Choosing a PLC for home automation: Moeller XN-PLC XI/ON or Siemens Simatic?
darekas 36251 63
Which PLC should I choose for a cost-sensitive home automation system with about 99 inputs and 144 outputs: Moeller XN-PLC XI/ON or Siemens Simatic?
For your star-wired house with 99 inputs and 144 outputs, a distributed Moeller-style system looks like the better fit than a single Siemens Simatic CPU, but you should price the whole system before deciding [#6296091][#6561216] The key specs to compare are cycle time, I/O response time, maximum inputs/outputs or modules, memory, floating-point support, variable forcing, and the available serial/Ethernet ports and protocols [#6263236] Moeller/XC200 or Easy Control were praised for decentralisation, CoDeSys programming, Ethernet, and even a built-in web server on some models, which makes them easier to learn and adapt for home automation [#6191764][#6296091] Siemens S7-200/S7-300 can also work, but the software is different between the two families and the hidden cost of modules and adapters can make the total price higher than expected [#6189738][#6190195][#6285751] Several posters therefore advised getting quotes for complete configurations and also checking cheaper alternatives like Fatek, Beckhoff, or WAGO if price is the main constraint [#6252994][#6230232][#6580319]
  • #1 6189460
    darekas
    Rate: 17
    Please help a layman who, against all odds, is determined to install a smart home system in his newly built house – which PLC controller should he choose?
    Unfortunately, cost is a factor, so I couldn’t afford EIB-type systems; instead, the idea arose to build the home automation system using a PLC controller.
    I have the entire installation wired in a star configuration. I’ve ended up with quite a lot of inputs and outputs – I have 99 inputs and 144 outputs.
    I’m wondering which would be the better solution: the Moeller system or Siemens Simatic
    By Moeller, I mean a distributed XI/ON system like the one here
    XN-PLC XI/ON
    The arguments in favour of Moeller are the greater number of useful communication protocols, particularly Ethernet as standard, the ability to build a decentralised system, and the availability of sample applications, which is important to me because I want to learn the basics of programming so that I can programme the system myself.
    On the other hand, Siemens’ Symatic is attractive to me because there is a fairly large second-hand market, e.g. on Allegro, so it might be cheaper. On the other hand, everyone is warning me against Siemens – where the costs will be highest.
    So the most important criterion when choosing is price, followed by functionality and ease of programming.
    There is also Wago, but I am completely unfamiliar with that system.
    I would be grateful for any suggestions.
  • #2 6189738
    shadoweyes
    Help: 26
    Rate: 27
    I would recommend the Siemens S7-200 series or using a PC with the relevant software and a card as a SoftPLC (which may be cheaper).
    There are plenty of expansion modules available for the S7-200 series, and it can be integrated with LOGO or the S7-300 series should the system need to be expanded. You could also consider the Siemens-clone VIPA 100V/200V/300V controllers (http://www.sds-automatyka.pl/?site=126).
  • #3 6189854
    darekas
    Rate: 17
    shadoweyes wrote:
    I would recommend the Siemens S7-200 series or using a PC with software and a card as a SoftPLC (which may be cheaper).
    There are plenty of add-on modules for the S7-200 series, and it can be integrated with LOGO or the S7-300 series should you need to expand the system. You could also consider the Siemens clones, the VIPA 100V /200V/300V controllers ( http://www.sds-automatyka.pl/?site=126 ).
    Actually, I’m thinking the same thing – I’ll buy the cheapest starter kit
    I’ll then have the genuine S7-200 software, and I’ll buy the rest of the modules second-hand – that might work out cheaper.
    I’m just not sure if the S7-300 is programmed using the same software as the S7-200
    But will it turn out that, in the end, Siemens ends up being more expensive than a Moeller bought new?
    There’s a company near Warsaw that does smart installations for detached houses using Moeller’s XI/ON or Wago, and they warn against the costs of Siemens’ Simatic
  • #4 6190195
    shadoweyes
    Help: 26
    Rate: 27
    The S7-300 is programmed using different software to the S7-200, and the two are not compatible. From what I’ve heard, VIPA controllers are cheaper and come with free programming software. Companies often recommend controllers they are more familiar with. It’s best to check for yourself and get quotes for Siemens and Moeller, then compare them in terms of price and capabilities, as well as any future system expansion needs.
  • #5 6190409
    andrzejek23
    Level 19  
    Help: 21
    Rate: 146
    Beckhoff. Much cheaper, built-in Ethernet, support for distributed I/O over Ethernet, free software and a building automation library available (unnecessary for a detached house).
    On a separate note, I consider the use of PLCs and other complex building automation systems in detached houses to be an unnecessary expense.
  • #6 6191096
    grudziu
    Help: 14
    Rate: 14
    Wago currently has a promotion on a starter kit with a KNX bus, so you’d have a versatile and affordable solution
    500 E including software, KNX input/output modules, a KNX-IP master controller, a power supply, and a programming cable – so it’s definitely the best deal available right now.
    You program using CodeSys, so it’s a universal language
  • #7 6191544
    gacolini
    Level 19  
    Help: 36
    Rate: 15
    I would also recommend Wago or Beckhoff controllers, which are ideal for such applications, and CoDeSys, which is a very user-friendly programming environment.
  • #8 6191764
    falowniki.com
    Power inverters specialist
    Help: 86
    Rate: 134
    All of the above are programmed using CoDeSys; Moeller controllers are supported by the Polish version of CoDeSys ...
    Additionally: the XC200 has a built-in web server which handles visualisation and the programming of home settings via a standard web browser...
    Good luck
  • #9 6194779
    darekas
    Rate: 17
    Thank you for all the replies so far :)
    Beckhoff is actually the same product as Wago, just a different name
    And how does it compare price-wise? Is it similar, or do you have to pay extra for the Wago name
    Added after 4 [minutes]:
    falowniki.com wrote:
    gacolini wrote:
    I would also recommend Wago or Beckhoff controllers, which are ideal for such applications, and CoDeSys, a very user-friendly programming environment.
    Good luck
    However, the XC200 is very expensive; if I’m not mistaken, the price starts at 5,000 PLN
    Added after 6 [minutes]:
    andrzejek23 wrote:
    On a side note, I consider the use of PLCs and other complex building automation systems in detached houses to be an unnecessary expense.
    I also had similar doubts about whether it was worth it, but now it’s too late – I have to
    get the system up and running somehow.
    I hope the PLC controller will help me automate certain tasks, and I’ve got plenty of ideas in mind
    grudziu wrote:
    Wago currently has a promotion on a starter kit with a KNX bus, so you’d have a versatile and inexpensive solution
    I just don’t know how to use KNX with Wago because my installation is star-shaped. Would I need to run an additional EIB-Bus?
    And I’d still be dependent on the company that has the KNX programming software.
    Please correct me if I’m wrong
  • #10 6194945
    falowniki.com
    Help: 86
    Rate: 134
    The smallest unit in the XC200 series can be purchased for around 2,500 PLN (excl. VAT)...
    or alternatively use the easyControl controller (also CoDeSys-programmable and with an Ethernet option)
    you can also use the XC100 via CANopen to connect to a 5" touchscreen operator panel and from the panel via FTP to a PC
    Let me know the maximum you’d like to invest (I know you want to keep it as low as possible :)
    and we’ll find something suitable...
    Best regards
  • #11 6195173
    darekas
    Rate: 17
    Let me know the maximum you’d like to invest (I know it should be as little as possible :)
    Best regards
    So perhaps let’s start with how many inputs and outputs I have
    I’ve been playing around with the setup a bit and it turns out I need a controller for 96 inputs and 144 outputs.
    Or rather, that’s how many I have, but if it ends up costing a horrendous amount, I don’t need to control everything
    How should I factor in the cost of building the control cabinet – i.e. controllers, relays, load cells, etc.?
    the smallest unit in the XC200 series can be bought for around 2,500 PLN net...
    BTW, where can you buy it at that price? :D
    How much might a Wago starter kit like this cost
    http://www.wago.com/cps/rde/xchg/SID-53EFFEF9-1D366A95/wago/style.xsl/plk-2078.htm" target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > Wago starter kit
    I can’t find the price online at the moment
  • #12 6196317
    grudziu
    Help: 14
    Rate: 14
    Nie wiem tylko jak wykorzystać KNX w Wago bo mam instalację położoną w gwiazdę. Czy musiał być dodatkowo ciągnąć magistralę EIB-Bus.
    No i cały czas jestem uzależniony od firmy która ma program do programowania KNX.
    Firstly, generally speaking, KNX = EIB, so I will use these terms interchangeably.
    Secondly, the EIB bus can be star-shaped or linear – any configuration (except closed loops)
    Thirdly, there is only one ETS programme for devices from all manufacturers, whether Siemens, ABB, Gira, Berker or others (Wago has also released an ETS plugin for its devices). You download the vd1-vd5 files from the manufacturers’ websites and the device is immediately visible in ETS
    fourthly, ETS sometimes costs €500, sometimes €1000 (depending on promotions), but the 30-day demo version can programme up to 20 devices.
    Fifthly, look for a version of ETS better than the demo :)
    Sixthly – you don’t need to attend a KNX Partner course to learn KNX. Once you’ve chosen a manufacturer, check whether they’re flexible in providing training or demonstrating how to programme devices and what the process involves.
    Seventhly – you can always contact me regarding KNX programming :) or many other companies. With CodeSys, you can give me a go; I’m not an expert, but I’ve programmed a few things and even done some integration.
    With other standards, especially proprietary ones, you might struggle to find the right person.
    vbass [at] vbass . pl
  • #13 6196498
    darekas
    Rate: 17
    grudziu wrote:
    [code]
    Firstly, broadly speaking, KNX = EIB, so I will use these terms interchangeably.
    Sure, I know
    grudziu wrote:
    Fourthly, ETS sometimes costs €500, sometimes €1000 (depending on promotions), but the 30-day demo version can programme up to 20 devices.
    Fifthly, look for a version of ETS that’s better than the demo :)
    I’m interested in this better version; where can I find such better versions? :D
    Why not? Please send me more information via private message
  • #14 6197307
    shadoweyes
    Help: 26
    Rate: 27
    As I mentioned, you can control the system from a PC, and it doesn’t have to be the latest model. You can buy EIB software and a modem for your PC (or make one yourself); you can use Ethernet modules as inputs/outputs. You can also control it wirelessly using WiFi or ZigBee modules. And I think this is much cheaper than a standard PLC controller. And it’s certainly a more cost-effective solution.
  • #15 6198898
    darekas
    Rate: 17
    Does anyone know how much the Wago starter kits cost? I can't find a price list anywhere.
  • #16 6209906
    darekas
    Rate: 17
    up, up
    Is no one else going to share their thoughts on PLC controllers?
  • #18 6229571
    PavvelB
    Have you looked at the Fatek PLC? I’m currently considering using it for my building automation system.
  • #19 6230232
    shadoweyes
    Help: 26
    Rate: 27
    It seems to me that the best approach to building automation is to base it on distributed systems, which improves its reliability. In such systems, we do not need a large, powerful, complex and significantly more expensive PLC. We can use smaller units that exchange the most important information with each other via a ‘network’ but also operate independently of one another. Today, you can buy I/O modules that operate over a network (RS485, EIB, Ethernet, Wi-Fi or ZigBee, etc.) that are compatible with any PLC or PC (SoftPLC). This allows such a module to be installed right next to the actuator, which reduces the installation costs of the entire system and enables its expansion as required.
  • #20 6230834
    grudziu
    Help: 14
    Rate: 14
    I agree with these words.
    Firstly, a distributed or multi-master network with some local expansion modules.
    And secondly – if, for example, there is dimmable lighting and we want to dim or brighten it alternately by holding down a button for a long time, doing this via a PLC is not such a simple task. The same applies, for example, to a so-called lighting ‘scene’ (scenario) and saving the current state by holding down a button for a long time and assigning that state to a particular scene. You’ll need to come up with a bit of a non-standard programme.
  • #21 6231012
    andrzejek23
    Level 19  
    Help: 21
    Rate: 146
    What's so difficult about that? Both dimming and brightening with a single button by holding it down for a few seconds is a job that takes five minutes. In general, I think that programming a PLC for a small building is a relatively simple matter, unlike industrial automation.
  • #22 6231043
    darekas
    Rate: 17
    shadoweyes wrote:
    Visit http://www.automatyka.com.pl/ , http://www.automatykab2b.pl/ and Astor. There you’ll find distributors of various controllers and automation solutions, as well as training materials and articles – perhaps something will be useful.
    I’ve already looked through almost everything, or at least what’s on Polish websites; nevertheless, I’m asking because I want to hear the pros and cons of a specific PLC from people who know PLCs well
    Added after 8 [minutes]:
    Muliprojekt, which offers the Fatek controller, also has dimmers in its range
    Fatek dimmers
    And what do you think of this controller anyway? It’s very popular on the Murator forum, for example
    Fatek controller
    andrzejek23 wrote:
    What’s so difficult about that? Both dimming and brightening with a single button by holding it down for longer is a function that takes five minutes to implement. In general, I think that programming a PLC for a small building is a relatively simple matter, unlike industrial automation.
    And is it possible to program a PLC controller in this way?
    The absence of occupants in a given room causes the TV to switch off
    In other words, if the motion detector does not detect any movement in the room for a period of, say, 60 minutes, the power supply to the socket is cut off and the TV is switched off.
    Re-entering the room restores power to that socket, allowing the TV to be switched on later using the remote control
    A rather silly idea for children and a TV that plays 24 hours a day.
  • #23 6231314
    shadoweyes
    Help: 26
    Rate: 27
    Everything can be done. Although some things you have to make yourself or adapt existing items so that they meet your requirements.
  • #24 6232801
    grudziu
    Help: 14
    Rate: 14
    You know, I’m writing partly from my own experience, which is different from controlling the whole system with a single controller. I’ve integrated PLCs into EIB or LON networks. It was necessary to develop quite a substantial section of code to ensure it worked in accordance with those communication standards.
    And how many buildings have you commissioned using PLC-based building automation?
  • #25 6235471
    shadoweyes
    Help: 26
    Rate: 27
    To do everything on a single PLC, you’d need a ‘powerhouse’. And whether industrial automation is more complex is a relative concept. There are smart building systems that are more complex than many industrial automation setups. In any case, when browsing websites on industrial automation and smart buildings, manufacturers tend to favour distributed systems rather than a single PLC controller.
  • #26 6237510
    szczupx
    Level 19  
    Help: 29
    Rate: 94
    I haven’t read the whole thread out of laziness, but I’ll put in my two cents: before deciding on the system architecture, check whether the chosen controller will be able to handle all the I/O (and a few spares for the future).
    99 + 144 = A LOT!
  • #27 6249425
    neuron
    See halla2007 - http://neuron.com.pl/hall2007.html
    It could be the perfect addition to a PLC-based system, although at the moment it only communicates with Hallchip processors.
    Wojtek
  • #28 6250369
    adner
    I recommend Siemens.
    Depending on the size of the installation, go for the S7-200 or S7-300 series. Unfortunately, you’ll need various software packages, but you can find everything online :-) – demo versions, of course.
    You can also buy a starter kit quite cheaply.
  • #29 6252994
    TJordan
    I also recommend Fatek. It’s free software, very easy to program via an RS232 cable or a standard USB cable (for the MCU version). Distributor’s technical support: www.multiprojekt.pl. There’s no need to buy expensive PPI or MPI adapters, as is the case with Siemens.
    I have already run quite a few applications on this hardware, which operates stably and reliably in truly extreme conditions (concrete plants).
    So I can recommend this controller with a clear conscience; add a Weintek panel to that and you have a truly professional building automation system.
    To give you an idea of the cost:
    FBS-20 MC controller, 12 inputs, 8 outputs – approx. 250 USD
    FBS-24 EX module, 24 inputs – approx. 100 USD (4 units will give 108 inputs)
    FBS-24 EYT module, 24 outputs – approx. 100 USD (6 units will give 152 outputs)
    FBS-CBE module, Ethernet – approx. 110 USD
  • #30 6253039
    darekas
    Rate: 17
    It could be an excellent addition to a PLC-based system, although for the moment it only communicates with Hallchip processors.
    wojtek
    I’ve seen this solution, but I’m not quite sure how to use it and integrate it with a PLC controller
