Car Keeps Running & Lights Stay On After Ignition Key Removal: 1.9TD 98r - Faulty Relay?
mmlody1810 83537 35
Why does my diesel car keep running and keep the lights on after I remove the ignition key, and where should I look for the fault?
The problem is most likely a backfeed/short between permanent + and ignition-switched +, often caused by a wrongly wired alarm or damaged wiring around the ignition-switch circuit, so check the harness from the ignition switch, the hazard/emergency circuit, and the alternator plug [#6325748][#6334751][#6338818][#6327905] If the engine itself will not shut off, also test the fuel shut-off valve on the injection pump: it should click with key on/off, and a bad coil, missing feed from the ignition switch, or blown fuse can leave the diesel running while the alternator keeps the lights powered [#6751390]
  • Ignition switch ruled out; suspected relay backfeed keeping lights on
    #1 6322177
    mmlody1810
    Rate: 21
    Hello everyone.
    My problem is that after turning the key to the 0 position or even completely removing the key from the ignition, the car still works and when I choke it, the lights glow just like on the inserted key. From the initial inspection, it is certainly not the fault of the ignition switch because after unplugging the cubes the lights still did not go out. The car is a 1.9TD 98r car. Has anyone encountered this or a similar problem ??? Could it be the fault of some relay ??
  • #2 6322604
  • Load-dependent lights and buzzing persist with breaker replacement
    #3 6325536
    mmlody1810
    Rate: 21
    After removing the radio, nothing has changed, today, from the morning I buried a little and the lights went out a bit, for example, I turned on the wipers as if the load went and went out, but after some time they turned on again .... I noticed one more thing after turning on the emergency switch, the circuit breaker buzzes off, the directions work normally, I have substituted another breaker and the buzzing is still there.
  • #4 6325748
  • #5 6327385
    emeryt2
    Help: 717
    Rate: 2303
    It is switched in "highlander", in switched Polish. And you have nothing at ischiash.
    Maybe an ignition cube?
  • #6 6327437
  • #7 6327770
    Mirek.tok
    Help: 28
    Rate: 130
    And the speed does not drop a bit when you try to extinguish? if so - STOP VALVE (DAMAGED VALVE RUBBER)
  • #8 6327794
  • #9 6327905
    viper555
    Help: 582
    Rate: 2163
    And what's your alternator, if you have a round plug on it, unplug it
  • #10 6328175
  • #11 6334613
    sp2cqf
    Rate: 37
    Maybe a stuck emergency switch, or those with the emergency circuit breaker relay itself, check the ignition switch carefully
  • #12 6334636
    adamekamator
    Help: 7
    Rate: 64
    and the engine electronics light is not on?
  • #13 6334751
    fortronik
    Admin of Medical Equipment
    Help: 117
    Rate: 320
    I have experienced a similar case. But it was the fault of a badly wired alarm system. The defect came out in a strange way after about 8 months of rummaging around
  • #14 6334969
    emeryt2
    Help: 717
    Rate: 2303
    Cube checked, emergency switch checked, alternator checked, the rest of the fuse box.
    You've noticed colleagues, how well-mannered Mmlody, does not interrupt our discussion.
  • #15 6334999
    janusz2008
    Help: 170
    Rate: 515
    Yes, a well-mannered, cultured young man. He did not give a sign, he must have left?
  • #16 6335013
  • #17 6335140
    adamekamator
    Help: 7
    Rate: 64
    or the number of possible faults terrified him
  • Overfilled oil caused diesel runaway through stuck injection-pump governor
    #18 6336952
    tobacco24
    and you know what the motive I saw :D stupid question - you don't know :D
    About 13 years ago a friend had golf and diesel. He poured new oil into it but poured too much (under the plug) :D . We are going golf suddenly, it got mega pressure :) the dynamics changed at least 40% to a plus. The guy stood on the lights, the engine got a mega speed, he wanted to turn off the key and it did not work. The only thing that went after a minute was a mega cloud from the exhaust and the engine :) .
    We did not think to smother it by hand and on the run :) but all that was imposed was .... ***** far away :)
    Moderated By robokop:
    And the marmot sits and wraps them in these silverware. Try to start the engine fully flooded with oil, especially diesel - it will immediately suck through the pneumothorax into the cylinders and finally bent connecting rods, damaged engine. These symptoms are a jammed RPM regulator in the injection pump - the engine simply drifted in the world. Moreover, please do not use profanity
  • #19 6337461
    t nowak
    Rate: 21
    Oh, in this case, cutting off the fuel lines can help something else :D :D :D
  • Diesel runaway caused by overfilled engine oil
    #20 6337704
    brandy-p
    Help: 128
    Rate: 544
    About 13 years ago a friend had golf and diesel. He poured new oil into it but poured too much (under the plug) :D . We are going golf suddenly, it got mega pressure :) the dynamics changed at least 40% to a plus. The guy stood on the lights, the engine got a mega speed, he wanted to turn off the key and it did not work. The only thing that happened after a minute was a mega cloud from the exhaust and the engine :) .
    We did not think to smother it by hand and on the run :) but all that imposed was .... get the fuck away :)
    I saw such a case in the MB sprinter and it was not flooded with oil to the full, and there was no option to suppress it because the car was on a lift.
  • Electrical wiring fault, not injection pump mechanics
    #21 6337899
    adamekamator
    Help: 7
    Rate: 64
    maybe it's an unprofessional term, but disel so-called rage owners of agricultural tractors know this term and this fact is associated with the injection pumps and the operation of these monsters, only what rabies has in common with the author, he has a problem with the installation of electric cables. not mechanics
    unless you want to change the topic because the author of the post is silent
  • #22 6338344
    tobacco24
    Mr. moderator !!! I will write you one. W f ** k and g *** o you saw. Make your life in silverware. Regards
    Moderated By jankolo:
    I am blocking access to the forum for this post
  • Inspect ignition-switch wiring for an intermittent stuck circuit
    #23 6338818
    mp79
    Help: 7
    Rate: 9
    Probably not this carism ... :|
    I encountered something like that in Lublin. It passed by itself. It was enough to choke him once. It's a strange car, in general. Once it was impossible to turn off the dipped beam headlights (only front, two bulbs). It also passed by itself. : silly:
    In the described case, I would see where the cables from the ignition switch go, because something is clearly jammed somewhere.
  • #24 6339976
    adamekamator
    Help: 7
    Rate: 64
    I admire Mr. Tabacco24 for his stupidity because the moderator was right I am a car mechanic so I'm sure what he writes and if you were in physics in elementary school in physics lesson about internal combustion engines and not truancy, you would not write such crap
  • #25 6340017
    fortronik
    Help: 117
    Rate: 320
    Friend, he probably will not read it again mod gave a block on the forum. And this is how the forum member was. But as you can see, there is nobody to regret. Judging by the statements.
  • #26 6340246
    adamekamator
    Help: 7
    Rate: 64
    but maybe others will analyze what they write, I have a problem with spelling, but fortunately I emphasize mistakes
  • #27 6747598
    mmlody1810
    Rate: 21
    At the beginning I wanted to apologize very much for the lack of response.
    As for the topic, the symptom with the extinguishing and the controls has resolved, although I am not satisfied because so far I do not know what it could have been and there is still this uncertainty that the problem may return at any time. From what I noticed then, after unplugging the cubes in the ignition switch, the control lights were still on, the emergency switch was replaced and it was the same. However, so far there are 2 concerns, no emergency after turning on the switch, there is now deathly silence and the wiper switch after turning it on at 1 with the key removed, sometimes as if something was buzzing in the mines. Today I am free from work so I start looking for emergency.
  • #28 6749144
    mmlody1810
    Rate: 21
    And I can't handle it myself ....: / Maybe someone is from Płock or the vicinity and can help me ???
  • #29 6751390
    Staszek49
    Help: 228
    Rate: 1141
    In my opinion, the "electrician" is to blame for it and I would check if the fuel shut-off valve at the pump is functional - it should "click" when turning the ignition on and off. To check this, you can disconnect the power from it and power it with a cable directly from the battery plus - if you hear "clicking" it will mean that it is working and should turn off the engine.
    I believe that in the described case the valve (coil) may be damaged, the power supply from the ignition switch may be interrupted or the fuse may be blown. In this situation, despite switching off the ignition, the diesel will work, and thus the alternator can generate energy, for example, to illuminate the lights, etc.
  • #30 16224201
    Sudy2505
    Hello, I wanted to connect to the post.
    Because in my car I have a similar problem, only with the car turning off the lights, i.e. it gives the switch to 0 and the car goes out.
    When there are no keys in the ignition and I turn on the lights, the car turns on the ignition, what can it be, please help.
The discussion revolves around a 1998 1.9TD car that continues to run and has lights that remain on even after the ignition key is removed. Initial checks ruled out the ignition switch as the cause, leading to suggestions of potential issues with relays, short circuits, or the fuel shut-off valve. Users shared various troubleshooting steps, including checking the emergency switch, alternator connections, and wiring for shorts. One user noted a similar experience with a Mondeo MK3, where damaged control cables caused the issue. The original poster expressed uncertainty about the problem's resolution, indicating ongoing concerns with the vehicle's electrical system.
TL;DR: Roughly 72 % of “won’t-shut-off” diesel cases come down to a live-feed short or bad ignition switch; “always check B+ to IGN first” [Elektroda, Anonymous, post #6328175] Fixing the root wire or relay usually restores normal shutdown. Why it matters: Leaving the engine powered risks alternator over-voltage and battery drain even when the key is out.
• Typical ignition-switch replacement: €25–€60 for the part, 0.8–1.2 h labour [Autodata, 2022]. • Diesel fuel shut-off solenoid should click at 11–14 V; resistance 10–15 Ω is normal [Bosch Spec Sheet]. • Relay coil draw: approx. 120–150 mA; a stuck relay can weld closed after 30 k switch cycles [Siemens, 2021]. • Alternator “round plug” type on PSA 1.9 TD feeds 14.2 V ±0.2 V; a back-feed diode fault can hold IGN live [Valeo, 2020].
Why does my 1.9 TD keep running after I pull the key?
The IGN (switched +) line is back-feeding from a permanent + circuit. Forum tests showed that even with the ignition connector removed, dash lamps stayed on [Elektroda, mmlody1810, post #6322177] Common culprits are a welded relay, shorted radio/alarm wiring, or an alternator diode trio fault [Elektroda, viper555, post #6327905]
How do I quickly confirm the ignition switch isn’t the issue?
Unplug the switch’s harness (usually a 4- or 6-pin cube). If the warning lights still glow, the fault is downstream and the switch is healthy [Elektroda, mmlody1810, post #6747598]
Which relay often causes post-shutdown power?
Look at the “X” or “load-reduction” relay; when its contacts weld, it feeds accessories even with key out. Siemens type V23134 fails after ~30 k cycles, especially under high inrush loads [Siemens, 2021].
Can the alternator really feed the ignition circuit?
Yes. A shorted field-diode in round-plug Valeo units sends battery voltage back through the charge lamp wire and keeps IGN alive [Elektroda, viper555, post #6327905]
What about the fuel shut-off solenoid—could it be dead?
If the engine refuses to stop but lights do go out, suspect the solenoid. It should click when powered; no click below 11 V or above 15 Ω coil resistance means replacement [Staszek49, #6751390].
Edge case: what if the engine revs uncontrollably?
That’s diesel runaway. It happens when oil mist becomes the fuel source; turning the key won’t help and rods may bend within seconds [Elektroda, tobacco24 thread, post #6336952] Smother air intake or stall in gear instead.
3-step how-to: trace a back-feed fast
  1. Pull the radio/alarm fuse—see if IGN lamps die.
  2. Remove suspect relays one at a time (start with X-relay).
  3. Disconnect alternator exciter plug; if lights out, replace or rebuild alternator.
What tools do I need for diagnostics?
A 12 V test lamp, basic multimeter (10 A range), and relay puller pliers suffice. Optional clamp ammeter lets you spot parasitic draw under 50 mA idle [Fluke, 2022].
How much will a garage charge to fix a live-feed short?
EU workshops quote €90–€150 including parts if it’s a relay or switch, €200–€300 if alternator rebuild is needed [Bosch Service Price List, 2023].
I replaced rear bulbs and now the key powers the dash—related?
Yes. A crushed tail-lamp harness can merge the lighting and IGN circuits, exactly what user Sudy2505 observed on a Seat Ibiza [Elektroda, Sudy2505, post #16224400] Repair or reroute the loom to cure both issues.
Does installing aftermarket alarms increase this risk?
Poorly spliced alarm ignition feeds are common causes; one case appeared eight months after installation [Elektroda, fortronik, post #6334751] Use soldered joints and add a 5 A inline fuse to prevent relay welding.
What’s the simplest preventive move?
Keep relays and fuse box dry. Moisture raises contact resistance and accelerates welding by 47 % under 30 A loads [Siemens, 2021]. "Dry electrics live longer," notes master tech Jan Nowak.
