Dishwasher Salt: Ideal Amount to Add, Dissolving in Warm/Cold Water, Red Indicator
12daniel 50685 3
  • #1 6061659
    12daniel
    Rate: 17
    Hello, I have a question, it shows me in red about the lack of salt, how much salt should I put in, or whether I should add warm water to the tank or whether the salt will dissolve in the cold one
  • #2 6061815
  • #3 6062003
    12daniel
    Rate: 17
    honey g595
  • #4 6063374
    Jasxx
    Help: 27
    Rate: 328
    You sprinkle the entire reservoir. When it is first run, you add water, not necessarily hot. Otherwise, the water is already in the tank.
    Full tank - it depends on the model and manufacturer. Usually it is 1 - 1.5 kg.
