ZeXt Motion Sensor Lamp Constantly On Despite Correct Wiring and Settings
Pawele2626 60278 3
  • #1 6565332
    Pawele2626
    Well, I lost the instructions, but I try to look for it, once I read it but I don't remember much.
    I have a lamp and a motion sensor (ZeXt) to react to movement.
    I connected according to the scheme, but it is lit all the time, there are two day-night settings and time - or +, i.e. the time that is to be lit.
    These arrows are not known from which side it is because it is so strange but I set it up anyway and at night and it still shines.
    I connected like this:
    I connected the blue wire (minus) to the sensor and to the lamp
    I connected the brown (plus) to the sensor and the red one that comes out from there to the lamp.
    So it turns out that the minus is all the time with the plus is switching on the sensor only why the lamp is on all the time?
    Something after 1 start does it? I waited 10 minutes and it did not go out.
    I know that I connected it well, the manual writes something about 1 launching some AUTO mode that goes out every 5 seconds, but here is the problem that it is on all the time, I set it for the night so that it does not react during the day and it shines anyway.
    The sensor and the lamp are separate.
    Even if I turn on and no one comes, it shines anyway, I waited after 10 minutes and the max time is 8 and nothing. Nothing goes there or anything that the sensor is catching something all the time.
    Anyone can help me?
  • #2 6565951
    zubel
    Conditionally unlocked
    Help: 41
    Rate: 129
    You need to cover the sensor carefully and then set the regulator to half the range and wait if the lamp goes out, if it does not go out, disconnect the sensor and check with the meter, the transition between brown and red should be a break, otherwise, the relay contacts are stuck together or the triac is defective, but it depends on the sensor type
  • #3 6566128
    Krzyś33
    Help: 58
    Rate: 104
    Hello. Forgive my friend, but only a qualified electrician can help you. Why am I writing this? Well, after you connected the sensor with the lamp for the first time - the motion sensor was probably released. And if you found a plus and minus in the alternating current, it seems to me that you had little to do with the current. Therefore, for your own safety, entrust "games" with the flow to an electrician to them. Regards.
  • #4 6566186
    Pawele2626
    I do not know, but it is done in such a way that there is always a plus in one, because it is not a socket, but an installation made for it (a box and a latch).
    I dealt with the problem.
    I just did not know that he was catching trees that "flew" so far because there was wind and after switching to the night it shone because he just didn't have a moment of stillness.
    Case resolved all git, but thanks for the help
