Beko DIS5831 Dishwasher: Water Intake Issue & Salt Tank Full, Built-in Appliance Solutions
soczek0071 6738 3
  • #1 16196306
    soczek0071
    I have a problem with the Beko DIS 5831 dishwasher. I have stopped drinking water for some time.
    In addition, I do not know if it should be like that, but in the tank where I pour salt, there is always plenty of water.
    The dishwasher is built in furniture. Can you do something about it without getting it out?
    I live on a rented apartment and I would not like to spoil something, and the owners are 1000km away and they apologize for ...
    Regards
  • #2 16196474
    tod.1977
    Help: 65
    Rate: 150
    Hello. You have a friend at least access to the tap where is the water supply to the dishwasher connected? There, something could clog or scale or the solenoid valve on the water supply to the device has been damaged.
  • #3 16196683
    soczek0071
    Thank you for your response.
    Yes, I have access to the tap. I will look at it today :)
    I searched the internet a little bit and in some cases people had a float suspended.
    Is there a chance in my situation that something like this could happen?
    Regards
  • #4 16196765
    tod.1977
    Help: 65
    Rate: 150
    A colleague probably means by the float the anti-flood switch activated with a styrofoam float. This could also happen, but then the drain pump in the dishwasher should start and if this does not happen then the previously described faults may take place.
