Renault Clio III - Manual Oil Inspection Reset: Deleting Light with Drop, Bowl, Orange Key
oidakra 138925 8
  • #1 7110642
    oidakra
    Rate: 99
    Do any of you know how to manually delete the inspection in this model?
    A light with a drop of oil and a bowl and a large orange key are on.
    There are no errors in any driver.
    If anyone knows how to do it, I would ask for a hint.
    azyl85
    Help: 7
    Rate: 61
    Try this: Turn the ignition on. Press the reset button [A], Fig.26., Until the spanner symbol lights up. Press and hold the button until the key symbol goes out or glows steadily. The correct maintenance interval is then displayed (e.g. 10,000 km). Release the [A] button. Turn off the ignition system.
  • #3 7116624
    oidakra
    Rate: 99
    hmm ... thanks for any response, but gosh, which "A" button is it ??
    There are no knobs at the clocks, only the control is at the steering wheel ...: /
  • #5 7118887
    oidakra
    Rate: 99
    Thanks colleagues for the hints :)
    Today I will try to check it out. I will let you know if I succeeded or not ..
  • #6 7135209
    oidakra
    Rate: 99
    Only today I had time to drive up to the guest and do it to him ...
    Of course, all without any problems according to the above tips.
    Thanks great colleagues.
  • #7 21050602
    pio33_67
    It should be added that it is not about turning on the ignition, but the engine must be started and then, after the oil information goes out, we press the button. I was struggling with this today.
  • #8 21050859
    kostrze
    Help: 12
    Rate: 41
    And disconnect the battery for a few seconds.
  • #9 21051485
    milejow
    Help: 1563
    Rate: 5149
    And why? All you will get is zeroing the periodic waveform
    Działalność własna
    Mętów 99, Lublin, 20-388
The discussion revolves around resetting the manual oil inspection light on a Renault Clio III, which displays an oil drop and bowl icon along with a large orange key. Users provided a method to reset the light by turning on the ignition, pressing a specific reset button until the spanner symbol lights up, and then holding it until the key symbol goes out. Clarifications were made regarding the button's location, with some users suggesting that the engine should be started instead of just turning on the ignition. Additional suggestions included disconnecting the battery for a few seconds, although this was debated as potentially unnecessary.
