Meaning of 70% V/V on Denatured Alcohol for Gasoline Use?
rafbid 64170 20
What does the 70% V/V marking on denatured alcohol mean, and can I use it in gasoline to prevent water from freezing?
70% V/V means 70% by volume, so the bottle is a diluted mixture rather than nearly pure alcohol [#11629577] For removing/binding water in gasoline, several replies recommend using concentrated, water-free alcohol instead—preferably 99% IPA—because store-bought denatured alcohol may contain enough water and impurities to make the problem worse [#11633277][#11634634] One reply says a small amount of ethanol in a large tank is unlikely to cause harm and can help carry tiny amounts of water out with the fuel, but it is best used in a tank that is already low on fuel and then driven soon after [#11634432]
  • #1 11629255
    rafbid
    Help: 153
    Rate: 418
    Hello, as in the title, I wanted to add denatured alcohol to the gasoline just in case the water wouldn`t freeze somewhere, but on the bottle it says "with an apparent power of 70% V/V" and I`m not sure what exactly that means?
  • #2 11629328
    robokop
    Help: 1763
    Rate: 6376
    That it`s some diluted fake. In a petrol station you can skip this procedure.
  • #3 11629359
    rafbid
    Help: 153
    Rate: 418
    And what if I add gasoline once every six months? Because I have LPG installations.
  • #5 11629577
    Cowboy zagrabie
    Help: 159
    Rate: 502
    V/V= volume/volume, volume concentration, 70% thin is a fault ;) ,
    I highly recommend adding concentrated (<90%) ethanol in the winter to bind 5-10% of the water contained in the fuel. Considering the quality of fuel offered by our gas stations, this is the most appropriate procedure and will help you avoid problems with ice plugs in the filters. For gasoline only denatured alcohol, but for Diesel also gasoline in the amount of 5-10%, in order to prevent the precipitation of paraffin.
  • #6 11630742
    kot mirmur
    Help: 206
    Rate: 561
    I pour IPA isopropanol into my Carina E 1.6 16V. Even in a 1/4 ratio, the engine works perfectly (1993, original Japanese).
  • #7 11630882
    Cowboy zagrabie
    Help: 159
    Rate: 502
    @>Ponichter Janusz, if you have an IPA for the price of denatured alcohol, I`ll have two Mausers please ;)
  • #8 11633277
  • #9 11633339
    robokop
    Help: 1763
    Rate: 6376
    Both true and not true. A mixture of alcohol and water of around 40% does not freeze - at least I haven`t seen frozen booze. The lower the alcohol concentration, the less it pulls moisture from the air. So half a liter of denatured alcohol in a bucket of water in the tank won`t do anything. Patent using emulsifying oil - you`ve gone too far here, what will be the crystallization temperature of such a mixture? In addition, oil diluted with gasoline will no longer have emulsifying properties. Using inventions such as IPA and others is quite risky - it is impossible to predict their impact during the combustion process on important engine components, including the probability of decomposition of engine oil.
  • #10 11633387
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4260
    How does the denatured alcohol-water mixture mix with gasoline?
    Water itself does not mix (you can stir it, but it will separate),
    so if there is even a little of it in the gasoline, it settles at the bottom of the tank
    and it may freeze; alcohol is mixed with gasoline, probably a mixture
    alcohol with some amount of water too - the question is how much
    water, the mixture will be stable so that no water is released.
    If the water content exceeds a certain threshold (unfortunately I don`t know what it is
    he is), is the result of adding an alcohol-water mixture to gasoline
    will be such that some of the water will separate and remain at the bottom, along with the gasoline
    alcohol and water will be mixed in a higher proportion of alcohol to water...
    thus, adding alcohol can cause water to remain.
  • #12 11633941
    revolt
    Help: 159
    Rate: 186
    When we forgot to turn off the turbo in the freezer after a party, all the drinks froze nicely (it was about -25).
  • #13 11634298
    rafbid
    Help: 153
    Rate: 418
    Below is the dependence of the freezing point of water and spirit liquids on the alcohol content:
    11.3% - 5C
    20.3% - 10.6C
    29.9% - 18.9C
    33.8% - 23.6C
    39% - 28.7C
    46.3% - 33.9C
    56.1% - 41C
    100% - 115C
  • #14 11634310
  • #15 11634432
    robokop
    Help: 1763
    Rate: 6376
    pandy wrote:
    It`s not about the water-alcohol mixture freezing, but about the fact that water is separated from the water-alcohol-gasoline mixture - why is alcohol added to the tank - to bind the water and burn it, or maybe the water has collected at the bottom of the tank where it will be a great place for various fungi and bacteria that form on the edge of the film and where this will significantly increase the risk of internal corrosion of the tank (even though most fuel tanks have an anti-corrosion layer inside)?
    I`m afraid my friend got too caught up in theory. In sequence;
    -how much bad and harmful water will there be in the tank? A few or a dozen or so grams, a larger amount has no reason to exist - the fuel pump pump usually pulls at the very bottom, this water would be sucked into the engine`s injection system and immobilize it. This is about a small amount of moisture, which may actually be present in the form of water at the bottom of the tank, and which, if frozen, could stick to the dragon strainer. Therefore, adding even 0.5 liters of ethanol to >40 liters of gasoline is unlikely to cause any harm. It is added not to burn the water, but to bind it and send it out with the fuel from the tank. Bacteria and fungi in the tank are also unlikely to exist - gasoline is an organic solvent that will rather utilize any proteins on an ongoing basis. I have never seen moss or algae in the tank, nor have I seen tank corrosion in modern cars - safety and economic requirements have long since introduced plastic tanks in passenger cars.
    It`s not about absorbing moisture from the air, but about the ability of alcohol to absorb a certain amount of water and at the same time not separate if there is still gasoline - this is where single percentages begin to play a role.
    Read above.
    I consider adding denatured alcohol to diesel oil a pyramidal misunderstanding - that`s what the water filter is for, to catch water, and kerosene should be used as a diesel depressant, not alcohol.
    But kerosene will not bind water, which, when frozen, together with crystallized paraffin, can effectively block the fuel filter.
    A colleague might as well write that pouring denatured alcohol into the dryers of truck brake systems is also heresy - there is also a problem with water, which in the form of ice can destroy the brakes.
  • #16 11634634
  • #17 11637728
  • #18 11645800
  • #19 11645904
    robokop
    Help: 1763
    Rate: 6376
    pandy wrote:
    Well, it`s hard for me to respond to this argument because I`ve seen advice many times to use nail polish remover to degrease the surface (most nail polish removers nowadays are acetone-free, and even when they were acetone-based, they still had additional lubricants whose task was to prevent degreasing).
    Well, this advice comes from the times when the socket was stiff 220V, ham was 100% meat and nail polish remover was pure acetone.
    In fact, so far I have been removing the toner from the PCB using my wife`s remover - acetone and nail nourishing additives.
    And I will write once again - a liter of IPA with a purity of over 99% is about PLN 10-12 - half a liter of denatured alcohol with quite varied composition but with much less ethanol than 95.6% is about PLN 5-7 (of which, to be honest, I usually see closer to PLN 7 ).
    A liter of IPA PLN 12 vs a liter of denatured alcohol PLN 14 - I don`t understand the point of paying more for a worse product.
    But you won`t get IPA in your local grocery store - what`s more, I haven`t even seen it at gas stations.
    Just evaporate a bit of denatured alcohol on a glass to see how much precipitate remains...
    Do you think that nothing will remain after the gasoline evaporates?
    Either way, how many votes, so many different opinions - to be decided by the interested parties themselves. Let me just say that I personally do not add anything to gasoline - for diesel engines, as a preventive measure, 2-3 liters of gasoline per 70-liter tank, at frosts exceeding 15 degrees - just for peace of mind. There is nothing more interesting than looking for a heated garage to defrost the fuel lines of a car that has been pulled off the road.
    There is one more issue, often overlooked - refueling the car once a year with gasoline, when powered by LPG - what is in the tank after a year, the parameters in real life do not resemble those guaranteed by the quality standard - just compare the smell itself - it is also far from flammable ideal.
  • #20 11645941
    piotras-scrambler
    I poured denatured alcohol into cars with petrol engines: Audi 80, Audi A4, Polonez, 126p, Tico, Seat Arosa. Whenever the temperature was still above 250 ml, I never noticed any irregularities in the engine`s operation.
  • Existing ethanol makes adding denatured alcohol unnecessary
    #21 11663624
The discussion revolves around the addition of denatured alcohol to gasoline, particularly concerning its effectiveness in preventing water from freezing in fuel systems. Users express skepticism about the quality and concentration of denatured alcohol, with some suggesting that isopropyl alcohol (IPA) is a better alternative due to its higher purity and effectiveness in binding water. The term "70% V/V" refers to the volume/volume concentration of the alcohol, indicating a diluted product. Participants highlight the risks of adding alcohol with high water content, which could exacerbate water issues in the fuel tank. Recommendations include using concentrated ethanol or IPA, especially in winter, to mitigate the risk of ice plugs in fuel filters. The conversation also touches on the potential impact of alcohol on engine components and the importance of understanding the freezing point of alcohol-water mixtures.
