Understanding BIOS Beep Codes: Award, Phoenix Award, and AMI - Diagnosing Memory, CPU & GPU Errors
Mery84 304782 0
  • Each motherboard signals it with a sound signal in case of problems.
    How to read this signal and what does it mean?
    BIOS AWARD and PHOENIX AWARD
    1 short - all right.
    1 long - memory error
    1 long, 2 short - RAM parity error
    1 long 2 short - graphics card error
    1 long 3 short - video card memory error or lack thereof
    Repeated - RAM error
    Variable low and high - processor error
    While the computer is working - overheating of the processor
    BIOS AMI
    3 short - error in the first 64KB of RAM
    4 short - error in the system clock or the first memory pin
    5 short - processor error
    6 short - keyboard controller error
    7 short - virtual processor mode error
    8 short - video card memory I / O error
    9 short - BIOS checksum error
    10 short - CMOS memory I / O register error
    11 short - processor L2 cache error
    1 long, 2 short - graphics card error
    1 long 3 short - RAM memory error
    1 long 8 short - problems with displaying the image by the graphics card
    Continuous sound - no RAM or video card
    BIOS PHOENIX (the word of explanation, e.g. 1-2-1 means that there was one beep then there was a pause two beeps in turn, then a pause and one beep)
    1-1-2 - CPU error or when low tone motherboard error
    1-1-3 / 4-2-2 - CMOS memory error
    1-1-4 - RAM parity error
    1-2-1 - system clock error
    1-2-2 - DMA controller error
    1-2-3 - DMA controller error
    1-3-1 - error related to refreshing RAM
    1-3-2 - RA memory test error
    1-3-3 - error in the first RAM pin
    1-3-4 - RAM parity error in the first 64 KB
    1-4-1 - memory address line error
    1-4-2 - RAM parity error
    1-4-3 / 1-4-4 - EISA bus error
    2-xx - RAM memory error
    3-1-1 - DMA controller error (Slave)
    3-1-2 - DMA controller error (Master)
    3-1-3 - interrupt controller error (Master)
    3-1-4 - interrupt controller error (Slave)
    3-2-4 - keyboard controller error
    3-3-1 - CMOS battery has run out
    3-3-2 - CMOS memory error
    3-3-4 - video card error
    3-4-1 - video card error
    4-2-1 - system clock error
    4-2-3 - no connection with the keyboard
    4-2-4 - CPU test aborted
    4-3-1 - error during RAM test
    4-3-3- system clock error
    4-3-4 - real time clock error
    4-4-1 - serial port error
    4-4-2 - parallel port error
    4-4-3 - processor error
    The following page may also be helpful in identifying:
    http://www.bioscentral.com/
    • BIOS Beep Code - czyli sygnały dźwiękowe BIOS.pdf (33.26 KB) You must be logged in to download this attachment.
    Mery84
    Mery84 wrote 7034 posts with rating 271, helped 427 times. Live in city Chorzów. Been with us since 2006 year.
