Driving a VW Polo 1.4 Petrol with a 44Ah Battery after Alternator Failure: Tow Truck Needed?
Nemo 52226 10
How far can I drive a VW Polo 1.4 petrol on battery power alone after the alternator belt fails, and do I need a tow truck for a short trip to the workshop?
You can probably make a short trip on battery alone, but only for a limited distance: one estimate is about 15–20 km if the battery is well charged, or roughly 2–3 hours of driving, and traffic matters more than distance [#6415458] [#6415929] Another user said they once managed less than 40 km, but without the lights it would go farther, so normal headlights will cut the range significantly [#6415920] For the 6 km city trip mentioned in the thread, several replies imply it should be possible, but not with much margin [#6415897] [#6417119] There is also a safety warning that driving this way can lead to additional faults, so a tow truck is the safer option if you can get one [#6415862]
  • #1 6415429
    Nemo
    Help: 9
    Rate: 72
    I have a question quite important to me:
    Car: VW Polo 1.4 petrol, 44 Ah battery, 4 months old
    After the failure, there is no V-belt, and therefore no power steering and no alternator. And here you have to get to the workshop somehow. At this point, the question arises: how long will the car last on the battery alone, I assume driving up to 2000 rpm. And the headlights are on normally.
    I'm asking because I don't know if I should take a tow truck.
    Regards.
    brandy-p
    Help: 128
    Rate: 542
    if well charged, I think 15-20km. Of course, if you don't get stuck in traffic.
    Time is more important than distance
    shadow0013
    Help: 243
    Rate: 314
    In the past, when the belt failed, a woman was undressed from tights and somehow reached the destination without lights. I drove about 40km (there was no own woman at hand, and harassment of random people can be dangerous).
  • #4 6415862
    alpha01
    Help: 31
    Rate: 164
    Gentlemen, what is the discussion about. I've already seen the effects of such a ride. The pillow drivers give the body first.
  • #5 6415897
    bandzior2
    Help: 38
    Rate: 146
    You won't get much on it, but you can get there ;)
  • #6 6415920
    paelek
    I had a similar case, the electricity was enough for less than 40 km. but without the lights it will definitely go half way further.
  • #8 6415988
    salmon
    Help: 435
    Rate: 262
    I don't know how in this engine with a cooling pump - belt drive or timing belt?
  • #9 6415998
    brandy-p
    Help: 128
    Rate: 542
    And here I agree with my colleague, at the end of such a drive there can be many errors in the drivers.
  • #10 6416019
    Nemo
    Help: 9
    Rate: 72
    Thanks all for the replies. And I'm already writing:
    :arrow: salmon : The water pump on the timing belt, so it shouldn't overheat.
    If there are mistakes, it's hard, maybe you can deal with them somehow. I'm sure they'll be fine in the workshop. If only to arrive.
    I wonder how much electricity the computers and the ignition consume during operation, because light bulbs are known (all together about 200W, I think).
    It's supposed to be close, about 6 km, but it's through the city. Well, let's see if it works. I will write about the effects. Oh, I'll be driving with a voltmeter connected to the cigarette lighter. That way I should probably know how much more the battery can do. I can make it to 10 volts.
    Regards.
  • #11 6417119
    bandzior2
    Help: 38
    Rate: 146
    6km, you can only charge the battery with a rectifier before this ;)
The discussion revolves around the feasibility of driving a VW Polo 1.4 petrol with a 44Ah battery after an alternator failure, specifically without a V-belt, which results in no power steering or alternator function. Users estimate that the car can travel approximately 6 to 40 kilometers on battery power alone, depending on driving conditions and whether headlights are used. Some responses suggest that the battery could sustain driving for 2-3 hours, while others emphasize the importance of avoiding traffic to maximize distance. The author plans to monitor battery voltage during the drive to assess remaining capacity and is concerned about the electrical consumption of the vehicle's systems. The water pump is confirmed to be on a timing belt, reducing overheating risks.
