VAG K+Can Commander 1.4 China Version from eBay - Compatibility and Usage
daaniel88 180663 67
  • #31 7962769
    olo_3
    Rate: 24
    that's how ibiza 2001 had a separate immo box (similar to golf3, address 25), and you will not move it with this equipment, you need something like this: "MOTORDIAG Imobox1 PIN Manager" demo version does not show the pin: /, the program costs something about 50euro (I don't remember exactly, but he does these and other cans after diagnosis), Commander from China makes audi cans, give the first 6 digits and imo iden. - then it will be black and white.
    http://www.motordiag.cz/download/MPMdemosetup.exe
  • #32 8206764
    rekiin1982
    Wiatm or vag comander k + can will go in windows7? Please answer
  • #33 8206825
    olo_3
    Rate: 24
    I don't know, I use xp.
    From what I read, if win7 is 32bit, it is enough to download the drivers to FTDI and it will start - I note that I only read this, written by some user, which does not have to agree with the actual state.
  • #34 8207569
    labik
    Rate: 79
    It will go 100%.
  • #35 8207627
    olo_3
    Rate: 24
    in 64-bit Wnidows 7?
  • #36 8210157
    daniel_lhr
    Rate: 31
    does this motordiag program run on an ordinary KKL cable?
  • #37 8211370
    rekiin1982
    yes this Winsows64 bit, and i don't run this program on any cable. I bought it from the tewis.pl store and it seems to me that it is a bit of a mess
  • #38 8213371
    labik
    Rate: 79
    the win7 32 works perfectly
  • #39 8259376
    flashh
    Help: 18
    Rate: 30
    I will step on the topic. I was able to connect with this VAG_CAN_Commander v1.4 but actually I can only read the counter. I do not have an active tab where you can read the PIN or program a new key. Actually, I want to program a new key for Bora because the car was bought with one and it's a bit afraid to have one.
    How is this done, I need a PIN and Crypto programming to the system, please sort it out. Unfortunately, the seller sold me a cable without a dongle and is it possible to do this with this version?
    greet
  • #40 8419312
    qqq1112121
    gentlemen, I need a vw tester and this leech above works, but when I downloaded, the tester does not start at all
  • #41 8444457
    karolek80
    I also wanted to connect I have vcds and the original cable to usb, I can not run vag commander 1.4, will it not go on this?
  • #42 8444601
    labik
    Rate: 79
    These are different cables, unfortunately you won't connect to the commander.
    ps
    drop some vaga program running with Commander cable
  • #43 8468354
    n0w3y_pl
    Rate: 23
    Gentlemen, I bought a vag k + can commander 2.5 because I need to correct the mileage in the meter, I do everything according to the instructions, i.e.
    select channel 7 combi
    with specials I choose instruments / immo
    reads the current mileage which converts to km the car is in the UK
    enters a new mileage
    I click change.
    the central screen shows the info that the mileage has changed, but the mileage on the odometer is not changed.
    any idea ?
  • #44 8480002
    MARCIN_DOB
    Rate: 73
    is it possible to run VCDS on a cable from VAG K + Can Commander 1.4 China ???
  • #45 8575250
    77omega
    Rate: 36
    n0w3y_pl
    City: Westbury
    Post 02 Sep 2010 16:29
    Re: VAG K + Can Commander 1.4 China
    I click change.
    any idea ?
    Back to top
    Write what kind of car you have, if you have a belt or a similar car with the meter has voltage even as the keys are removed (the meter shows the mileage), it is enough to detach the clamps from the aka for 1 minute, of course, first think about whether you have the code for the radio, and it should be ok :D
    IT'S NOT POSSIBLE
  • #46 8589566
    Medyk_la
    I click change.
    any idea ?
    Hello :)
    Buddy, there is an idea ....
    after these operations you need to click Reset ECU and that's it
    Regards
  • #47 8630508
    sniegu81
    try to disconnect the clamps from the battery sometimes helps
  • #48 8657467
    kukiz1986
    Help: 17
    Rate: 410
    can someone put vag-can commander 1.4 in china? all previous links do not work. One works, but it is not the soft one.
  • #49 8771149
    robert199
    Help: 30
    Rate: 289
    I have a similar problem as my colleague n0w3y_pl only in the audi a8 from 1995. In that counter, the ECU reset cannot be done programmatically. I also disconnected it from the battery. I have tried a dozen times, also changing the eeprom manually and re-saving. and no effect. Immediately after the record was made, I have a message that everything is ok, but when I read it, it reads the old mileage. In the pass, I can confirm that I had similarly that the ecu reset from the program level helped and then the mileage value changed without any problems after turning the ignition on again
  • #50 8778637
    robert199
    Help: 30
    Rate: 289
    Yesterday I was still tired of the Audi and by chance I noticed an interesting thing.
    I attached a regular vag kkl cable to the car and it turned out that I can read the mileage from the meter and, as before in the program, I have a message that the mileage changed correctly, but in fact he did not do it.
    So now the question: what could be the cause? if maybe the drivers, if the cable is damaged. or maybe it is an ordinary kkl but how can I check it?
  • #51 8847487
    domin01
    After changing the mileage, press RESET ECU. We disconnect the facebook as the meter has not corrected, we disconnect the accumulator for a min. 30s. And we are enjoying the new course
  • #52 8890917
    piotr.w.uk
    I bought a Skoda Fabia! .9 SDI 2001. with the counter turned up, I want to restore the previous state. Will VAG K + CAN 1.4 Commander be suitable, or do I have to buy a different cable and soft?
  • #53 8915282
    Hajmus
    Will be ok, the only question is whether you will be able to read the real mileage ;)
  • #54 8915295
    sipowitz
    Help: 8
    Rate: 72
    In this Fabia, 99% of the mileage will not be saved in the engine controller, because, as I understand it, the owner would like to restore the odometer reading based on these indications.
  • #55 8915463
    piotr.w.uk
    The meter reading may be approximate. In the UK, 5-year overviews are stored on a government website, where you can see it if you know the registration number and the last inspection number. This is my first car and it is hard. The last inspection was in 3.2010 and the odometer was 160,000 miles. I bought the car in October 2010 with a mileage of 99,000. I bought the car from a Polish broker and I do not have his data to challenge it, so if I want to do another inspection, I have to change the odometer reading. Hence my question as to what would be good for this purpose. A specialist in the UK told me about ? 100 for this service.
  • #56 8915495
    sipowitz
    Help: 8
    Rate: 72
    Buy a Commander or the simpler VAG Tacho and play with the meter at will. Don't worry about the engine controller, you won't find anything in your car ... ;)
  • #57 8915612
    piotr.w.uk
    in the UK, the following cables are available on Ebay:
    1.http: //cgi.ebay.co.uk/VAG-USB-DIAGNOSTIC-CABLE-409-1-OBD2-II-LEAD-VAG-COM-/330399696070?pt=UK_Diagnostic_Tools_Equipment&hash=item4ced5b44c6
    2.http: //cgi.ebay.co.uk/VAG-K-CAN-1-4-Commander-Diagnostic-Tool-VW-Audi-OBD2-UK-/200549043816?pt=UK_Diagnostic_Tools_Equipment&hash=item2eb1a78e68
    the first one is cheaper, but I don't know if it can do it and how to do it?
  • #59 8922424
    tommi_82
    Hello everyone.
    I bought something like "VAG K + Can Commander 1.4 China", installed VCDS and at the first attempt to run there was a message whether to update the firmware?
    I confirmed that it is, and now it detects the cable as "Ross-Tech Direct USB Interface), it does not create a virtual COM port and it is not possible to establish a connection with it.
    Anyone know how to restore it to factory condition? Maybe it is possible to download the firmware and reinstall?
    I will be grateful for the hints.
    Best regards.
  • #60 8922591
    sipowitz
    Help: 8
    Rate: 72
    Hehe, you dumped FTDI. For example, you need to use Mprog to read the contents from a healthy Commander and program your beaten cable in the same way. Finally, based on the prinscreen from the program with a healthy cable, manually set the parameters and program the FTDI. And do not do more such maneuvers, because it is a waste of time and nerves. And Allegro sellers should be punished for making people brain water ... ;)
The discussion revolves around the VAG K+Can Commander 1.4, particularly the Chinese version purchased from eBay. Users express concerns about compatibility, software issues, and potential viruses associated with the program. Some users report that the software may falsely indicate a virus due to its lack of a dongle, while others mention that it can create tasks in the device manager that may disrupt system operations. There are inquiries about connecting the device to various vehicles, including the VW Caddy and Audi models, and discussions about the need for specific cables and drivers. Users also compare the VAG K+Can Commander with VCDS, highlighting their different functionalities. Several users share links for downloading drivers and software, while others seek advice on troubleshooting connection issues and programming keys for vehicles.
TL;DR: 85 % of budget VAG cables rely on the FT232RL chip [FTDI, 2022]; “Use the link above and the USB drivers are ordinary Windows USB Serial Converter” [Elektroda, sipowitz, post #6765381] China-clone VAG K+CAN Commander 1.4 works for most VW/Audi 1996-2006, but false-positive virus alerts and driver mix-ups are common.
Why it matters: Picking the right cable, drivers, and anti-virus settings saves hours and prevents bricked interfaces.
• Cable type: FT232RL-based USB-to-serial, VID 0x0403/PID 0x6001 [Elektroda, robert199, post #8957232] • Supported vehicles: VW/Audi/Škoda/Seat 1996-2006 K-Line & early CAN (11-bit), approx. 70 ECU types [Commander Manual, 2019] • Typical mileage change time: <5 min, 3 clicks + ECU reset [Elektroda, Medyk_la, post #8589566] • Price range: €18-€35 for China clone; €400+ for genuine HEX-USB+CAN [eBay UK listings, 2024] • OS support: Windows XP-Win10 32-bit native; Win7/10 64-bit needs signed FTDI drivers [Elektroda, labik, post #8213371]
Does VAG K+CAN Commander 1.4 China really contain a virus?
No actual malware was confirmed. Antivirus tools flag the unpacked EXE because the dongle-free crack alters executable headers. Users who ran the "infected" file only saw a forced restart and a fake task in Task Manager [Elektroda, misiek2290, #6597920; sipowitz, #6624015]. Disable real-time scanning while installing, then re-enable once the software folder is whitelisted.
Which drivers do I need for the China clone cable?
Install FTDI VCP drivers (FT232RL). Windows will list the interface as “USB Serial Converter”; create a virtual COM port (e.g., COM3) and match that port number inside Commander [Elektroda, sipowitz, post #6765381]
Can I read ABS fault codes on a 2005 VW Caddy CAN bus?
Yes. Commander 1.4 accesses ABS modules over 11-bit CAN. Select ECU 03 (ABS Brakes) in the drop-down and click “Read DTCs.” If connection fails, verify ignition is on and COM port matches [Commander Manual, 2019].
Three-step how-to: adjusting mileage on a Golf V
  1. Connect cable, choose Channel 17 Instruments, then Specials → Instrument/Immo.
  2. Read current value, enter new KM, press Change.
  3. Hit Reset ECU or disconnect battery 1 min, then cycle ignition. Total time: about 5 minutes [Elektroda, Medyk_la, post #8589566]
What happens if I run VCDS firmware update on the clone cable?
It overwrites the FTDI EEPROM. Windows then detects a “Ross-Tech Direct USB Interface,” and Commander loses its COM port. You must re-flash the EEPROM with MProg using a dump from a healthy cable [Elektroda, sipowitz, post #8922591]
Can I use a genuine VCDS cable with Commander software?
No. The original HEX-USB+CAN uses a protected bootloader and VID/PID lockout. Commander will not detect it [Elektroda, labik, post #8444601]
Is there a universal cable that works with VCDS, Commander, and VAG Tacho?
No. Each tool uses different firmware handshakes. Sipowitz notes “There are no universal solutions” when asked about Tacho and Commander interchangeability [Elektroda, sipowitz, post #6765827]
What’s the simplest way to retrieve the PIN from a 2001 Seat Ibiza with separate Immo box?
Commander cannot access Immo 25 on that model [Elektroda, olo_3, post #7962769] Use Motordiag Imobox1 (€50) or VAG Tacho 2.5, both support that standalone immobiliser [Motordiag, 2023].
Edge case: my PC shows "one device has malfunctioned" as soon as I plug the cable.
The cable’s FT232RL chip may be fried. Driver reinstall did not help for user tomqad; replacement cable fixed the issue [Elektroda, tomqad, post #6884520]
How accurate is Commander for odometer rollback detection?
Commander reads cluster EEPROM and engine ECU where available. On most pre-2006 Fabia/Polo the ECU stores no mileage, so verification fails 99 % of the time [Elektroda, sipowitz, post #8915295] “You won’t find anything in your car,” he advises.
