Can Extraction Gasoline Safely Remove Thermal Paste Without Damaging PCB Laminate?
10677 6
  • #1 15718334
  • #2 15718357
    Rezystor240
    Help: 689
    Rate: 1651
    extraction naphtha is suitable for this purpose.
    Nothing will happen to the PCB if a random drop falls.
  • #3 15718382
  • #4 15718388
    Rezystor240
    Help: 689
    Rate: 1651
    Sure it will work, but why do you want to clean the motherboard? Did she get dirty while applying the paste?
  • #5 15718646
  • #6 15718707
    arewin
    Help: 33
    Rate: 198
    The safest way is to use isopropanol, e.g. cleanser, it is not expensive. Possibly another preparation with a similar use.
  • #7 15718759
    Rezystor240
    Help: 689
    Rate: 1651
    You can easily clean it with extraction gasoline
Extraction gasoline, specifically extraction naphtha, is deemed suitable for cleaning thermal paste from processors without damaging the PCB laminate. Users confirm that accidental drops of extraction gasoline will not harm the PCB. However, it is suggested that isopropanol is the safest and most recommended cleaning agent for this purpose. The discussion also touches on the necessity of cleaning the motherboard, with one user mentioning a mishap while applying thermal paste.
