Installing Ham Radio Antenna on Roof: Mast Height Regulations, Diamond X-510N & X-50N Options
kamilalek1 7773 10
Can I install a rooftop ham radio antenna without permission if the mast is under 3 m, and does the antenna length count toward the limit?
No—the thread does not support a simple “3 m mast = no permission needed” rule; respondents say you need the building owner/manager’s consent, and the local building supervision authority decides whether the installation needs notification or a permit, with one reply stating that the whole structure (mast plus antenna) is counted and that a mast over 2.5 m may require a permit [#16633941][#16634551][#16633744] So a 2.99 m mast with a 5.2 m antenna is not clearly legal without permission just because the mast itself is under 3 m; the stricter view is that the antenna is part of the installation and the total structure matters [#16634551][#16633744] For a building run by a housing cooperative, approval may also be refused and conditions such as grounding measurements can be imposed [#16672211]
  • #1 16633043
    kamilalek1
    Rate: 41
    I am planning to install an antenna on the roof in the near future.
    From what I heard from my friends, if the mast on the roof is over 3m, you should report it and wait for the permit, while if your mast is below 3m, you don't have to report it anywhere.
    Is what I wrote above true.
    If so, can I install 2.99m without permission and on this mast a 5.2m omnidirectional antenna
    https://www.inradio.pl/sklep/anteny-vhf-uhf/a...e-ukf/163/antena-bazowa-diamond-x-510n-detail
    Or only, for example, a 1.2 m mast and a 1.7 m antenna on it
    https://www.inradio.pl/sklep/anteny-vhf-uhf/a...we-ukf/159/antena-bazowa-diamond-x-50n-detail
  • #2 16633051
    Rezystor240
    Help: 689
    Rate: 1652
    If that's true.
    kamilalek1 wrote:
    can I mount it without a permit?
    This is a 299cm mast "should be legal".
  • #3 16633076
    kamilalek1
    Rate: 41
    Yes, most people said that the mast could be a maximum of 3m.
    However, opinions on whether an antenna can be mounted on such a mast were divided
    - some people say that the antenna can be a maximum of 3 m above the roof level, so if the mast is 3 m, you cannot mount the antenna on it without permission, you can only use 1.2 m and a 1.7 m antenna so that the whole thing is not exceeded 3m.
    - at the same time, several people claimed that I can easily mount a 5m antenna on the mast, that only the height of the mast cannot exceed 3m because then you need to obtain permits, while the antenna can be of any length (read above 3m)
  • #4 16633080
    Rezystor240
    Help: 689
    Rate: 1652
    kamilalek1 wrote:
    several people claimed that I can easily mount a 5m antenna on the mast, that only the height of the mast cannot exceed 3m because then you need to obtain permits, while the antenna can be of any length (read over 3m)
    I am of this opinion too.
    But it all depends if you live with the guys who oversee everything and even crap calling the guys who are talking on 172.250 MHz.
    Or you live where nobody sticks their nose where they don't need it (optimistic option).
  • Mast permit threshold is 2.5 m
    #5 16633744
    jkk
    Help: 31
    Rate: 40
    As far as I remember, a building structure (mast here) is subject to a building permit if its height exceeds 2.5 m (it must be checked in the current Construction Law). Below this height, an application is sufficient. Unfortunately, the object, based on logic (even official), is the whole, i.e. the mast with the antenna. :( . That's why I prefer wire antennas because they are less conspicuous and effective. And you can always explain to the nosy neighbor that it's a wifi antenna. Why is it so long? Because I, a neighbor, download long files from the net ...
  • #6 16633928
    Rezystor240
    Help: 689
    Rate: 1652
    If the neighbor is an IT specialist, this excuse will not work.
  • Building owner consent required for any antenna mast
    #7 16633941
    gumisie
    Help: 1667
    Rate: 2486
    kamilalek1 wrote:
    however, if your size is below 3m, you do not need to report it anywhere.
    Most of what is written here is "NOT TRUE". It all depends on the administrator or owner of the building. Without his consent, you do not have the right to mount any antenna, including satellite, terrestrial TV and especially to put up some masts.
    Edit:
    Post col. c2h5oh , dispelled any statements you made about this problem.
  • Building permit needed for antenna mast installation
    #9 16634551
    jkk
    Help: 31
    Rate: 40
    Let us distinguish between two consent. The first is the consent of the roof manager (and the rest of the building) for the antenna installation. The topic is eliminated when we ourselves are. If not - then there are negotiations (with the manager: owner, cooperative or housing association) - and this topic has been raised many times. The second (even more important) is the consent of the local Building Supervision Authority to perform the works. The Construction Law specifies in detail which construction works and changes in a building structure or its part are subject to the notification of works, and for which a building permit must be applied for. An antenna mast is such a structure - regardless of whether it is on the roof or on the ground. Of course, let's not go to extremes - you do not need such procedures for a meter-high pipe by the chimney, but for something larger ...
    In the nearest poviat Construction Department (starosty or in the district town hall) they will also tell you which receipts and consents must be collected for the installation. Of course, you can bypass it all and quietly put it down - but it can get really warm, like all this - on a windy day, it will go off the roof on someone's car or head - then the Prok will definitely ask for such receipts - and it can be uninterestingly done. . Even if it falls off your private roof! Unless some informant neighbor kindly reports to PINB and sends a demolition order. And as for wifi - it's a joke, of course, although a dilettante neighbor might swallow it :D
    Moderated By c2h5oh:
    However, it is worth taking a look at the link from the topic above.
  • #10 16670710
    kamilalek1
    Rate: 41
    I even asked in and heard two versions :(
    1. If the mast exceeds the height of 3m, it should be reported, the length of the antenna does not matter. So the mast can be 2.5 m and the antenna 5.2 m and it does not need to be reported
    2, However, I agree with the second version: So if the mast is, for example, 2m long and the antenna 1.2m in total, 3.2m in total, it should be reported because the structure exceeds 3m.
    However, I will not worry about it because I decided to use a 1m mast and a 1.8m antenna, I planned to buy a bigger one, but I changed my mind (I had an opportunity)
  • #11 16672211
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1008
    You may not get a permit to install the antenna on the roof of a building administered by the Housing Cooperative. The roofs of the buildings are covered with heat-weldable roofing felt and the company providing the covering provides a warranty for the above-mentioned covering for about 25 or 30 years Covering. In the event of approval for the installation, the Cooperative will set the conditions for the installation and present the protocol for measuring the grounding of the antenna mast.
The discussion revolves around the installation of ham radio antennas on roofs, specifically addressing mast height regulations. It is generally agreed that a mast exceeding 3 meters requires a permit, while a mast below this height does not. However, opinions vary on whether the total height of the mast plus antenna must also be considered. Some participants argue that the antenna can exceed 3 meters as long as the mast itself is under 3 meters, while others believe that the combined height must not exceed this limit. The conversation also highlights the importance of obtaining consent from building managers and local authorities, as well as the potential complications with housing cooperatives regarding installation permissions. Users also discuss alternative antenna options, such as the Diamond X-510N and X-50N models, and the practicality of using less conspicuous wire antennas.
