Seeking Recommendations: Best Cleaning Liquids for Electronic GSM Plates
sebaele22 21774 14
What liquid should I use to clean electronic boards, remove flux, and soak motherboards after flooding?
Use pure isopropyl alcohol (IPA) for cleaning electronic boards, flux removal, and soaking motherboards after flooding [#15361199][#15361698] Cleanser Druk was also recommended as a product that is almost the same as IPA and leaves no traces on the PCB [#15361248] Several replies specifically say IPA is what they mainly use and that it removes most fluxes after flooding [#15360095][#15360151] Acetone was mentioned, but it was rejected because it dissolves many plastics [#15398521]
  • #1 15360062
    sebaele22
    Level 30  
    Rate: 513
    As in the topic of what preparation for cleaning electronics rinsing, e.g. GSM.
  • #2 15360095
    marci4
    Help: 169
    Rate: 177
    It depends on what you want to clean. I mainly use IPA.
  • #3 15360106
    karolark
    Help: 702
    Rate: 2516
    I also use IPA.
  • #4 15360146
    sebaele22
    Level 30  
    Rate: 513
    I mean, how to clean from what I do not understand? I am just looking for some agent that will be very good at cleaning electronics, e.g. after flooding, for removing flux, etc.
  • #5 15360151
    ladamaniac
    Help: 724
    Rate: 2078
    After flooding with IPA, most fluxes also come off IPA.
  • #6 15361181
    sebaele22
    Level 30  
    Rate: 513
    So what exactly to look for?
  • #7 15361199
    vania
    Help: 84
    Rate: 65
    Isopropyl alcohol (IPA)
  • #8 15361248
    Ture11
    Help: 573
    Rate: 1130
    I recommend Cleanser DRUK, it's almost the same as IPA, but leaves no traces on the PCB. The use of PRINT is rather flux removal after soldering, than cleaning the plates after pouring, but it is worth mentioning.
  • #9 15361269
    sebaele22
    Level 30  
    Rate: 513
    I am looking for something that can be used for cleaning flux, various other impurities as well as for soaking motherboards, e.g. after flooding.
  • #10 15361698
    vania
    Help: 84
    Rate: 65
    sebaele22 wrote:
    I am looking for something that can be used for cleaning flux, various other contaminants as well as for soaking motherboards, e.g. after flooding.
    This is what you can choose from pure isopropyl alcohol (IPA) and Cleanser Druk which mainly consists of IPA. I use IPA and also for cleaning the PCBs after soldering Water PCB cleaner
  • #11 15361950
    sebaele22
    Level 30  
    Rate: 513
    Thank you for all your help, I close the topic :-) .
  • #12 15396069
    sebaele22
    Level 30  
    Rate: 513
    Hello, I bought ISOPROPYL ALCOHOL IPA ISOPROPANOL 100% I hope it will be a good agent for cleaning motherboards soaking after flooding etc. :-)
  • #13 15398511
    phanick
    Help: 65
    Rate: 2840
    Why not acetone?
  • #14 15398521
    Freddy
    Help: 1394
    Rate: 2821
    phanick wrote:
    Why not acetone?
    To the fact that it is not suitable for this, it dissolves a lot of plastics.
  • #15 15411968
    sebaele22
    Level 30  
    Rate: 513
    Thank you for your help, I close this topic.
The discussion centers around the best cleaning agents for electronic GSM plates, particularly after incidents like flooding or for removing flux. The primary recommendation is Isopropyl Alcohol (IPA), which is noted for its effectiveness in cleaning electronics and removing flux residues. Another suggested product is Cleanser DRUK, which is similar to IPA but leaves no traces on PCBs. Users also mention the importance of avoiding acetone due to its potential to dissolve plastics. The conversation concludes with the author expressing gratitude for the recommendations and confirming the purchase of 100% Isopropyl Alcohol for cleaning motherboards.
