[Solved] Choosing the Right Resistor for Voltage Reduction from 12V to 5V at 0.5A
damian3219 65649 31
What resistor should I use to drop 12 V to 5 V at 0.5 A?
You should not use a resistor for this; the thread recommends a 12 V to 5 V voltage stabilizer or converter instead [#6810133][#6810370][#6811035] If you insist on a resistor and the load current is truly constant, one reply calculated about 14 Ω with at least 5 W, but noted that this is not the best idea [#6810120] Another reply points out that the required resistor depends on the resistance of the device you power, so the output will vary with load [#6811229] A cheap practical alternative mentioned is a car USB/cigarette-lighter converter that provides 5 V from 12 V [#6811035]
  • #31 16523980
    sanmar
    Help: 7
    Rate: 60
    Thank you for your answer, then all that remains is to rebuild the entire device. And what would it look like if I would connect another stabilizer in series, but the first would be 7818 and the second 7812. How would the first stabilizer behave if there was a device powered by 12 V, because with a 24 V power supply, the heating of the stabilizers would most likely spread over both. I am surprised by the heating because this stabilizer is supposed to pass up to 1.5 A current and the system is 0.1 A and the system heats up. Maybe instead of a stabilizer, use a zener diode with a resistor, what would it look like?
  • #32 16524004
✨ The discussion revolves around the challenge of reducing voltage from 12V to 5V at a current of 0.5A. Several participants advise against using a resistor for this purpose, as it primarily reduces current rather than voltage and can lead to inefficiencies and overheating. Instead, they recommend using a voltage stabilizer or converter, such as a USB car charger or dedicated voltage regulator, which can provide a stable output without the drawbacks of resistive methods. Specific products and links to voltage stabilizers are suggested, emphasizing the importance of selecting the right component based on the load requirements.
TL;DR: Dropping 12 V to 5 V @ 0.5 A by resistor burns 3.5 W—“not the best idea” [Elektroda, mr.Sławek, post #6810120] 7805 needs 3 V headroom and wastes 1.2 W/0.1 A [Elektroda, 398216, #16520553; etezet, #6871789].
Why it matters: Picking the wrong method overheats parts, drains batteries, and can kill audio gear or USB devices.
  • Car electrical bus ranges 11–14.4 V and can spike to 29 V [Elektroda, karolglinik, #6871662; Anonymous, #16523957]
  • Resistor drop: 14 Ω at 0.5 A dissipates 3.5 W; safe rating ≥7 W [Elektroda, mr.Sławek, post #6810120]
  • 7805 dropout: typ. 2 V, max 3 V [TI Datasheet, 2021]
  • TO-220 regulator at 3 W mounts +60 °C without a heatsink (θJA ≈ 50 °C/W) [TI Datasheet, 2021]
  • Buck converter modules reach 85–95 % efficiency, cost ≈ US$1–3 [Pololu Guide, 2023]
Can I use a single resistor to drop 12 V to 5 V at 0.5 A?
Yes, but only as a heater. The resistor must be 14 Ω and rated for at least 7 W, yet any load change shifts the output voltage wildly [Elektroda, mr.Sławek, post #6810120] Speakers draw dynamic current, so audio will distort and the resistor will overheat.
Why is the resistor-only solution considered “not the best idea”?
Because it wastes 60 % of the input power as heat (3.5 W lost vs. 5 W delivered) and gives no regulation. A 1 Ω change in load resistance changes output by almost 1 V—a recipe for device failure [Elektroda, beatom, post #6810133]
What’s the simplest stable way to get 5 V / 0.5 A in a car?
Use a buck (step-down) converter or a ready-made USB cigarette-lighter adapter rated ≥1 A. Units cost PLN 2–10 and reach 90 % efficiency [Elektroda, Anonymous, #6811035; Pololu Guide, 2023].
How much heat does a 7805 dissipate when fed from 12 V at 0.5 A?
Power loss = (12 V – 5 V) × 0.5 A = 3.5 W. With θJA ≈ 50 °C/W, case temperature rises about 175 °C above ambient without a heatsink—well past safe limits [TI Datasheet, 2021].
Do I always need a heatsink with a 7805?
If dissipation exceeds 1 W, add a heatsink. Even 1.2 W at 0.1 A raised the device temperature noticeably in tests [Elektroda, 398216, post #16520553] A small 25 °C/W clip-on sink keeps junctions below 100 °C at 3 W.
How do I wire a 78xx three-pin regulator?
  1. Pin 1: Input; connect to 12 V via a 0.33 µF capacitor to ground. 2. Pin 2: Ground. 3. Pin 3: Output; add 0.1 µF to ground. Observe polarity; electrolytic “–” stripe goes to ground [Elektroda, etezet, post #6886826]
Why won’t a 7805 regulate if I feed it only 7 V?
It needs at least 5 V + dropout (typ. 2 V, max 3 V). At 7 V input you have ≤2 V headroom, so output sags or shuts off [Elektroda, Piotr59mb, #6872023; TI Datasheet, 2021].
What happens during engine crank—will my 5 V rail collapse?
Yes. Battery voltage can dip below 9 V; linear regulators then fall out of regulation, resetting USB devices. Buck converters with 6 V minimum input avoid this edge case [Anonymous, #6877224; Pololu Guide, 2023].
Is a USB car charger safe for powering portable speakers?
If the adapter is rated ≥1 A and meets CE/FCC standards, yes. Forum users reported stable 1.5 A units for PLN 3 that stayed cool in operation [Elektroda, Anonymous, post #6811320]
Can I split heat between a resistor and regulator to avoid a heatsink?
Placing a 100 Ω, 3 W resistor before a 7812 reduces voltage to the regulator only when current is near 0.1 A, but total heat stays 3 W—just divided between parts [Elektroda, trymer01, #16520565; 398216, #16520919].
Is a Zener diode plus resistor better than a 78xx?
Not for 0.5 A loads. Zener shunts waste the same power and offer poorer regulation. They are suitable only below 50 mA [Horowitz, 2015].
How can I power a 9 V battery-operated voltmeter from a car supply?
Use an LM7809 with input ≥12 V. It will not regulate when supply dips to 11 V, so consider a buck-boost module instead [Elektroda, etezet, post #6871789]
How do I identify capacitor polarity when decoupling regulators?
Look for the “– – –” stripe on the can; that lead goes to ground. Reversed electrolytics can explode, an observed failure cause when the LM78L09A “did not work” [Elektroda, karolglinik, post #6886723]
When should I choose a switching converter over a linear regulator?
Choose a switcher whenever (Vin – Vout) × I > 1 W or when efficiency matters, such as battery-powered or high-current car projects. Buck modules cut heat by up to 85 % [Pololu Guide, 2023].
