Amica Cooker Control Panel Locked After Power Failure - How to Unlock?
kuczaj 43560 7
  • #1 15796141
    kuczaj
    Rate: 16
    Hello and welcome,
    I have a problem with the control panel of the Amica cooker, model unknown (it was already in the apartment when I bought it)
    After a power failure, which has already happened, the time flashes and a padlock icon appears. We`ve had failures before, after which the time was set and everything was fine, but the lock icon was never there. Now when you touch the panel it just lights up but nothing works.
    I am attaching a photo.
    Thanks in advance for any information on what it could be and how to turn it off
    regards
    Jedrzej
    • Amica Cooker Control Panel Locked After Power Failure - How to Unlock? 1468049302019-1439434810.jpg (2.02 MB) You must be logged in to download this attachment.
    sanfran
    Help: 963
    Rate: 3004
    A padlock is a child-proof device. Then the knobs become inactive. To turn it off, long press the key or key combination. For me, MENU works if I press it for about 10 seconds.
  • #3 15796220
    kuczaj
    Rate: 16
    That`s what I thought, but I didn`t know the combination.
    It worked for me when I pressed all the buttons on the panel at once and held down for 15 seconds.
    Thanks
  • #4 15796222
    sanfran
    Help: 963
    Rate: 3004
    Unplug it overnight and maybe it will be better in the morning.
  • #5 15847886
    kuczaj
    Rate: 16
    Parental lock
  • #6 19116777
    Milena-M89
    Rate: 9
    The topic is still relevant - I have the same oven and I have already tried all possible combinations to disable the lock and nothing works! Do you have any ideas on how to fix this?
    PS.
    Disconnecting the power, holding the buttons for 20 seconds, etc. does not help ☹️
  • #7 19360881
    fufurka89
    Level 4  
    I have a problem, but in the other direction - I want to block it and I don`t know what combination... I have a similar display
    Were you able to find answers/combinations other than those described?
  • Amica panel unlock requires door pressed firmly
    #8 20272220
    leburaque
    Rate: 111
    OK, I`m resurrecting an old topic, but I was looking for an answer to this question for a long time. Finally, I found this answer on Wykop:
    "You need to hold down the menu button and the arrow on the right. All knobs must be in the "zero" position and the oven must be closed. You should check whether the oven is closed and what about these knobs, i.e. turn the knobs, open and press the oven, etc."
    It worked for me*. :) If it helped dej mnje ploosa. :)
    * I will only add that for unknown reasons I had to press the door harder and hold it while pressing the buttons.
The Amica cooker control panel can become locked after a power failure, displaying a padlock icon and rendering the panel unresponsive. Users have suggested various methods to unlock the panel, including long-pressing the MENU button for about 10 seconds, pressing all buttons simultaneously for 15 seconds, or holding down the MENU button along with the right arrow while ensuring all knobs are in the "zero" position and the oven door is closed. Some users have also recommended unplugging the cooker overnight as a potential solution. However, there are reports of difficulties in unlocking the panel despite trying these methods.
