How to Accurately Measure Computer Power Supply Voltage with UNI-T M890G Meter Safely
Xylometazolin! 185858 3
  • How to measure voltage with a meter?
    This type of question is often asked in the forum. Therefore, I will try to explain how to measure voltages in a computer power supply so that the readings are the most accurate, and the measurement itself is safe for us.
    1. Preparation of the necessary equipment for measurement.
    Personally, I will use the UNI-T M890G meter.
    BATTERY - if our meter is powered by a battery, we should make sure that it is charged and fully functional - this will avoid measurement errors.
    MEASUREMENT RANGE - the next step is to set the appropriate measuring range - in this case, set it to DCV 20 (direct current voltage, range up to 20V).
    MEASUREMENT PROBES - whether our reading will be accurate also depends on the cleanliness of the measuring probes. Make sure that there is no deposit, grease or other types of dirt on them. It is best to degrease the probes beforehand, e.g. with alcohol or acetone.
    If everything is ready, we can move on to point 2.
    2. Performing the measurement.
    Voltage measurement on + 12V and + 5V lines with a MOLEX plug.
    We find a MOLEX plug (we use it to connect, among others, drives, hard drives, etc.)
    + 5V
    We put the probes in the same way as in the attached photo - the black probe to the place where the black wire is located and the red probe is to be found in the red wire. We read the measurement.
    + 12V
    The probes are inserted as follows: black to the black wire, and red to the yellow wire. We read the measurement.
    Voltage measurement on the + 3.3V, + 5V and + 12V lines using a 20/24 PIN plug and a 4 PIN plug.
    20/24 PIN socket:
    4 PIN socket:
    + 3.3V
    In the 20/24 PIN plug we have to find two wires - orange and black.
    We put the red probe to the contact of the orange wire, and the black probe - to the black one (as shown in the pictures). We read the measurement.
    + 12V
    We find the 4 PIN socket. Put the red probe to the contact point of the yellow wire, and the black probe to the black contact. We read the measurement.
    + 5V SB, also marked as +5 VCCH
    We perform in two states:
    1. When plugging the power adapter into the mains, but the computer is not yet running.
    2. After turning on the computer with the POWER button and starting all components of the computer.
    Place the multimeter (meter) probes as shown in the picture below, i.e. the red probe placed in the place of the plug marked with color purple and the black one applied to any color-coded pin black .
    The voltage is very important as it allows the PC to boot properly.
    In addition, in some boards there is a voltage that also supplies USB ports, so its stability and value largely depend on the correct operation of each device connected to this port.
    The difference between the state 1 , that is, connecting the power supply to the network, and the state of 2 . that is, an already running computer should be the same and should not change significantly during operation.
    The measured value must be within +/- 5% of the nominal voltage value, i.e. (4.75-5.25) V
    + 5V PG also marked as Power Good or Power_OK
    It is the necessary voltage for the proper operation of the power supply connected to the motherboard during normal use.
    In the event that this voltage is insufficient or very unstable and exceeds the values contained in the ATX standard, stable operation on the computer will be impossible. This will be manifested by turning off the power supply, incorrect startup of the computer or resetting the system.
    We perform it immediately after turning on the computer with the POWER button.
    Place the red probe in the ATX plug in the pin marked with the color gray , be light green and the black probe should be placed in any pin marked with a color black like in the picture below:
    The measured value must be within +/- 5% of the nominal voltage value, i.e. (4.75-5.25) V.
    3. What should the correct voltages look like?
    The table below shows what the tensions should look like on individual lines:
    4. Finally ...
    Finally, I would like to add that we measure the voltages with the computer turned on. It is best to measure 2 times:
    while the computer is idle - that is, we turn off all applications and then we measure.
    while the computer is under load - that is, we turn on demanding applications, e.g. GAMES, Orthos (computer-intensive application; it works on max 2 cores, so if your processor has more of them - use two parallel running Orthos, select the appropriate cores for each of the programs and then test).
    And why do we measure voltages with a meter and not programmatically?
    The answer is there HERE.
    Thanks to a friend spruce for help in developing and implementing the thread.
    Prohibition of copying without the consent of the author.
    • Jak mierzyć napięcia miernikiem.pdf (640.73 KB) You must be logged in to download this attachment.
    Xylometazolin!
    Xylometazolin! wrote 6834 posts with rating 857, helped 264 times. Live in city Górny Śląsk. Been with us since 2006 year.
  • #2 6348749
    tzok
    Help: 3175
    Rate: 6546
    ... I would like to add that it is not worth exaggerating with the precision of giving the measurement results, and that the software measurement is not always that bad:
     How to Accurately Measure Computer Power Supply Voltage with UNI-T M890G Meter Safely  How to Accurately Measure Computer Power Supply Voltage with UNI-T M890G Meter Safely
    In addition, the "yolk" shows what is happening when the battery in the meter is low (although the indicator does not signal it yet).
  • #3 9626367
    phaker92
    Rate: 11
    Hello. It can be very dangerous to measure the voltage on a USB port by itself. You can easily make a short circuit and damage the motherboard. I suggest you prepare a suitable cable. You take a USB cable and cut it in half. There are 4 wires inside: Red, Black, White, and Green. The red wire is connected to the red wire of the meter and the black wire to the black one, the rest is trimmed and nicely insulated so that it does not short circuit you. You set the meter to the 20V range and you can measure the voltage on the USB ports. I attach a drawing with a description of the pins on the USB.
    Regards.
  • #4 11037432
    Yansen
    Help: 44
    Everything is nice and beautiful, but such measurements using popular meters are not real. This is due to the delay of the meter - the number of measurements per second.
    To check computer power supplies, I use a specialized meter that shows all the power supply voltages with a high refresh rate at once with a percentage trap causing an alarm, on which you can only see that the voltages are floating and this affects the computer freezes, spontaneous resets, etc. When measuring with a popular multimeter, it is not possible to notice such deviations due to the delay of the meter. Even though the meter shows 3.3V, it does not mean that it is so all the time. A microsecond drop in this voltage causes the platform to become unstable.
    There are many ways to measure, but two are important:
    - measurement on the living organism: a meter of all voltages connected between the power supply and the computer,
    - measurement of the power supply itself with the use of an adjustable set of loads on all power sections: you can quickly and painlessly check whether the 500W power supply is actually 500W.
    In view of the above, I call the postulated measurement of voltages at the molex terminal or port terminal only and only checking whether there is voltage.
