  • #1 6261972
    szeri88
    Help: 11
    I have a question, is it possible to transport fuel in canisters by passenger car? From what I remember, during the driving course they mentioned that fuel can only be stored in metal tanks. Is there any regulation limiting the amount of fuel transported out of the tank?
    Regards
  • #2 6262031
    orzelpiotr
    Help: 238
    Rate: 164
    [DU 2004 / item 675]
    2. The import by a natural person, in any quantity, of motor fuels, heating oils or liquefied petroleum gas with excise duty paid on the territory of a Member State indicates that these products are intended for commercial purposes, if these products are transported by non-standard means of transport.
    3. Unusual type of transport means:
    1) transport of motor fuels, other than in the fuel tanks of motor vehicles, permanently installed by the manufacturer in all motor vehicles, which allow for direct use of fuel for the propulsion of a motor vehicle or adapted for motor vehicles, allowing for the direct use of gas as fuel, or in suitable spare containers (canisters) containing motor fuels intended for consumption in these vehicles, w
    a quantity not exceeding 10 liters;
    2) transport of heating oils or liquefied gas, other than by tankers used by entrepreneurs engaged in the transport of these products, as part of their business activities.
    You can carry up to 10 liters, but not everywhere in Greece, Great Britain Italy, for example, prohibits transport even in canisters.
  • #3 6262990
    arekb81
    Help: 135
    Rate: 746
    Nobody will find fault with carrying fuel in one or two canisters (the police). More may raise suspicions as to the legality of its origin, or a police officer may consider it a safety risk in the event of an accident, but it depends on who will control our car. Limitations on the amount outside the tank are certainly on the borders, including with Russia. As for plastic canisters, they are everywhere at stations and in supermarkets. They used to be made of a different material. The gasoline sloshing in the canister caused the formation of electrostatic charges. A possible flashover could cause an explosion.
  • #4 15848540
  • #5 15850750
    helmud7543
    Help: 1216
    Rate: 1564
    How tight it is almost full. Not quite up to the cork - because the heat and pressure will increase, so leave some space. Not too little - because fuel vapors mixed with air are explosive. The larger the space, the greater the force of the explosion if something. Gasoline itself, as a liquid, is non-flammable. If you break the canister and it spills, the fumes can catch fire from a spark (short circuit in an accident) or hot elements (I don't know - the exhaust system).
    In the case of a forward or side impact, when the canister is in the trunk, the risk is negligible, if the trunk and the canister (and probably the fuel tank) are damaged, it is worse.
  • #6 15850842
    kortyleski
    Help: 957
    Rate: 3860
    It is not written whether gasoline or diesel. Diesel safer,
  • #7 15854511
  • #8 15855427
    kyller
    Rate: 11
    Qujav wrote:
    Spoiler:
    /.../ I have a route to do, with a section where gas stations are approximately every 500km, maybe 400 with a small hook on the tank ...
    I want to take a 20L canister, but I'm curious if someone has any source, how do certified metal containers behave in the event of an accident? How dangerous is it? /.../
    Buddy, are you going on a route where the stations are every 500 km and you are afraid to transport fuel in a canister? LOL It used to be a lot of transport (2-3 canisters of 20 liters) and somehow we are all alive. What's the difference whether you have fuel in the tank or in the canister?
    Be careful of rubbing the canister against other metal objects - it can rub right through. By the way, the only country where there were sections where you couldn't really get fuel anywhere on large sections of 400km was Western Sahara
  • #9 15855520
Transporting fuel in canisters by passenger car is permissible under certain regulations. A maximum of 10 liters of fuel can be carried in suitable spare containers, such as canisters, without raising legal concerns. However, carrying larger quantities may attract scrutiny regarding the fuel's origin and safety risks, particularly in the event of an accident. The discussion highlights the importance of using certified metal containers for safety, as gasoline vapors can be explosive. Users shared experiences of transporting fuel, emphasizing the need for caution to prevent spills and potential fires, especially when canisters are in the trunk during impacts. Diesel is noted to be safer than gasoline in terms of transport risks.
