Setting ATX Power Supply for Automatic Computer Startup Post-Power Failure
majty0 27320 4
  • #1 6337661
    majty0
    I have an ATX power supply, and AT power supplies, when the power went out and the computer shut down, and when the power was restored the computer turned on automatically, I would like to set the ATX power supply so that it would be the same as the AT, but I do not know how to go about it.
  • #2 6337702
    wladek83
    Level 32  
    Help: 155
    Rate: 104
    It is necessary to set such an option in the BIOS of the computer - what it is supposed to do in the event of a return of power supply voltage.
    Sage.
  • #3 6337716
    mat_ed
    Help: 924
    Rate: 268
    You can also redesign the power supply accordingly.
    The topic has been discussed more than once and not twice, just use the search engine on the forum.
  • #4 6337727
    orzelpiotr
    Help: 238
    Rate: 164
    Some boards have this feature in the Bios. I think it's called Auto Power On or Resume After Powerfailure.
  • #5 6337756
    wladek83
    Level 32  
    Help: 155
    Rate: 104
    Just as a colleague writes - in my BIOS there is a Power section, in it the APM Configuration function, then Restore on AC Power Loss and here to choose from: Last State ( that is, the last state ) , Power Off and Power On . In this case, you should set Power On.
    Sage.
