  • #1 6454386
  • #2 6454419
    kaken
    In electronics stores, 1L costs PLN 18 (in Wrocław).
  • #3 6454428
  • #4 6454432
  • #5 6454443
  • #6 6454510
    michal.rogaczewski
    Help: 94
    Rate: 82
    Look for "CLEANSER IPA" This is isopropanol and is available in various packages (small sprays, large sprays and normal liquid)
  • #8 6455995
  • #9 6467241
    jokrasa
    Help: 112
    Rate: 89
    I ordered from AGAWA, by phone (044) 726-15-13 and they delivered it by shipment.
    When I needed it, nobody in the nearby shops had an electron, I don't say anymore that in Żyrardów there was an electron. the dumplings shop, they didn't really know what I was asking.
    I just found it on the net, but you know, you know the composition and probably under a different name, in a different incarnation you can buy it.
  • #10 6467991
  • #11 6468623
  • #12 6468683
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 587
    elektrit wrote:
    They need something there ...
    Isopropanol is used in the humidification systems of offset machines.
  • #13 6468725
    serwis
    Level 37  
    Help: 334
    Rate: 268
    Aszloch wrote:
    Hello!
    I was in "OBI" and there was no such thing! And now where can I buy it? Please do not give me links on the Allegro - because the shipment itself will cost more than isopropanol!
    Regards and I am waiting for a response ;)
    And such a link can be Link :D
    You are looking for something poorly, or you don't live in Lublin.
  • #14 6468735
    movzx
    Level 40  
    Help: 731
    Rate: 1269
    Experience shows that a spray IPA is much more expensive than a bottle in a bottle. So, if you don't necessarily need the "puff" function, it is better to buy the latter. Unfortunately, you do not have a direct micro-chip distributor in Lublin, maybe it will be faster to order by post. Possibly someone will buy you and send it to you.
    edit: o, "Standard" appeared, problem seems to be solved.
  • #15 6469053
Isopropanol can be purchased at various locations, including electronics stores where it is available in different quantities, such as 1L for around PLN 18 in Wrocław. Smaller packages, like 150-200ml sprays, are also available under the name "CLEANSER IPA." Some users suggest checking with local printing houses, as they often have isopropanol in bulk for their operations. Online ordering is another option, though shipping costs can be a concern. Users recommend avoiding expensive spray options if a simple bottle suffices.
