Is 4-20mA Current Range Safe for Human Body Contact?
552 8
  • #1 21679460
    Derby Jhon
  • 4-20 mA loop is safe to touch
    #2 21679461
    Rick Curl
  • #3 21679462
    Conrad Mannering
  • RCDs trip at 30 mA on mains faults
    #4 21679463
    David Ashton
  • Household voltage contact warrants heart check
    #5 21679464
    Conrad Mannering
  • #6 21679465
    Bart Allen
  • #7 21679466
    Rick Curl
  • #8 21679467
    Aubrey Kagan
  • Body resistance determines 24V shock risk
    #9 21679468
    David Ashton
The 4-20mA current loop used in industrial instrumentation is generally safe to touch because the voltage involved is low and skin resistance is high, preventing significant current flow through the human body. Contact with a live 4-20mA loop typically does not cause a perceptible shock. However, if a current of 4 to 20mA were to actually flow through the body, it could be dangerous or even lethal depending on the voltage and current path. Human tolerance to electric current varies, with 30mA often cited as the highest non-lethal current threshold, as evidenced by Residual Current Devices (RCDs) or Earth Leakage Circuit Breakers (ELCBs) that trip at this level to prevent electrocution. Factors such as skin moisture, contact area, and the current path significantly affect the risk. Experiments with multimeters and batteries demonstrate that wet skin and larger contact areas reduce resistance and increase current flow, potentially increasing hazard. Safety precautions include avoiding intentional current flow through the body, using insulating footwear, and relying on protective devices like ELCBs. High voltage and high current scenarios pose greater risks and require strict safety measures.
