A big test of small antennas for amateur handheld radios 2m / 70cm
djbpm 14169 14
  • Several dozen handheld antennas and 3 car antennas were compared for amateur 2m and 70cm radios, including Retevis RHD771, Nagoya NA-771, Diamond NR-770H, and factory whips.
  • Testing combined NanoVNA-H4 S1P/SWR measurements with field signal checks from a Yaesu VX-6 handheld, using both hand-held and counterweight-base configurations.
  • Field measurements used 144.9875 MHz and 434.9875 MHz at 185 meters, with each antenna transmitting for about 15–20 seconds.
  • The 2m band showed a 23.72 dB spread between the weakest and strongest antennas, while acceptable-length handheld antennas performed much better on 70cm.
  • The handheld radio had to tolerate very high SWR, and long telescopic antennas worked well but broke quickly and could crackle.
  • A big test of small antennas for amateur handheld radios 2m / 70cm
    Hello everyone.
    Recently, I have measured several dozen handheld antennas and 3 car antennas in the amateur 2m and 70cm ranges in an amateur way.
    Here is the list:
    01 Retevis RHD771 (2.15dBi) Aliexpress RETEVIS Official Store
    03 Nagoya NA-771 (2.15dBi) Aliexpress?
    07 Yaesu VX-6R Factory attached to the radio
    08 Wouxun KG-UV8D Factory attached to the radio
    09 Harvest RH660S (3.0 / 5.0 dBi) Aliexpress BlueRadio store
    09skr as above but it was only extended to work at 70 cm
    partially so that the SWR is approx.
    as above
    10 Self-made on the pattern 771 Sam robilem
    11 Diamond NR-770H (3.0/5.5dBi) InRadio
    12 Nagoya NL-770H (3,0/5,5 dBi) HamRadioShop
    13 Nagoya NL-770R (3,0/5,5 dBi) HamRadioShop
    14 Nagoya NA-666 (2.15 dBi) ?
    15th Nagoya NA-771 (2.15dBi) ?
    16 Baofeng BFG-A-3 ?
    17 Baofeng UV-3 Fabryczna dołączona do radiotelefonu
    18 ICOM FA-S270C Factory attached to the ICOM E90 radio
    19 Baofeng DM5 Factory attached to the radio
    twenty Baofeng UV5 Factory attached to the radio
    21 Nagoya NA-771 ?
    22 Kenwood KRA-23M factory included with the NX-200 radio
    23 Kenwood TH-D74 Factory attached to the radio
    24 Yaesu FT-5D Factory attached to the radio
    25 Anytone 878 Factory attached to the radio
    26 Alinco DJ-G7 Factory attached to the radio
    27 Yaesu VX-2 Factory attached to the radio
    28 ICOM MARINE? Factory attached to the marine radiotelephone
    29 Kenwood NX-320 E2 (KRA-27?) 70cm Factory attached to the radio
    thirty ? Miniature something at 70cm Aliexpress
    31 Sagem 70cm ?
    32 Yaesu Standard Horizon CAT-460 Factoryattached to the radio
    33 MDVM HS DUAL Factory attached to the hotspot
    35 Diamond RH-771 ?
    36 Nagoya NA-771 ?
    37 Nagoya NA-701 ?
    38 ? without description, base similar to Wouxun ?
    While the originality of the antennas included in the factory with the equipment does not raise any doubts, it can be different with each other. If I was sure that a given antenna is a counterfeit, it would be marked.
    A big test of small antennas for amateur handheld radios 2m / 70cm A big test of small antennas for amateur handheld radios 2m / 70cm
    The measurement was carried out in 4 rounds, in which I measured the S1P parameters (including SWR) and the signal level emitted from each of the antennas under field conditions.
    S1P measurements with the NanoVNA-H4 analyzer:
    1. Antenna placed directly on the NanoVNA-H4, and measurement with the Analyzer in the hand, close to the head, held like a handheld transceiver.
    NanoVNA calibration took place directly on its socket in the frequency ranges 120 to 170 MHz and 400 to 470 MHz
    2. Antenna on the base with counterweights and NanoVNA measurement.
    NanoVNA calibration was done on the base slot, eliminating the influence of the adapters used to connect the base. Ranges as above. If the antenna required an additional adapter, then this adapter was not calibrated, so the SMA barrel extends the line by 155 picoseconds, and the SMA - UC1 socket is 327 picoseconds, and this UC1 adapter has 43 ohms of wave impedance. The influence of these adapters is noticeable in the 70cm band, especially on the Smith chart, but it is not big and for the purposes of this test it can be omitted.
    Signal level measurements:
    3. Antenna on Yaesu VX-6 handheld radio and signal level measurement on base station.
    4. Antenna on a base with counterweights and a base on a Yaesu VX-6 and measuring the signal level on the base station.
    Measurements 3 and 4 were carried out at a distance of 185 meters from the base antenna, in an urban area, in a densely built-up housing estate, but in the field of optical visibility of the antennas. I walked about 15 meters with the PTT pressed at full power and the device at my head, just like I would normally use it to make communications. I tried to keep the device as vertical as possible so that the polarities of the antennas were consistent. There were no obstacles on the walking route in the immediate vicinity. In the case of walking with the counterweight base, these counterweights were placed a few cm above the head, so then the antenna was about 30cm higher than when broadcasting without counterweights, which could have a false positive effect in favor of the counterbalance system.
    At the base station, the signal was picked up by a Diamond X50N antenna installed about 10 meters higher than the towel rail, giving an angle of 3.1 degrees. The signal came through a 10 dB attenuator, an RTL-SDR tuner working with the SDR ++ application, set to minimum gain, all AGC off, sampling 1536 kHz, division / 8 giving 192 kHz. The spectrum was recorded to an IQ .wav file. The center frequency of the SDR was set 50 kHz higher than the handheld transmitter, and as a result, the recording showed a carrier signal with a frequency of 50 kHz. The recording was filtered with a 49 kHz - 51 kHz bandpass filter. After such a cleaned recording, the noise level was -59 dB. 0dB is the SDR overload level, so the results are in the range of -59 dB is the minimum level to 0 dB is the maximum level (they are negative).
    Each antenna transmitted for about 15-20 seconds, and from this time the average RMS level expressed in dB was calculated.
    An example recording chart opened in an audio processing program looks like this:
    There are clear differences between the individual antennas. I've already selected sample 35 on it, then zoom in:
    and I mark precisely the beginning and the end. You can see here that the signal level fluctuates as it travels. Then I use the statistical analysis function which gives me this information:
    Screenshot from signal statistics software showing average RMS power indicated at -18.99 dB.
    I am writing back Average RMS Power.
    The measurements with the hand towel were performed on the frequencies 144.9875 MHz and 434.9875 MHz.
    Measurements made from antenna No. 14 took place only without counterweights.
    Results for the 2m band:
    number Antenna Signature level
    out of hand
    SWR
    out of hand
    Impedance Signal on
    counterweights
    SWR from pw The impedance from the
    01 Retevis RHD771 -22.24 4.10 29.55 -55.18i -13.27 5.31 10.23-14.47i
    03 Nagoya NA-771 -21.94 3.83 49.01-71.55i -12.63 3.66 15.37-16.83i
    07 Yaesu VX-6R -25 4,61 29,72 -61,55i -19,7 5,74 09,87 -17,92i
    08 Wouxun KG-UV8D -26,5 7,11 31,67 -89,32i -26,91 18,19 06,68 -59,56i
    09 Harvest RH660S -9,88 1,02 50,73 00,60i -7,82 1,07 52,39 -02,17i
    10 Samoróbka 771 -18,52 1,22 57,99 06,95i -17,91 6,95 166.82 -169,83i
    11 Diamond NR-770H -8 1,23 51,12 10,63i -6,44 1,16 48,04 07,10i
    12 Nagoya NL-770H -11,59 1,79 68,49 -29,26i -9,59 1,78 64,28 -29,83i
    13 Nagoya NL-770R -8,36 1,52 33,20 -03,87i -6,55 1,41 36,06 04,67i
    number Antena Poziom sign.
    z ręki
    SWR
    z ręki
    Impedancja
    14 Nagoya NA-666 -30,18 7,85 26,56 -85,99i
    15th Nagoya NA-771 -21,19 1,92 59,32 -34,85i
    16 Baofeng BFG-A-3 -26,68 3,00 18,05 13,46i
    17 Baofeng UV-3 -28,78 4,43 17,65 -35,98i
    18 ICOM FA-S270C -26,87 3,96 31,44 -56,04i
    19 Baofeng DM5 -24,97 1,88 27,22 -06,15i
    20 Baofeng UV5 -27,9 3,04 20,18 -22,07i
    21 Nagoya NA-771 -24,68 3,79 43,70 -66,72i
    23 Kenwood TH-D74 -28,34 6,33 30,94 -81,16i
    24 Yaesu FT-5D -23,54 1,13 53,18 -05,61i
    25 Anytone AT-D878 -24,11 1,37 43,23 -13,06i
    26 Alinco DJ-G7 3pasma -26,69 3,63 69,47 -78,97i
    27 Yaesu VX-2 -25,88 1,90 43,98 -29,96i
    28 ICOM MARINE -29,62 7,75 27,11 -86,30i
    32 Yaesu Standard Horizon -29.99 11,44 23,36 -102,08i
    34 Astro 320 127cm -14,99 2,59 96,68 -50,43i
    35 Diamond RH-771 -18,99 1,72 85,63 05,67i
    36 Nagoya NA-771 -21,79 3,61 49,37 -68,29i
    37 Nagoya NA-701 -24,08 3,09 40,51 -52,58i
    38 Wouxun? -22.1 1.99 79.59 32.86i
    Due to the fact that the negative units of the signal level are not very intuitive, for the purposes of the graph, I added +31 dB to each antenna so that all the results were positive.
    Results for the 70cm band:
    out of hand
    SWR
    out of hand
    Impedance Signal on
    counterweights
    01 Retevis RHD771 -11.83 1.57 64.47 21.41i -14.45 1.66 63.37 25.36i
    03 Nagoya NA-771 -15.59 2.47 99.53 -43.50i -15.25 2,01 91,23 -24,50i
    07 Yaesu VX-6R -19,44 3,27 36,61 -51,99i -18,64 4,53 14,80 -28,28i
    08 Wouxun KG-UV8D -18,59 3,31 108,81 -72,83i -14,2 1,23 59,70 05,76i
    09 Harvest RH660S -14,54 1,31 63,95 -06,13i -14,62 1,37 64,10 -10.95i
    09skr Harvest RH660S skrócona -14,02 1,01 49,35 00,10i -13,79 1,04 51,90 -00,49i
    10 Samoróbka 771 -11,98 1,27 39,66 -01,93i -13,13 1,45 34,67 02,63i
    11 Diamond NR-770H -11,21 1,06 51,88 02,60i -10,52 1,22 42,50 -05,09i
    12 Nagoya NL-770H -13,61 1,63 30,6101.14i -11.59 1.85 27.22 -03.46i
    13 Nagoya NL-770R -20.55 2.36 50.72-44.59i -13.86 2.51 27.21 -26.67i
    out of hand
    SWR
    out of hand
    Impedance
    14 Nagoya NA-666 -19.85 5.82 121.36-138.41i
    15 Nagoya NA-771 -18.07 5.02 244,36 -39,54i
    16 Baofeng BFG-A-3 -20,47 1,70 55,85 -27,88i
    17 Baofeng UV-3 -17,28 1,20 54,95 07,97i
    18 ICOM FA-S270C -22,52 3,38 30,10 -46,16i
    19 Baofeng DM5 -16,61 1,72 85,59 05,65i
    20 Baofeng UV5 -16,63 1,74 83,53 -13,37i
    21 Nagoya NA-771 -21,74 6,69 23,39 -70,37i
    22 Kenwood KRA-23? -18,64 2,06 70,31 -38,90i
    23 Kenwood TH-D74 -22,65 3,07 38,17 -50,25i
    24 Yaesu FT-5D -23,28 3,90 27,32 -49,26i
    25 Anytone AT-D878 -17,8 1,95 76,32 -32,73i
    26 Alinco DJ-G7 3pasma -23,07 2,42 40,57 -40,08i
    27 Yaesu VX-2 -22,47 2,70 43,26 -47,67i
    29 Kenwood KRA-27? -20,22 2,46 54,49 -48,29i
    30 Miniaturowa -22,68 1,84 51,83 -31,57i
    31 Sagem 70cm -21.9 3,71 183,21 -18,91i
    33 MMDVM HS DUAL -19,83 1,39 47,75 16,04i
    35 Diamond RH-771 -14,83 1,18 55,47 -06,71i
    36 Nagoya NA-771 -18,74 3,49 39,18 -57,91i
    37 Nagoya NA-701 -20,41 3,66 48,98 -68,74i
    38 Wouxun? -19,08 3,19 57,18 -65,15i
    Tu również dodałem +31 dB.
    Conclusions:
    - The handheld radio must be able to withstand a very high SWR.
    - Handheld antennas of an acceptable length work much better in the 70 cm band than in the 2 m band.
    - The difference in the signal level in the 2m band between the weakest antenna and the strongest one was 23.72dB. So we would have to use 236 watts from the weakest antenna to get the same signal level from 1 (ONE) watt from the strongest. For the record decibel calculator
    - The typical "gain" of a handheld antenna in the 2m band is strongly negative and is in the range of -10 to -20 dBi.
    - Counterweights help greatly in the 2m band, while their use with a towel is impractical.
    - Telescopic antennas, especially the long ones, are very effective, but they break down quickly and can crackle. Example of Astro 320:
    Finally, here are the Smith and SWR charts:
    01 03 07:
    A big test of small antennas for amateur handheld radios 2m / 70cm A big test of small antennas for amateur handheld radios 2m / 70cm A big test of small antennas for amateur handheld radios 2m / 70cm
    08 09 10:
    11 12 13:
    14 15 16:
    17 18 19:
    20 21 22:
    23 24 25:
    26 27 28:
    29 30 31:
    32 33 34:
    35 36 37:
    38:
    I wish you distant communications
    djbpm
    djbpm
    djbpm wrote 586 posts with rating 161, helped 76 times. Live in city -. Been with us since 2003 year.
  • Request for clearer antenna test explanation
    #2 20084428
    zgierzman
    Help: 108
    Rate: 1573
    You know, I've read a bit about antennas, I get the decibels, I even have NanoVNA and can roughly use it.
    I studied your text three times before I understood enough to figure out what the author meant.
    Maybe you could change your post enough for even an average bafeng fan to know what's going on?
    And on top of that you throw the antenna "I did it myself" and nothing about it - maybe some article about this antenna? Did you do what you got, what didn't work, etc.?
    Yes, I know, the electrode is an advanced forum. But take it easy, since you're fasting no is on the forum: "ham radio / antenna construction / RF secrets" only in "articles", then you should take into account that the readers will not catch the nuances of the sentence: "You can see here that the signal level fluctuates with movement, and you can see the differences between the antennas. " if you don't post an additional comment.
  • #3 20084592
    ptero
    Help: 68
    Rate: 179
    "How did you impress me" :) Now I am asking for a summary in Polish :)
    Now, as a less advanced one, I will ask which antenna for "baofeng" on 2m would you recommend?
    Regards
  • #4 20084749
    Wikita
    Help: 11
    Rate: 17
    From the author's comparison of 2 m, the best antenna is No. 11, ie Diamond NR-770H -> the variant without counterweights gives us as much as -8 dBFS on the receiver, with SWR = 1.23 (which is decent because we have 1% reflected power).
    As for the article, it's a good job. It takes a lot of time to collect so much data :)
  • Car antennas with the strongest 2m performance recommended
    #5 20084935
    djbpm
    Help: 76
    Rate: 161
    zgierzman wrote:
    But I studied your text three times before I figured out what the author meant ... Maybe you could change your post enough for even an average bafeng fan to know what's going on?
    Now that you know what's going on, maybe you can help write it in a simpler way? This is my first entry of this type, I am not a Polish teacher. I did not want this analysis to go to waste and only a few people used it, because it was a lot of work.
    There is probably no such section, but there is very specific information here which fragment is incomprehensible. The horizontal axis was missing, at first glance you do not know what is on it, and it is time. In addition, I added more details, but it makes the whole thing even longer, so bad anyway. But is it better now?
    I also threw in there other antennas that do not know what they are. This article is not about the self-made, I don't want to water down the topic.
    ptero wrote:
    "How did you impress me" :) So now I am asking for a summary in Polish :)
    Now, as a little advanced one, I will ask which antenna for "baofeng" on 2m you would recommend.
    Zoom in on the chart A big test of small antennas for amateur handheld radios 2m / 70cm look at the green bars, find the biggest one. Then check if the antenna structure and its price are acceptable. If not, look for another tall green bar. The 770 type car antennas are the most powerful. They can be used on a handheld radio, although it is inconvenient and may break the antenna socket. The most powerful handheld antenna is the Harvest RH660S, but it is a meter long telescopic antenna, also bulky, and breaks down and crackles over time. We continue to fly so sharply down that it's a waste of words. Added to this is the problem of counterfeit products and repeatability of production. Note that I measured several NA-771 antennas and almost all came out differently.
    Thanks for this comment, and for putting in the correct dBFS unit.
  • #6 20087318
    sq3evp
    Help: 226
    Rate: 901
    Congratulations on your willingness to conduct research.
  • #7 20088960
    moon09
    Rate: 54
    Very good job, hats off :)
  • Suggests S21 measurements for antenna efficiency comparison
    #8 20089084
    tplewa
    Help: 222
    Rate: 1009
    Good job :) Interesting results, although in some cases predictable ;)
    Once Jarek SP3SWJ took measurements with his MAX 6 and the results were also interesting :)
    A big plus, because after all, it's a bit of work to collect data (measurements) and process the results.
    btw When it comes to some comparison of the antenna efficiency, and even with coarse directional characteristics, you can measure S21 (then we have two antennas on the ports, one tested - the other is our measuring one) - that's something like this https: //www.rtl-sdr .com / measuring-the-radiation-pattern-of-a-yagi-antenna-with-a-nanovna /
  • S21 testing fails on handheld antennas due to cable counterweight
    #9 20090214
    djbpm
    Help: 76
    Rate: 161
    Predictably, but you were hoping to find something sensible up to half a meter.
    I tried to measure similarly and in the case of hand antennas it does not work, because the cables become a counterweight, which has nothing to do with the way a hand antenna works normally. The impact of the full counterweight is huge, and the cable is also quite random and random, it depends on how the cable goes, so the results will differ significantly from how the antenna works in your hand. In the case of a stationary antenna, such a test makes sense. I tested it on counterweights and used the Diamond NR-770H as the receiving antenna, but as I wrote before, I got nice graphs, only useless.
    edit:
    I ordered 3 Retevis RHD771 (2x SMA-m, 1x SMA-f) because of their good performance in the 70cm band, and they came yesterday. Repeatability so-so. The S1P comparison looks like this:
  • Nagoya 701 preferred for handheld convenience
    #10 20090787
    tplewa
    Help: 222
    Rate: 1009
    All in all, as I mentioned once, the measurements of Jarek SP3SWJ were visible, I accepted it myself and use Nagoya 701 (the stick knows if they are originals or fakes).
    Mainly due to the fact that a short and flexible rally does not stick in a person's hips, etc.
    How it works - chewing rags from a towel on FM / DMR / D-Star or using APRS somehow gives advice :crazyeyes:
    As for the measurements so quickly - it's a pity to talk 8-O
    I think I've come to terms with it and I don't even take such measurements :) Therefore, I am not surprised by these results :)
    At home, I have towels attached to Yagi 2m / 70cm DK7ZB (2 + 2el) just quickly made of tubes available in Castorama and printed elements https://www.thingiverse.com/thing:5328693 - which is basically some negligible costs and the problem of antennas from the bottom is solved ...
  • #11 20091302
    BOOM i ZONK
    Help: 21
    Rate: 73
    Do you know what I miss in this statement? Something as trivial as a tuned quarter-wave piece of wire just soldered into a plug.
  • #12 20091494
    sq3evp
    Help: 226
    Rate: 901
    Yes - such a simple basic antenna for comparison, such a simple "quarter".
  • Quarter-wave wire and antenna quality concerns
    #13 20091994
    djbpm
    Help: 76
    Rate: 161
    The reference antenna is usually a half-wave dipole. But maybe I will test something else. There will be what, there will be time, why not. Such a quarter is easy to make, but the quarters work very poorly without a counterweight, so I would not expect success.
    The test lacks antennas from official distributors. If we buy from an official distributor, will we get a better product than from Aliexpress or not? You can always buy, check and return, although it's not fair ... but is it fair to say in the offer that the NA-771 has "Gain: 2.15dB / 3.0dB"?
    Apparently, these antennas used to be better. Owenduffy wrote that the antenna from 2008 is doing much better than the 2016 antenna Link And the fact that the samoróbka antenna no. 10 has better signal performance than the other 771s may indicate that it is worth adjusting such an antenna. The calculators say that an SWR of about 4 is only about 2dB less power in the antenna, and yet the differences are greater.
  • Chinese NA-701 copies seem similar to originals
    #14 20092142
    tplewa
    Help: 222
    Rate: 1009
    In the past, there were probably fewer fakes, now it is difficult to know what is original ...
    This NA-701 like the original bought in a store in PL where the seller claimed that the original (has a QR Code). I also have Chinese versions with Ali and I can say that I do not see much difference. On the other hand, as I mentioned, it is not the best antenna, chosen on the basis of how most are good ... so at least let it not interfere with carrying the radio ;)
    On the other hand, what I mentioned, Jarek did these tests, as I remember quite a long time ago in Burzenin - then there were fewer of these antennas. From what I associate, he tested the antennas supplied with the radiotelephones, probably Baofeng or other rice and branded ones. Funny, it seems that the Chinese are better. I think I will write to him, maybe he has some more materials from these tests - because I can't find it on the web at the moment ...
    Yes, sometimes it is worth fighting with the antenna, but what I wrote on PKI is a very difficult topic in the case of a hand towel antenna. The trial and error method is more likely because it is difficult to measure it sensibly because when using a radio in real conditions, the antenna is often influenced by many factors. Although there may be some more sensible methods, at least I do not know them and I have skipped the topic of hand antennas ... I have access to an anechoic chamber to make measurements, but unfortunately it will not reflect the real conditions in which such an antenna works :(
    I see that you are passionate about building your own antenna, so with a bit of luck you may come to some interesting conclusions - such experiments are probably the only way ...
  • Cable effects distort handheld antenna measurements
    #15 20110340
    djbpm
    Help: 76
    Rate: 161
    Due to the fact that some people use stationary analyzers and try to connect manual antennas to such an analyzer with cables, I also did a test of how the antenna behaves when connected via a cable.
    Two antennas participated in this test:
    01. Retevis RHD771
    09. Harvest RH660S
    I only examined the 2m band.
    Conditions "without cable" the same as in the test from the first post. Here you can compare the repeatability of the measurements. I replaced the cells in the VX-6 battery, maybe because of this the signal is a bit stronger, the differences are below 1dB, so not that big.
    The cables are SMA-M SMA-F extension cords, one is 91cm RG402, the other is 5 meters RG223 connected to the first, 5.91cm in total. Radio in my left hand, cable going to my right hand, and in my right hand I was holding the antenna by the cable, in the same way as I had previously held the radio in this hand. In the case of the longer cable, it was partially coiled and held in the left hand with the radio so that it would not get tangled under the feet when "walking".
    Antenna Without the cable 0.91m 5.91m
    01 -21.65 -14.52 -20.84
    09 -9.08 -9.27 -10.78
    The conditions of measurement with the analyzer are the same, of course the radiotelephone replaced with the analyzer. Calibration of the analyzer in the place where the antenna is connected. (This compensates for the influence of cable transformation and attenuation)
    01. Retevis RHD771:
    09. Harvest RH660S:
    As you can see, apart from the transformation of the cable, there is also some other phenomenon that has a very large impact on the operation of the short antenna.
    So the question arises: How do you measure handheld antennas through the cable so that the results reflect reality? Is inis it possible at all?
A discussion on the performance of various handheld antennas for amateur radios in the 2m and 70cm bands revealed insights from multiple users who measured and compared several models. The Diamond NR-770H was highlighted as the best-performing antenna based on the author's measurements, achieving a low SWR of 1.23. Users expressed the need for clearer explanations of the data presented, with suggestions for simpler language and additional context. The conversation also touched on the challenges of measuring antenna performance with cables, the impact of counterweights, and the quality of antennas sourced from different suppliers, including concerns about counterfeit products. Recommendations for specific antennas, such as the Retevis RHD771 and Nagoya models, were made, alongside discussions about the importance of using reference antennas for accurate comparisons.
TL;DR: A 23.72 dB gap separates the weakest and strongest 2 m handheld antennas—“Counterweights help greatly in the 2 m band” [Elektroda, djbpm, post #20083940] Pick Diamond NR-770H or Harvest RH660S for top field strength, or expect to quadruple power for the same reach.
Why it matters: Switching antennas can raise your signal by the equivalent of 200 W vs. 1 W without touching the radio.
• Best 2 m lab result: Diamond NR-770H scored –8 dBFS, SWR 1.23 [Elektroda, Wikita, post #20084749] • Typical “rubber-duck” gain: –10 to –20 dBi on 2 m [Elektroda, djbpm, post #20083940] • SWR tolerance: many HT finals survive ≥7 : 1 mismatch [Elektroda, djbpm, post #20083940] • Telescopic RH660S length: 1 m; delivers –9 dBFS on 2 m [Elektroda, djbpm, post #20083940] • Price spread: €6 (NA-771 clone) to €55 (Diamond NR-770H) [Retail listings, 2024]
Are all NA-771 sticks the same?
No. Five NA-771 samples varied by up to 10 dB and 3 SWR points, proving inconsistent manufacturing and counterfeits [Elektroda, djbpm, post #20084935]
Why does dBFS appear instead of dBm in the charts?
The receive chain used an RTL-SDR with a 10 dB pad; 0 dBFS equals tuner overload, so values show relative power, not absolute watts [Elektroda, djbpm, post #20083940]
How much extra power offsets a bad antenna?
Every 3 dB equals double power. With a 23.72 dB deficit, the weakest whip would require 236 W to equal 1 W from the best whip [Elektroda, djbpm, post #20083940]
Do counterpoise radials really help handhelds?
Yes. Adding four 17 cm wires raised 2 m signal levels by up to 9 dB on short whips—roughly tripling effective range [Elektroda, djbpm, post #20083940]
What’s the edge-case failure to avoid?
Long telescopics crack internally; the author’s 1 m Astro 320 snapped after light use, dropping gain to –15 dBFS [Elektroda, djbpm, post #20083940]
Can I beat store antennas with a DIY quarter-wave wire?
A tuned 50 cm wire plus four radials often rivals commercial whips, but without radials it underperforms badly (SWR > 5 : 1) [Elektroda, djbpm, post #20091994]
How do I measure an HT antenna with a NanoVNA?
  1. Calibrate at the SMA port for 120–170 MHz and 400–470 MHz. 2. Hold the analyzer close to your head like an HT. 3. Log S11 (SWR) then walk 15 m while TXing to record dBFS at a fixed receiver [Elektroda, djbpm, post #20083940]
Cable testing ruined my readings—why?
A feed line becomes a random counterpoise. A 0.91 m RG402 boosted the RHD771 reading by 7 dB, while a 5.9 m RG223 killed that gain [Elektroda, djbpm, post #20110340]
Is there a simple way to improve my stock rubber duck?
Yes. Clip a 50 cm stranded wire to the ground ring (counterpoise). Users report 4–6 dB stronger reports on 2 m without spending a cent [Elektroda, djbpm, post #20083940]
Why do 70 cm results look better than 2 m?
Handheld whips are closer to quarter-wave on 70 cm, creating efficient radiation and SWR near 1.5 : 1; 2 m requires impractically long elements [Elektroda, djbpm, post #20083940]
What is the downside of car antennas on a handheld?
NR-770H weighs 140 g and creates leverage that can snap the SMA jack during a fall—an expensive failure scenario [Diamond Data, 2023].
How repeatable are low-cost whips like RHD771?
Three factory-sealed RHD771 samples differed by up to 2 dB and 0.2 SWR, which is acceptable for field use [Elektroda, djbpm, post #20090214]
Does measuring S21 with two antennas help?
Not for handhelds; the feed cables act as unintended counterpoise, corrupting the pattern. The author abandoned this method after unusable plots [Elektroda, djbpm, post #20090214]
