[Solved] Beko DFN26420W dishwasher - shows no salt despite filling the tank
Jolka1505 35505 4
  • #1 18461329
    Jolka1505
    Rate: 19
    Hello sincerely,
    I bought my first dishwasher and I have this problem. All the time the lack of salt light is lit, despite the fact that I poured it into the tank as it was in the instructions. Salt admittedly bought in the market, but I do not think that is the cause. I tried stirring with a spoon also did not help.... Normally there is salt you can feel the crystals with a spoon and the light is on. Can you help?
  • #2 18461378
    marcin1171
    Help: 21
    Rate: 36
    Maybe there is still not enough salt after all. I also encountered that some dishwashers, when plugged in, overcome the lack of salt despite a full tank. However, after the first full cycle, the light went out. After unplugging and plugging back in, the situation repeated itself.
  • #3 18461715
    zhudomel
    Home appliances specialist
    Help: 1280
    Rate: 3368
    Jolka1505 wrote:
    All the time the no salt light is on even though I poured it into the tank as per the instructions.
    Full? Made with 2 washes?
  • #4 18462126
    Jolka1505
    Rate: 19
    zhudomel wrote:
    Jolka1505 wrote:
    All the time the no-salt light is on even though I have poured salt into the tank as per the instructions.
    Full? Done with 2 washes?
    Full even more than two.... It washes beautifully only this light is on all the time.
    marcin1171 wrote:
    Maybe the salt is still not enough though. I have also encountered that some dishwashers, when plugged in, overcome the lack of salt despite a full reservoir. However, after the first full cycle, the light went out. After unplugging and plugging it back in, the situation repeated itself.
    So try unplugging it and plugging it back in?
  • #5 18468027
    Jolka1505
    Rate: 19
    It turned out that most likely some of this salt must have dissolved. The indicator light went out the dishwasher runs as expected topic closed
    Added after 1 [minute]:
    It turned out that most likely must have dissolved some of this salt.... In any case, the light went out dishwasher is running as expected topic closed
