Effect of Alcohol on Electronic Components: Washing Plates, Capacitors, Transistors, Resistors
snajper7.92 16508 15
Can I wash a PCB with alcohol after soldering without damaging capacitors, transistors, or resistors?
Yes—cleaning a board with spirit, denatured alcohol, ethanol, or preferably isopropanol is generally considered safe for capacitors, transistors, and resistors, and users reported no damage in practice [#4353853][#4360746] Isopropanol was recommended as the best option and also as cheap [#4354231] Alcohol helps remove rosin and dirt, absorbs moisture, and can improve the insulation of the board surface [#4354621] Be careful with coils and transformers: some are varnished or wax-protected, and alcohol can dissolve that protection, especially on HF coils and similar parts [#4360562] It is also wise to remove the worst rosin mechanically first and to rinse thoroughly, especially around edge connectors, so dissolved residue does not remain and spoil contact [#4364708][#4364171]
  • #1 4353825
    snajper7.92
    Help: 9
    Rate: 40
    Hello, as in the subject, I wanted to ask if alcohol when washing the plates with it after soldering from the remains of rosin with soldered elements will not damage them?
    I read that electronics are washed in this way, e.g. a mobile phone flooded with water, and even soaked in alcohol for a long time.
    I mean capacitors transistors and resistors. Thanks for the help.
    Sorry if I posted the topic in the wrong place.
    artbi
    Level 19  
    Help: 22
    Rate: 45
    Hello, according to my practice, nothing was damaged by spirit / denatured alcohol / greetings
  • #3 4353871
    snajper7.92
    Help: 9
    Rate: 40
    Thanks artbi if anyone has any other comments please share them.
  • #4 4354016
    czarutek
    Help: 150
    Rate: 86
    I prefer extractive gasoline.
  • #5 4354231
    revolt
    Help: 159
    Rate: 186
    Isopropanol will be best. It's cheap.
  • #6 4354621
    elek555
    Level 37  
    Help: 310
    Rate: 252
    Not only does it not damage, but it absorbs all moisture and thus improves the insulation parameters of the surface of the tile and elements. Of course, it facilitates the removal of even stuck dirt. With so many advantages, one should even go on to describe the unparalleled taste... :) but the law can get in the way. The cell service buddy keeps saying that nothing can replace a great isopropanol bath :)
  • #7 4354660
    czarutek
    Help: 150
    Rate: 86
    Where to get isopropanol?
  • #11 4359493
    snajper7.92
    Help: 9
    Rate: 40
  • #12 4360562
    shg
    Help: 339
    Rate: 135
    Just watch out for the coils, not the miniature ones in resistor housings or radial chokes with an air gap, only those in HF circuits. (usually shielded with a can).
    Such coils are sometimes protected with varnish, which unfortunately dissolves in alcohol. With gasoline, I would also be careful with the coils, because sometimes these can also be protected with a drop of wax. Similarly, transformers (lacquer).
    Of the alcohols, isopropanol (good, because pure alcohol) or spirit comes out relatively cheap, good for food (doesn't smell, doesn't leave muck, doesn't contain aggressive additives) and preferably from across the eastern border, because of the cost. You can also technical, ideally it would be contaminated with methanol, this is already cheaper than mineral water. Unfortunately, I do not know where it comes from, I have seen contaminated with ether and benzene, but both are not suitable. Methanol itself is of course also good and just as cheap.
    I do not recommend more exotic alcohols (for example, isobutanol, which dissolves much more substances than ethanol or isopropanol)
  • #13 4360746
    dual
    Help: 34
    Rate: 72
    shg wrote:
    "Methanol itself is of course also good and just as cheap.
    I do not recommend more exotic alcohols (for example, isobutanol, which already dissolves much more substances than ethanol or isopropanol) "
    It is a fantasy of a colleague, because methanol as a POISON is unavailable in normal sale, and besides, it is not a better solvent than ethanol, not to mention isopropanol. As for isobutanol, it's also a dud, because its intense smell would be unacceptable. It seems to me that neither of the colleagues had anything to do with it. I can confirm the opinions of the previous speakers regarding the use of ethanol or isopropanol, but the cheapest will be to buy colorless denatured alcohol (available in household appliances stores), which is a mixture of alcohols with sufficient capacity to dissolve rosin, and at the same time does not threaten other elements of the system and easily evaporates from the washed surface.
  • #14 4361214
    shg
    Help: 339
    Rate: 135
    I just said it was good, not better. It is dangerous and therefore its trade is restricted because it is difficult to distinguish from ethanol and can accidentally (or intentionally) be ingested. Stronger poisons are available in grocery stores and used in almost every household.
    If you know what you're working with and use it consciously, I don't see any obstacles. However, I cannot imagine working with hazardous substances without familiarizing myself with the elementary safety rules and properties of these substances.
    I'll highlight what my colleague apparently missed:
    More exotic spirits I do not recommend (e.g. isobutanol (...)
    Isobutanol cleans rosin quite well, but is only suitable for "unfilled" boards, for example, it can remove prints from component housings. Unfortunately, the smell (I won't say stench, because there are worse things) actually leaves a lot to be desired, although isopropanol does not smell like a spring meadow either.
    I had and I have.
  • #15 4364171
    kavma
    Help: 38
    Rate: 94
    Maybe another note.
    If washing in ethanol, then rather in a large amount because, as my colleagues mentioned, the rest of the rosin is dissolved during washing.
    With boards equipped with edge connectors, poor rinsing of the dissolved rosin can effectively eliminate or deteriorate the contact between the connectors of the board / card and the board.
  • #16 4364708
    elek555
    Level 37  
    Help: 310
    Rate: 252
    The rosin itself is best removed mechanically first. By pressing, for example, with a needle or a thin screwdriver, we cause cracking and chipping of rosin droplets. Remaining remains will be much easier to remove with spirit. Spirit also effectively removes the remains of soldering paste that many electronic engineers use and later looks for the reasons for the failure of the system. Solder paste LEADS! Some people do not want to recognize this simple fact and spend many hours of deep thought and searching. Paste residues left behind cause the system to malfunction and then corrode everything around it.
    The aforementioned colleague claims that the alcohol-based paste resembles quince in taste and color :) .
The discussion centers on the use of alcohol for cleaning electronic components, particularly after soldering. Users confirm that isopropanol and denatured alcohol are effective and safe for cleaning circuit boards, capacitors, transistors, and resistors without causing damage. Isopropanol is highlighted as the preferred choice due to its low cost and effectiveness in removing rosin and moisture, thus improving insulation. Caution is advised regarding certain components, such as coils and transformers, which may be varnished and could be damaged by alcohol. Mechanical removal of rosin is recommended before using alcohol for cleaning. Users also discuss sourcing isopropanol and denatured alcohol from various suppliers.
