Comparing Range of 70cm vs 2m Bands on Nagoya 666 Antennas with Yaesu VX3 & ICOM IC E90 Radios
sexijan 30413 10
With the same transmitter power and equal-height base antennas, which band gives greater range: 2 m (144 MHz) or 70 cm (430 MHz)?
With equal-height base antennas and the same power, 2 m (around 144–150 MHz) will generally give greater range overall, but 70 cm (around 430–450 MHz) can perform better in dense urban areas because of better building penetration and reflections [#7216444][#7224800] The Nagoya 666 test is not a clean comparison because the antenna gain differs between bands; one reply says the 70 cm side may have been working about three times more effectively, and receiver sensitivity differences can also affect the result [#7218249] For a reliable comparison, use proper single-band antennas with the same gain and mounting height, not a dual-band antenna with different band performance [#7226581][#7218249] In practice, 2 m is usually better in open terrain and forests, while 70 cm can be advantageous in heavily built-up areas [#7224800][#7216939]
  • #1 7215895
    sexijan
    Recently, with a friend, I tested the range of Nagoya 666 antennas on Yaesu VX3 and ICOM IC E90 radios.
    I performed the test in a city in a heavily built-up area in Silesia. Both radios were outdoors. On the 2m band we could barely hear each other after about 1km, after changing the frequency to 70cm we could talk comfortably up to about 4-5km.
    If I had base antennas with the same gain for the 70cm and 2m bands mounted on the roof at the same height, which band would I get a greater range with the same power?
  • #2 7216444
    SP5ANJ
    Rest in Peace
    Help: 1382
    Rate: 656
    Of course, frequencies around 150MHz are definitely better than frequencies around 450MHz.
    Better means that with lower power you can achieve a greater connection range.
    ____________
    However, I wonder about the question itself???
    Which band is better, 70cm or 2m?
    Because it's obvious.
    I will ask - at what frequencies were the range tests performed? ??? :?:
    Regards.
  • #3 7216483
    sexijan
    tests performed at 144MHz and 430MHz
  • #4 7216610
    Adik
    Help: 28
    Rate: 36
    Mainly when it comes to the band, it's ok, but I don't think tests could have been done at these frequencies, and if they were, there's something wrong.
  • #5 7216939
    Moskit
    Help: 17
    Rate: 39
    I do not entirely agree with the previous speakers because the operation of the 70 cm and 2 m bands depends on the terrain. According to my knowledge, radios in the 2 m band work better in mountainous areas, i.e. hills, hills and built-up areas.\ (see uniformed services - they work in the 2m band), which means no matter how you look at it, it is the southern part of Poland. However, the 70 cm band will certainly perform better in open plains, i.e. central and northern Poland. If I'm wrong, please correct me :)
  • #6 7217540
    uważny_czytelnik
    SP5ANJ wrote:
    Of course, frequencies around 150MHz are definitely better than frequencies around 450MHz. Better means that with lower power you can achieve a greater connection range.
    The 450 MHz band was chosen to create NMT mobile networks not by accident. In dense buildings it performs much better than 150 MHz (smaller QSB, better building penetration). The author's attempts confirmed this.
    Why couldn't these tests be done? What do you think is "wrong" with these frequencies (bands)?
    Moskit wrote:
    According to my knowledge, radios in the 2m band work better in mountainous areas, i.e. hills, hills and built-up areas.\ (see uniformed services - they work in the 2m band)
    In large agglomerations (dense development), uniformed services have moved to 450 and 380 MHz. In even larger agglomerations, with even denser development, they use the 800 MHz band.
  • #7 7218249
    MariuszC
    Help: 8
    Rate: 15
    Friend sexijan, the test on duobander antennas was heavily distorted by different antenna gains for the 2m and 70cm bands (do not be guided by the single value of 2.15 dBi for this antenna). I would conservatively assume that in the 70 cm band the antennas worked three times more effectively. Hence the large disproportion in the ranges achieved. Any difference in the sensitivity of receivers on these bands also had some significance.
    As for your question - I can answer from experience that in forested areas the range at 70 cm is several times smaller than at 2 m. That's why the Forest Service uses very low VHF. I don't have much experience with such comparisons in built-up areas, so I won't comment.
    Regards
    Mariusz
  • #8 7219920
    sexijan
    Let me just remind you that the antenna is 23 cm long, the gain of this antenna is 2.15 dB, but it is probably different for both bands.
    However, the test cannot be reliable because at the 144MHz frequency the antenna works as 1/8 wave and at 430MHz as 3/8 wave, which could result in better performance on the 70cm band.
    I used the antenna calculator from this website:
    http://www.csgnetwork.com/antennaevcalc.html
  • #9 7224800
    tinek
    Interesting topic. A program for calculating ranges was once described in the "Świat Radio" magazine (it was also discussed on the electrode). I did a simulation with this program. I chose a random point in Katowice and drew the ranges for 144Mhz in yellow and for 430Mhz in green. As you can see, on 144Mhz the range is greater. Please note that I have not fully explored this program and there may be errors in the calculations. This is probably due to the fact that at a lower frequency, Fresnel lines have a larger radius and overcome the curvature of the earth and terrain.
    On the other hand, in urban areas, higher frequencies, as my colleagues have described, will be more effective, with better penetration and greater reflections.
  • #10 7225686
    sq6ade
    Level 40  
    Help: 482
    Rate: 285
    At 2 meters it flies further, whether it's a city or a village - these are my observations after quite a long time of beating foam from the mobile. But for 70 it's looser and cheaper ;)
  • #11 7226581
    Radiowiec 2
    Help: 93
    Rate: 236
    Sexijan, take a look at the telecommunications manual. The model for the propagation of 430 MHz waves and similar is described there. Study the model of Okumura and Walfisah Ikegami. There is also the Bulington model. It is clear from this that: If you test on a 5/8 lambda monobander (for 145 MHz) at altitude transmitters in the base and on the car. Then the result will be reliable, otherwise it won't. Moreover, waves above 300 MHz propagate between buildings and in bunkers and mines as if through waveguides. And the penetration through concrete walls varies depending on the amount of iron in the walls. It's similar in the city. Regards ! :) )
✨ The discussion centers on the comparative range performance of Nagoya 666 antennas on Yaesu VX3 and ICOM IC E90 radios across 2m (144MHz) and 70cm (430MHz) bands in a densely built-up area in Silesia. Initial tests indicated that communication was limited to about 1km on the 2m band, while the 70cm band allowed for clear communication up to 4-5km. Participants debated the inherent advantages of each band, noting that lower frequencies (2m) generally provide better range in open areas, while higher frequencies (70cm) perform better in urban environments due to improved building penetration and reduced signal fading. The effectiveness of antennas at different frequencies was also discussed, with considerations of antenna gain and propagation models influencing the results. Overall, the consensus suggests that while 2m may have a theoretical advantage in open terrain, 70cm is more effective in urban settings.
