RJ45 Plugs: Differences Between Wire & Rope Types, Correct Assignment, & Universal Plugs
mariuszss 52799 5
  • #1 6311471
    mariuszss
    Rate: 55
    I have a question about RJ45 plugs. I once bought two types: for wire and for rope.
    For wire as in the picture:
    To the link as in the picture:
    I have a question for you - is this the correct assignment of endings?
    I am asking, because on Allegro some sell plugs with a description for the link and others for the wire that look identical. Until recently, I approached the topic of choosing a plug with a grain of salt, but recently I earned a cable (wire - a few meters) and it did not always work (with the plug as described above), I chose other plugs (for the cable) and the connection started working OK (the order of earning according to the configuration 568B).
    What terminations are there in universal plugs?
    Thanks in advance for your answers.
  • #2 6311604
    alvaro99
    Help: 34
    Rate: 47
    In fact, I do not know about these tips, because I approach this topic the way you used to ... but I can say that it often happens that the earned cables do not work because of the curved legs in the kneader ... even in the buddy store I used to earn money. I went home and the cable wasn't working. I came back and pressed better and ok.
    I know from experience that it is best to have a cable tester with you if you earn them a lot and often.
  • #3 6315975
    abdenagof
    Help: 58
    Rate: 28
    the wire and the line differ in the cross-section of the veins, the photos on the Allegro may be the same because the exhibitors use one photo for different auctions, not necessarily the one that reflects the goods sold
  • #4 6316032
    pstryk
    Help: 9
    You should stick "spikes" to the line and braid it to the wire, so there should be three prongs to the wire.
  • #5 6316238
    mariuszss
    Rate: 55
    Thanks for the answers.
    snap - do you know any leads in the network to be able to confirm such a selection of plugs, or on the basis of your own thoughts. I would like to have such a "pad" for the future.
    So far, nowhere have I come across any recommendations of cable manufacturers regarding the use of appropriate terminals.
  • #6 7151733
    lelo82
    Rate: 34
    I confirm. The description of the photos from the first post is correct.
    As predecessors wrote: needles are to stick to the line, and the wire is braided with three forks.
    In the case of wire, The forks are made in such a way (looking from the bottom of the plug from the pin side) so that when placed one next to the other, they do not cause a short circuit (two forks go one way, and one middle forks in the other - you can see how they are bent just before tightening, after carefully examining the plug) on the side).
    It still exists the third type of plug, the so-called universal (both for wire and rope)
    They are very similar to the lanyard ones. They have "double forks", but after careful inspection you can see that one of the forks is cut one way and the other is cut the other way.
    The idea is that in the case of a line, they should normally stick into the center of the core (and this is what usually happens), while in the case of a wire, they should diverge: one to the left, the other to the right :) (precisely due to the fact that they have alternately cut tips) In practice, it comes out differently, depending on the quality of the crimper.
    To sum up: (from my several years of practice)
    Any type of tip will be tightened on the "poverty" rope, it will be fully clamped (in the sense that the pins will be deeply seated) and it should work (good contact and no short circuits).
    However, it is best of course to use line ends.
    With the wire, the matter becomes more complicated.
    As a general rule of thumb, crimping the ends onto a wire should be avoided. We put the wire only from the socket to the panel in the closet. However, in practice we know that sometimes it is necessary to do otherwise ;) Therefore, someone came up with tips for wire.
    Now I will describe my experiences with crimping different ends FOR WIRE:
    The ends are intended for the line (personally, I never did it, because it shouldn't be, but I saw the previous admin at work).
    There are two possible effects: If the press tool has the correct (perpendicular) application of force, the needle is FORCED into the wire. It will not pierce this wire (no chance) - the effect is that the tip works, but the pins are not fully tightened. The effect of connecting such a plug to devices is such that the pins in the sockets start to bend too much. Later, after connecting a correctly clamped plug, it is enough to slightly withdraw it (RJ'ka, as we know, has some play in the socket, despite the latched dowel) and it stops connecting. In addition, plugs tightened in such a way you can immediately recognize the fact that, looking from the side of the dzyndzl, the wires are even pressed against the wall (knocked out of insulation).
    The second possible effect is that we have a poor quality press tool that applies some force to the side. The effect is that the needles slide off the wires and stick between the veins. In this case it is a lottery: it will either work or it will work and sometimes .. stop .. why ??
    Once I fought with several computers on which several times a day was "Network cable disconnected" and then the message disappeared after a while. No movement of the plug on the card or switch had any effect. The cable was checked with a simple tester (4 diodes indicating the efficiency of individual pairs in turn). The cable is wire, of course. As it turned out ? Short circuit between adjacent pins in the plug. These neighbors were one of the transmission cores (10/100 standard) and the remaining unused wire (connected to ground in 10/100 devices). It caused such degradation of the signal that .. the 3coma power cable managed, however, with a few exceptions per day.
    Now for the best for last. I have tried to crimp these ends several times. This time I used dedicated wire tips (those with 3 forks). The crimper was weak (for PLN 60). Wasted a few plugins. There was a short circuit each time. Although the plugs were wired, after crimping it it was obvious that the pins were not driven in as they should.
    In the case of all types of plugs, when crimped, when viewed from the side of the diaphragm, the tips of the needles sticking out of the core layer should be clearly visible.
    As for crimping universal terminals on a wire, I will only say that with a good crimping tool everything should be OK. However, I have the impression that the dedicated ones are better, but I noticed another problem. For a long time (2-3 years) sold wire ends do not tighten as nicely as they used to be. This is not only my opinion, but also a few experienced installers who I know.
    Therefore, nowadays the safer choice are universal tips + good (read above PLN 100) crimping tool.
    If the crimper is cheap and of poor quality, it is only suitable for crimping on a rope.
