Celma PRCZ 13 IEO - Installation of the drill and replacement of the drill chuck
3x6 7284 7
  • #1 16739584
    3x6
    In a few days I bought a Celma PRCZ 13 IEO drill. I am green in the field of drills and unfortunately I have a problem with installing the drill. The drill is factory-fitted with a quick-release chuck (at least it seems to me). Just like the picture below:
    Celma PRCZ 13 IEO drill with a quick-release chuck.
    The clamps are hidden, and I don't know how this chuck twists to mount a smaller drill bit. On the handle there are inscriptions GRIP and RELEASE marked with directions. By turning the handle depending on the position, you hear a single click and it does not go any further. If any of you have had contact with this equipment, please give me any advice regarding this handle.
    PS A key chuck was included with the drill, but before that I have to unscrew the one attached at the factory. Should the screw in the handle be turned clockwise?
    best regards
  • #2 16739658
    wiertacz
    Help: 312
    Rate: 384
    The screw inside the handle has a left-hand thread, so you have to turn it clockwise.
    Only to unscrew the handle most conveniently, you need to twist it to a smaller diameter and insert an Allen key into it and tighten it with the handle.
    When the handle is tightly clamped on the spindle, it may be a problem to unscrew it with your hands.
    Ideally, you can still attach a flat key to the spindle.
  • #3 16739711
    wada
    Help: 168
    Rate: 732
    And what is the instruction manual for :?:
    It is one of the best handles
    one ring with a click is a lock of the chuck so that the drill does not loosen during an impact, the second ring is slightly twirling, the jaws should protrude out
    see the end of the movie https://www.youtube.com/watch?v=MFnDhTXgKe8
    GRIP - block
    RELEASE - unlock
    Elefant
    Wagonowa 34, Wrocław, 52-231 | Company Website: literyzmetalu.pl
  • #4 16739973
    3x6
    Unfortunately, there is nothing in the instruction manual about operating the drill chuck, which is why I decided to ask here.
    I've seen the movie before and it didn't help. In my case, one ring is movable, the one with GRIP / RELEASE inscriptions, closer to the hole for the drill, twists, a click is heard, as I understand it is ok. When I try to turn the second ring, the closer to the "body" of the drill, the ring itself does not move, but the entire chuck with the drill spindle. The only thing that comes to my mind is that it is fully unscrewed and you need to use a wrench (I do not currently have one) to hold the spindle and then try to twist this ring to loosen the clamp.
  • #5 16784972
  • #6 16785098
    3x6
    wkam87 wrote:
    I think I have exactly the same problem, I can turn the ring left and right (release / grip), and I hear a click, but just unscrewing the drill hole is all the time to the max, I can't reduce it
    have you managed to solve this problem?
    I wrote to the service and got a reply that the handle is definitely damaged. I sent the drill to a complaint and three days later it returned with a working handle. Unfortunately, I did not receive any information as to what exactly was the cause, but the situation was certainly not due to the lack of operating skills, but a defect or excessive "unscrewing" the handle. A note was attached to the drill so as not to twist / unscrew the handle to the maximum.
    In any case, the drill works as it should :)
  • #7 16786180
  • #8 16965450
    3x6
    I sent the drill to the service and the fault was removed. I can add that the contact with the service was very good and the service was really express.
The discussion revolves around the installation and operation of the Celma PRCZ 13 IEO drill, specifically focusing on the quick-release chuck mechanism. The user encountered difficulties in understanding how to install a smaller drill bit due to the hidden clamps and the operation of the GRIP and RELEASE handles. Responses indicated that the screw inside the handle has a left-hand thread, requiring clockwise rotation to unscrew. Some users noted that the chuck may be damaged if it does not operate as expected, and one user successfully resolved their issue by sending the drill to service, which confirmed a defect in the handle. The service experience was reported as efficient and satisfactory.
