Electrical Installations and Devices at SEP
    I recommend if someone can not fall asleep ... hehe
  • #16 1284816
    Gosia2k
    Help: 11
    grzesiox wrote:
    And the voltage does not affect the current, but the current hurts you ;)
    How does not voltage affect the current, what does it? The sum of sunny days in March divided by Andrzej Lepper's IQ? The current that kills you is only due to its cause (forcing) to voltage. Assuming a constant impedance of the human body (e.g. hand -----> leg), it is the voltage level that determines the size of the current; Ohm's law buddy ;) . Before touching, for example, the cable, there is no current, there is voltage, the current appears at the moment of touching. That is why safety voltages have been defined (see above).
  • #17 1284988
    grzesiox
    Level 19  
    Help: 20
    hehe there was not supposed to be this "no" ;) - I have already corrected - read now ;)
    Windows breaks something and I either eat letters or insert some strange things ;)
    and I know what has been determined and that is about the copy electricity and not voltage ;)
  • #18 1285903
    cinek13
    Help: 7
    Rate: 20
    Please answer this question. Because I want the LED to work under water and I don't know if I should build a waterproof "capsule" or can I turn it on under water without protection.
  • #19 1286130
    telewizory
    Help: 30
    Rate: 16
    If you want to power it from a battery or accumulator, there is no threat to human life (as far as the aquarium is concerned, I have no idea how it will affect the fish). Do not use the AC adapter if you will come into contact with water under normal conditions (e.g. bathtub). You can also use an AC adapter to power the aquarium.
  • #20 1286294
    pit_com
    put the diode in the cover because electrolysis will take place and various substances will be released. By the way: CURRENT IS THE MOST IMPORTANT !!! AND DEPENDS ON VOLTAGE AND RESISTANCE !!! CURRENT = VOLTAGE / RESISTANCE !!! And remember that, it's very important !!!! And remember that you can't tell if some cable "goes" with some amps, because it depends on the difference in voltage and resistance !!! so if you connect a 1000ohm resistor to 220V, the current will flow 220/1000 = 0.22A, i.e. 220mA. We cannot talk about voltage conduction either, because voltage is only a term for "electron density" (pathologically) and it has a meaning when we count power !!! power = voltage * current (current). how do you have any questions to come on !!! it is best to understand the current as a gas pipeline (voltage = gas pressure, current (intensity) = gas flow velocity, resistance = pipe narrow (the narrower the greater the resistance)) and this is the easiest way to understand :-)
  • #21 1286695
    cycu1118
    Help: 7
    Rate: 8
    once there I heard that the 24v is already kicking ... and how are electric lighters and how will it break? ;) there is "something like that" in the middle, when you press it, it gives a spark while kicking how much of it is a volt and what current is it?
  • #22 1286727
    cinek13
    Help: 7
    Rate: 20
    Do not use an AC adapter
    But why ? What is the difference between a 9V AC adapter and a 9V battery
  • #23 1286931
    telewizory
    Help: 30
    Rate: 16
    The difference is that the battery will never have a voltage greater than 9V and the power supply can also provide 220V as a result of a failure. Although this is an extreme and very rare case, life is probably not worth risking. These are mostly shoddy power supplies with poor insulation. However, even those with safety approvals pose a risk when they are flooded with water, or even as a result of condensation inside them. If you absolutely want to, use only a good quality power supply and it is best to connect it to the mains outside the bathroom, using a low voltage cable to it.
  • #24 1286948
    marcinj12
    Level 40  
    Help: 1024
    Rate: 250
    The point is that if you use an ordinary transformer to power devices in the bathtub, if there was a breakdown and 230 would appear on the secondary winding instead of 9V, you know what the consequences would be if someone was just taking a bath ...
    Of course, this is a purely theoretical protection (I do not think that fittings manufacturers use batteries to power, for example, hydromassage motors), but it is always better to be safe than sorry. By the way - the maximum DC voltage within the bathtub is 12V AC. Such voltages are also used to power jacuzzis or other hydro massages.
  • #25 1287740
    cinek13
    Help: 7
    Rate: 20
    And if we could protect them in the form of constantly charging batteries. The diode would take the current from the battery and the power supply would charge it all the time. If there was a "breakdown", the batteries would act like bespieczniki. Just like in the picture. Sorry for the ugly :)
    • Dangerous Tension: Can a 12V 40Ah Battery Hurt or Kill a Person? Current Lethality Explained xxx.jpg (15.31 KB) You must be logged in to download this attachment.
  • #26 1289024
    grzesiox
    Level 19  
    Help: 20
    Well, probably not to the end :) because you have to turn them on in parallel ;) and then you have power on the diode anyway ;) and the batteries only do what the UPS does for the computer :)
  • #27 1289406
    cinek13
    Help: 7
    Rate: 20
    So what are you suggesting?
  • #28 1292054
    cinek13
    Help: 7
    Rate: 20
    Why aren't you writing?
  • #29 1293326
    bu508
    Help: 5
    The drawing suggests that this is intended to be aquarium lighting. Some aquatic organisms are sensitive to voltages of the order of uV, therefore attempts are being made to use them as earthquake warning detectors. So it is imperative to insulate everything.
    The power supply in the picture is a typical crap, see the posts above. If you use the power supply directly for power supply, no batteries are needed.
    If the batteries are 2 shifts: 1 is working, the other is charging and then swapping. In my opinion, this is the safest solution, although the service is absorbing.
  • #30 1293569
    cinek13
    Help: 7
    Rate: 20
    It will not be a power supply, but a charger for the Nokia 3510i
    And if everything is well insulated, should I be afraid of "puncture" or not?
The discussion centers around the potential dangers of a 12V 40Ah battery and the current levels that can be lethal to humans. Participants highlight that while voltage is important, it is the current that poses the real threat. Current levels above 1mA can be felt, while 6-10mA can cause muscle spasms, and currents above 30mA can disrupt heart function. The skin's resistance plays a crucial role in determining whether a current can flow through the body, with 12V being generally considered safe under normal conditions. The conversation also touches on the differences between AC and DC currents, with DC being noted for its potentially more severe effects at high voltages. Safety measures for using electrical devices in wet environments, such as aquariums, are also discussed, emphasizing the importance of proper insulation and low voltage usage.
TL;DR: 10 mA through the heart can trigger fibrillation [IEC 60479-1]; “current, not voltage, kills” [Elektroda, prokopcio, post #1283513] Dry-skin impedance (~1 kΩ) limits a 12 V car battery to about 12 mA—felt but seldom lethal. Wet skin slashes resistance, so stay below 30 V for personal work safety.
Why it matters: This FAQ helps makers, hobbyists and aquarists avoid low-voltage traps that can still shock, injure—or in rare cases—kill.
• Safe-touch limits: ≤50 V AC or ≤120 V DC per IEC 60479-1. • Typical residual-current device (RCD) trips at 30 mA in 40 ms [IEC 61008]—below the 45 mA breathing-arrest zone [Elektroda, telewizory, post #1283533] • Car battery short-circuit current: 300–800 A (12 V, 40 Ah class) [BatteryCouncil, 2021]. • Human skin resistance: 1 kΩ–100 kΩ dry; 300 Ω–1 kΩ wet [NIOSH, 2013]. • 70 mA across the chest is “usually fatal” [Elektroda, wzagra, post #1282885]
Can a 12 V 40 Ah car battery actually kill you?
Unbroken, dry skin gives ≥1 kΩ resistance [NIOSH, 2013]. Ohm’s law shows 12 V/1 kΩ ≈ 12 mA—below the 30 mA fibrillation threshold [IEC 60479-1]. With wet skin or wounds (≈300 Ω) current rises to 40 mA, entering the danger zone. So death is unlikely but possible in water or through broken skin. Keep cuts covered and use insulated leads.
What current range is lethal for the human body?
According to IEC 60479-1, 30–50 mA can cause respiratory paralysis, and ≥75 mA can trigger ventricular fibrillation within seconds. Forum users quote similar figures: “70 mA kills” [Elektroda, wzagra, post #1282885]
Why do experts say current, not voltage, kills?
Voltage only creates risk by pushing current through tissue. “Current, not voltage, kills” [Elektroda, prokopcio, post #1283513] A static-discharge sweater can hold 10 kV yet supply microamps—harmless. Conversely, 80 mA at just 25 V through a pacemaker lead can be fatal [IEC 60479-1].
How much current flows through my body at 12 V when my hands are wet?
Wet-hand resistance often drops to 500 Ω [NIOSH, 2013]. 12 V ÷ 500 Ω ≈ 24 mA—enough to lock muscles and stop breathing after several seconds [Elektroda, telewizory, post #1283533] Dry hands reduce current four-fold.
Is DC safer than AC at the same voltage?
At human body frequencies, AC is more dangerous. 50–60 Hz AC causes continuous heart muscle stimulation, promoting fibrillation. IEC curves show DC needs roughly double the current to cause similar harm [IEC 60479-1]. Edge case: High-voltage DC arcs can burn deeply even without shock [OSHA, E2002].
Why are household RCDs set to 30 mA?
30 mA lies just below the 30–50 mA respiratory-arrest zone; tripping within 40 ms prevents sustained heart current [IEC 61008]. Forum member grzesiox mentions 40 mA as a harmful dose [Elektroda, 1282863]
Does sea or fresh water increase shock risk at low voltage?
Sea water’s conductivity (~5 Ω·m) dwarfs that of fresh water (~200 Ω·m) [NOAA, 2020]. Water lowers body resistance, letting >30 mA flow even at 12 V. Hence bathroom standards cap DC to 12 V and AC to 25 V near tubs [IEC 60364].
How do I power an LED safely under water?
  1. Encapsulate the LED and leads in aquarium-grade silicone.
  2. Feed it from a sealed 12 V battery outside the tank.
  3. Add a 100 mA fuse inline to stop fault currents. Telewizory notes battery supply removes 230 V fault risk [Elektroda, 1286130]
Is a 9 V plug-in adapter as safe as a 9 V battery?
No. A failed wall wart can leak 230 V to the output leads [Elektroda, telewizory, post #1286931] Batteries cannot exceed their rated 9 V. If you must use an adapter, choose a medical-grade SELV unit and mount it outside wet zones.
How many volts and amps are in a piezo gas-lighter spark?
Piezo lighters create ~10–15 kV pulses at nano-amp currents—enough to jump 5 mm air gaps but too brief and weak to harm humans [Kirby, 2019].
I have a pacemaker—what extra precautions should I take?
Avoid touching circuits above 30 V, even briefly. 10 mA across implanted leads can disturb pacing [FDA, 2021]. Wear insulating gloves and ensure RCD protection in workshops.
How can I test a 12 V battery without shocking myself?
  1. Clip insulated multimeter probes before powering the battery.
  2. Keep one hand behind your back to avoid a chest current path.
  3. Measure voltage; if tools slip, fuse limits spark energy. Following this routine prevents accidental hand-to-hand conduction [Elektroda, telewizory, post #1283533]
