Motherboard Cleaning: Using Denatured Alcohol or Extraction Gasoline - Safe or Damaging?
Zulok 39698 20
Can I safely clean a dirty motherboard with denatured alcohol or extraction gasoline?
Use isopropanol/propanol instead of extraction gasoline, and treat denatured alcohol only with caution because it can leave residue. For a thorough wash, one reply recommends rinsing the board in distilled water with a brush, drying it, then washing or spraying it with isopropanol on both sides, and drying it again very well [#5993568] Another reply says denatured alcohol is not “pure” alcohol and leaves sediment, so if it is used at all, it should be followed by a rinse with drinking спирit/ethanol; it also says propanol would be the best choice [#8725190] A shorter answer adds that if you are cleaning with fluid, the fluid should be isopropanol [#5990020] For dust only, compressed air is mentioned as the safest option, but not as a washing method [#5990269]
  • #1 5989958
    Zulok
    Rate: 19
    Hello, I wanted to ask what to clean a dirty motherboard with. Will denatured alcohol or extraction gasoline damage the equipment?
  • #2 5990020
    K!lleR
    Help: 456
    Rate: 131
    Brush quite wide, not too big, or compressed air. If the fluid is just isopropanol.
  • #3 5990269
    Xylometazolin!
    Help: 264
    Rate: 858
    Compressed air will probably be the safest.
  • #4 5990349
    mat_ed
    Help: 924
    Rate: 268
    Read clearly what the author wrote. He means washing the motherboard, and as far as I know, it will not wash the motherboard with compressed air. Well, unless you've seen compressed air that is used to wash the motherboard, provide the link - I'll be happy to see it.
  • #5 5990389
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 587
    Basic question: what is the disc dirty with?
  • #6 5990396
    Xylometazolin!
    Help: 264
    Rate: 858
    And what are these emotions for? I got it wrong and that's it, I'm only human.
    When it comes to literal washing, as someone has already written - isopropanol.
  • #7 5990419
    warczyk_nbr
    Help: 6
    I washed my CD with a damp cloth ...
    Then I waited for it to dry very well and plugged it in.
    Regards.
    Moderated By K!lleR:
    I give a warning for such brilliant advice.
  • #8 5990491
    jag61
    Radiation protection specialist
    Help: 115
    Rate: 85
    ZULOK - and then what a colleague wants to do YES to wash the motherboard ??
  • #9 5993445
    Zulok
    Rate: 19
    I poured coffee with cream over the CD and now it is all dirty and a bit greasy.
  • #10 5993567
    warczyk_nbr
    Help: 6
    Zulok - what you don't have a computer case?
  • #11 5993568
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 587
    1. Thorough washing in distilled water (with a brush);
    2. Drying;
    3. Washing in isopropanol or sprinkling the plate thoroughly with isopropanol on both sides (we do not regret isopropanol, it should drip off it);
    4. Thorough final drying;
  • #12 5998386
    Zulok
    Rate: 19
    warczyk_nbr
    I just had the disc disconnected.
    And extraction gasoline would not be suitable, because I do not even know where to buy this isopropanol?
  • #13 5998452
    Xylometazolin!
    Help: 264
    Rate: 858
    Isopropanol can be purchased from most electronics stores.
  • #14 5998464
    Buczusiek
    Rate: 31
    You can buy isopropanol without any problems on Allegro.
    Chemical stores are another option, they should have. And in the latter case, electronics stores.
  • #15 5998539
    K!lleR
    Help: 456
    Rate: 131
    How about oil?
    Isopropanol 1 / L costs about PLN 10.00
    I recently bought 5 / L on the Allegro for a total of 45.00 PLN.
  • #16 5998733
    warczyk_nbr
    Help: 6
    so it will be left to clean the disc with Isopropanol, and a soft brush would also be useful.
  • #17 5999176
    jag61
    Help: 115
    Rate: 85
    "Borrow" brush from a friend / sister / mother / wife (delete as appropriate ;-) ) - seriously - pay special attention when washing (that is - do it very carefully) on places with small gaps between elements / leads - that there is nothing superfluous "left".
  • #18 8722222
    chris061
    Can a flooded plate be cleaned with colorless denatured alcohol? I am going to clean it, but I do not know if I can use this product? With a brush? I will add that the laptop motherboard.
  • #19 8725190
    jag61
    Help: 115
    Rate: 85
    Theoretically yes - although I would be careful - denatured alcohol is not "pure" spirit / alcohol, it leaves a sediment (after "washing" with denatured alcohol, I washed / rinsed in food spirit). Of course, propanol would be the best (maybe you would consider whether it is better to buy a liter of propanol - at least through POCh)
  • #20 8725195
    chris061
    But I'd better buy propanol and leave the denatured alcohol to clean other things.
    Thanks for the answer
  • #21 8725432
    jag61
    Help: 115
    Rate: 85
    I would like to remind you that propanol, like alcohol - is flammable - flammability class 2 (same as explosiveness) - moreover, see also on Wiki
The discussion centers on the appropriate methods for cleaning a dirty motherboard, specifically addressing the use of denatured alcohol and isopropanol. Users recommend isopropanol as the safest option for cleaning, emphasizing its effectiveness when used with a soft brush and distilled water for initial washing. Concerns are raised about using extraction gasoline and denatured alcohol due to potential residue and damage. It is suggested that isopropanol can be easily purchased from electronics and chemical stores. Users also highlight the importance of thorough drying after cleaning to prevent damage to the motherboard.
