Selecting the Best Ultrasonic Cleaner for Phone and Laptop Motherboards
wentyl215 12792 13
Which ultrasonic cleaner is a good value for cleaning phone and laptop motherboards?
For phone motherboards, the CD-4820 is recommended as a good price-to-capacity/power choice, with a 245x145x70 mm tank that should fit all phone boards and an option to heat the cleaning liquid to improve cavitation and cleaning efficiency [#16658205] For electronics, use isopropyl alcohol or a similar electronics cleaner such as Cleanser Druk; it can stay in the tank permanently, but the lid should be kept on because it evaporates quickly, especially with heating [#16658292] General-purpose concentrates like DEMA or K3 are mixed with distilled water and were tested more for mechanical parts than electronics, so they are not the usual daily choice for PCB cleaning [#16658292] For laptop motherboards, tank size is the key criterion, the CD4820 is only considered OK for small electronics, and one reply says you will not fit within PLN 1000 for laptop-board washing [#16658358]
  • #1 16656981
    wentyl215
    Level 19  
    Help: 11
    Rate: 64
    Hello, I am asking you to recommend a good ultrasonic cleaner, it is not about the cheapest, it is not about the most expensive one - in general, the price is to be quality, i.e. the cheapest, but it should work, that it could remove deposits on the phone's motherboard.
    By the way, I will also ask about laptop motherboard washers, so far as approximate.
  • #2 16658205
    Godziks
    Given the ratio of price to tank capacity and power, one of the more competitive positions is the washer with the symbol CD-4820 .
    We use such a washer on our website and we can confidently recommend it. We use just for washing tiles with electronics using isopropyl alcohol. This washer also has the option of heating the tank with washing liquid. An increase in temperature causes the phenomenon to intensify cavitation , i.e. in practice, increasing washing efficiency. The 245x145x70mm tank will definitely wash all your phone's motherboards.
    Peter
  • #3 16658250
    wentyl215
    Level 19  
    Help: 11
    Rate: 64
    There are 3 different liquid offers on page. I understand that instead of buying e.g. 5L isopropyl alcohol for PLN 36, it is better to take K3 concentrate, where you can have PLN 23 after cleaning with water for 50L of cleaning fluid, I think?
    Well, what does the operation look like ... the washer has 2.5L capacity, we pour this isopropyl alcohol there and after washing one plate, pour 2.5L alcohol and pour another 2.5L?
  • #4 16658292
    Godziks
    For cleaning electronics and components we mainly use the aforementioned isopropyl alcohol and its derivatives, e.g. Cleanser Druk, which in practice is an alcohol with the addition of some cleaning agent. It dissolves most of the impurities on PCBs after the soldering process, mainly about removing soldering flux based on rosin etc. In addition, this liquid has a nice supply (but this is a subjective feeling). Friends from GSM services clean phones with this liquid mainly after flooding.
    Regarding the practical use of the isopropyl alcohol washer, it can be kept permanently in the bathtub. It is important to cover the tub with a cover from the set, because it evaporates quite intensively - especially when using the heating function. Replace the liquid only when we find that it is dirty or we find that after washing the element is still dirty.
    As for additional DEMA or K3 fluids, these are concentrates to be reconstituted with distilled water . These are general-purpose preparations and on a daily basis we do not use them for electronics (although they have electronics written in the specification). We tested this agent rather for cleaning mechanical components. If you choose, both concentrates are very similar. From what I remember quickly, K3 has an additional corrosion inhibitor component (which supposedly prevents collisions on metal elements).
    Greetings,
    Peter
  • #5 16658307
    wentyl215
    Level 19  
    Help: 11
    Rate: 64
    Okay, because no one else helped me, I decided to place an order on your site, I'm also waiting for delivery.
  • #6 16658328
    Godziks
    Thank you. You will certainly be satisfied with your purchase
  • #7 16658358
    Jawi_P
    Level 36  
    Help: 260
    Rate: 715
    Search by tank size. Because this is the most important criterion. For laptop boards, it's not cheap.
    The CD4820 for small electronics is ok. A friendly website just uses what I see.
    You won't fit in PLN 1000 for laptop boards.
    wentyl215 wrote:
    Okay, because nobody else helped me
    You wrote a post yesterday around 5pm and until today no one has helped you?
    It would be appropriate to apologize to you? ;)
  • #8 16658459
    wentyl215
    Level 19  
    Help: 11
    Rate: 64
    Well, Godziks helped, too, there is no reason for which to apologize ... Thank you too for the post regarding laptops. ;)
  • #9 16660539
    wentyl215
    Level 19  
    Help: 11
    Rate: 64
    I was to be happy, unfortunately the washer did not work, blinked once when connecting and that's it, no Polish manual? We advertise after 5 minutes of receipt.
  • #10 16660556
    Godziks
    WOW,
    This is called malice of inanimate things :(
    Don't worry, the goods will be exchanged for functional and tested. You will still be pleased.
  • Complaint about delayed replacement shipment timing
    #11 16660791
    wentyl215
    Level 19  
    Help: 11
    Rate: 64
    Well, it's just a pity that you didn't go on hand and refused to send a second copy, where tomorrow maybe I would have functional equipment and I would give away the broken one right away. Some stores go for such systems, especially in a situation where I haven't even used this equipment, and of course Friday tomorrow, also with you back is only on Monday and even if you send it expressly, the new copy will be at my minimum Tuesday / Wednesday so virtually all week.
  • Replacement unit received and initial operation looks promising
    #12 16675353
    wentyl215
    Level 19  
    Help: 11
    Rate: 64
    As I suspected, the washer returned on Wednesday. The report was replaced with a new one and the operation checked before shipment. And it works, we will see with what quality, but it looks promising, I only wonder that this time the seller did not put the warranty seal (that model had it and I was not allowed to break it, because I wanted to check if it was only a fuse).
    I just hope that the washer will last longer than the warranty period, because there may be problems with complaints. :D
    I do not close the topic yet, in a few days I will put some assessment for this device, maybe I will help someone ...
  • #13 16713843
    ...KUBA...
    Help: 65
    Rate: 316
    Hello, I am waiting for reports from using the CD4820 washer because I am also interested in buying it.
  • #14 16713860
    wentyl215
    Level 19  
    Help: 11
    Rate: 64
    The washer does what it is supposed to do, washes the electronics, but it has already torn the ears of the basket. Poor hinges and already cracked. I don't have a warranty seal from the seller, I don't know how to rate this purchase ...
The discussion centers around selecting an effective ultrasonic cleaner for cleaning phone and laptop motherboards. The CD-4820 model is recommended for its balance of price, tank capacity, and power, featuring a 2.5L tank and heating capabilities to enhance cleaning efficiency through increased cavitation. Users emphasize the importance of using isopropyl alcohol or its derivatives for optimal cleaning results, particularly for removing soldering flux and contaminants. Concerns about product reliability and warranty issues are also raised, with one user experiencing initial malfunction but later receiving a functional replacement. Overall, the CD-4820 is noted for its effectiveness in cleaning electronics, although some users report durability issues with the basket.
TL;DR: For phone boards, a 2.5 L tank (245×145×70 mm) like the CD‑4820 works well; “heating intensifies cavitation.” [Elektroda, Godziks, post #16658205]
Why it matters: This FAQ helps repair techs choose a cleaner, liquids, and settings to safely wash phone and laptop motherboards.
What’s the best ultrasonic cleaner for phone motherboards right now?
A proven budget‑friendly choice is the CD‑4820. It offers a 2.5 L tank, heater, and enough space for phone PCBs. Users report solid results washing electronics with IPA. Heating the bath improves cleaning by intensifying cavitation. It balances price, power, and capacity for small boards. [Elektroda, Godziks, post #16658205]
Will a 2.5 L tank actually fit phone logic boards?
Yes. The CD‑4820 tank measures 245×145×70 mm. That footprint accommodates typical phone motherboards without diagonally forcing the board. Technicians report it “will definitely wash all your phone’s motherboards.” Use the basket to avoid parts contacting the tank. [Elektroda, Godziks, post #16658205]
What should I buy for laptop motherboards—what size and budget?
Choose strictly by tank size for laptops. Larger boards need bigger, deeper tanks, which raises price. Expect to exceed entry budgets; sub‑PLN 1000 solutions are not sufficient for full laptop boards. Measure the board and compare against tank dimensions before purchase. [Elektroda, Jawi_P, post #16658358]
Which liquid is safest: IPA, K3, or DEMA?
Use isopropyl alcohol (and derivatives like Cleanser Druk) for electronics. These dissolve rosin flux and typical post‑solder residues. K3 and DEMA are water‑mix concentrates aimed at general or mechanical parts; K3 includes a corrosion inhibitor. For PCBs, IPA remains the default. [Elektroda, Godziks, post #16658292]
Do I replace the IPA after every board?
No. Keep IPA in the tub and cover it to limit evaporation, especially when heating. Replace only when the fluid looks dirty or cleaning results drop. This practice cuts waste and keeps throughput high during service days. “Cover the tub with a cover from the set.” [Elektroda, Godziks, post #16658292]
Does heating the bath really improve cleaning?
Yes. Heating strengthens cavitation, which boosts particle removal from tight gaps. As an expert put it, “An increase in temperature causes the phenomenon to intensify,” translating to better wash efficiency. Monitor flammability guidance when heating IPA and keep ventilation adequate. [Elektroda, Godziks, post #16658205]
How do I wash a flooded phone board safely?
Technicians in GSM service wash flooded boards with IPA in an ultrasonic bath. After the cycle, allow thorough drying before power‑up. Use the basket to protect components and avoid prolonged dwell times. Verify connectors and shields are dry before reassembly. [Elektroda, Godziks, post #16658292]
What if my ultrasonic cleaner arrives dead on arrival (DOA)?
It happens. One user’s unit only blinked once and failed, but the seller replaced it and confirmed operation before return shipment. Always test on arrival and keep paperwork for fast exchanges. This edge case underlines why vendor support matters. [Elektroda, wentyl215, post #16675353]
Are there durability issues with the CD‑4820?
Watch the basket ears and hinges. A user reported cracked ears under normal use. Avoid overloading heavy parts and handle the basket gently. If the basket weakens, replace it early to prevent debris or part contact with the tank. [Elektroda, wentyl215, post #16713860]
Do I need to worry about warranty seals or documentation?
One replacement unit arrived without a warranty seal, though the first had one. Keep invoices and correspondence, and verify the seller’s warranty process. Test performance within the return window to catch faults early. [Elektroda, wentyl215, post #16675353]
How much IPA will I need to fill a typical small tank?
A 2.5 L tank like the CD‑4820 needs roughly 2.5 liters to reach the working level. Do not drain it after each board; cover it between sessions and refresh when dirty. This keeps costs predictable across multiple jobs. [Elektroda, Godziks, post #16658205]
What is cavitation in ultrasonic cleaning?
Cavitation is the rapid formation and collapse of microscopic bubbles from ultrasonic waves. The collapses dislodge soils from surfaces and gaps. Heating the bath intensifies cavitation and improves cleaning efficiency on dense PCB assemblies. [Elektroda, Godziks, post #16658205]
Can I use water‑based concentrates on electronics if I lack IPA?
They are general‑purpose and specified for some electronics, but the forum experience favors IPA for PCB flux and contamination. If you use K3/DEMA, dilute with distilled water and dry thoroughly to avoid residues or corrosion. [Elektroda, Godziks, post #16658292]
What’s a simple, safe workflow to clean a phone PCB?
Try this: 1. Fill tank with IPA, place PCB in basket. 2. Run a short heated cycle; watch for loosened debris. 3. Remove, air‑dry fully before testing. “Friends from GSM services clean phones with this liquid mainly after flooding.” [Elektroda, Godziks, post #16658292]
