Changing COM Ports on IBM Laptop: VAG-USB Car Computer ABS Error, Setting COM1-COM4 Range
lange13 76802 5
  • #1 6207824
    lange13
    Rate: 10
    Hello, I recently bought a VAG-USB for a car computer to remove the ABS error, unfortunately for the program to work and for me to do anything, I need to have the com1 - com4 port set in my laptop and for me in IBM they are from com7-com15 how should I add or change them on com1 to make this plug work via usb
  • #2 6214975
    lange13
    Rate: 10
    ... maybe you need to bury it in Bios, but where to find it? please any help
  • #3 6342185
    DarekTDA
    Rate: 18
    Hello, you still have a problem with that COM port?
  • #4 6347440
    mala1985
    Rate: 17
    After successful installation, shut down and restart
    computer. The next step is to check if our drivers are visible in the system
    and which COM port is installed. This is of great importance because on
    example: VagCom program designed for car diagnostics in its
    the menu has the option of using one of the four COM ports. Then
    If you want to use VagCom, select the appropriate COM port number.
    The assigned COM port number is in the system. Therefore, we click on
    the START tab, located in the lower left corner of our screen, and then
    go to the Control Panel tab. When in the "control panel", find and click on the tab
    System, After a while, a window will appear: "System properties", then click on
    Hardware tab and then Device Manager. Being in the "Device Manager" tab, expand the submenu
    the following tabs:
    1) Tu universal serial bus controllers
    there should be a tab of our installed USB driver o
    name: USB High Speed Serial Converter. 2) Ports (COM and LPT). Our tab should be here
    installed COM driver with assigned port number named:
    USB Serial Port (COM3). It goes without saying that the assigned COM port number may be different from
    discussed above, ie COM3. The selection is made by the system itself during installation
    drivers and assigns the lowest number of free ports to the COM port
    COM. So if on the list (see photo above) we can see that our COM port has
    assigned number three or four (COM3 or COM4), then everything is in
    okay. Please note that the same port must be set in the program
    diagnostic tool, in this case VagCom.
    However, if the COM port is assigned a higher number, e.g. COM5,
    it means that it is not possible to set such in the diagnostic program
    COM port (COM5 and above). We can then set it up in our system and
    assign it a number three or four (COM3 or COM4). To do this, click
    right click on the tab: USB Serial Port (COM3) and select
    properties / port settings tab / advanced tab - here we are setting
    desired port number. For this purpose, we expand the COMx window. Then they will be punished
    all COM ports, i.e. those that are already assigned a number and free ports, to
    use
  • #5 6347859
  • #6 6471569
    lange13
    Rate: 10
    hello, after a long break, I added a new com2 port, but I still couldn't connect to the car computer. The problem is still with the driver, I installed the program attached to the cable and the tab in the manager called USB High Speed Serial Converter did not appear. Maybe because I have a viste. I do not see a window with the exact properties of the port as in the picture of Marcin230
