Crimping Scheme: Pros & Cons of Non-Standard Twisted Pair to RJ45 Plug Order (Installer's Method)
piotrek22101 21558 4
  • Pros and cons of reordered RJ45 wire pairs
    #1 16385685
    piotrek22101
    Help: 695
    Rate: 1421
    Hello. If I did not find a good department, I am sorry, I am looking for pros and cons, such a crimping scheme. Recently I met an installer who connects the cables to sockets and plugs in a different order. The standard connection is as in the picture (not including the patch). He pins:
    orange, and white-orange.
    green, white-green,
    blue, white-blue,
    brown, white and brown.
    How is this with it? Thank you for your answer.
    • Crimping Scheme: Pros & Cons of Non-Standard Twisted Pair to RJ45 Plug Order (Installer's Method) 9941498900_1475101967.gif (5.17 KB) You must be logged in to download this attachment.
    Nonstandard pinout breaks twisted pairs and limits Ethernet speed
    #2 16385748
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8293
    Welcome.
    The diagram from the picture is correct, there is another variant of this connection, where the green pair is exchanged with the orange one.
    The connection method used by the installer you have described is incorrect. Electrically it's OK, because using this scheme on both sides, the connection will be working according to the multimeter. However, such a connection has a chance to set up to max 10Mbps, maybe with problems over a very short distance "a hundred will go". In a 100 megabyte network, two pairs (Tx and Rx) are used, of which one pair is on pins 1, 2, and the other pair is on pins 3, 6. With the gigabyte, two further pairs on pins 4, 5 and 7 are additionally used , 8. When doing the wrong scheme you described, one of the directions is correctly connected to the whole pair (1, 2), the other one is not (3, 6) - because this direction will be according to the description on half green and half blue pair. These signals are twisted pair for a reason. In case of a wrong connection, it will work badly and the installer should know about it, or should change work.
  • #3 16385786
    piotrek22101
    Help: 695
    Rate: 1421
    Maybe this is the installer, there is then something to fix.
  • #4 16385845
    dt1
    Help: 7315
    Rate: 8293
    Possibly :) If you want this installation to be really suitable for something, then you better insist on your version from the picture ;)
  • #5 16385866
    piotrek22101
    Help: 695
    Rate: 1421
    It just wasn't with me, I don't have to use it.
