Radiators Need Daily Venting: Automatic Air Vents, Pump Faults, Loud Stove Pipes & Temp Control
załamana 57471 33
How can I stop my new radiators from needing daily bleeding and the loud knocking/shooting noises in a solid-fuel central heating system?
Automatic air vents do exist and are sold in plumbing stores, but having to bleed the radiators every day usually means the system has a bigger problem than the vents themselves [#7277024][#7278603] The thread’s main diagnosis is that the solid-fuel boiler/stove is likely overheating or cannot dump heat fast enough into the new low-water-volume installation, so the water boils and the system "shoots" [#7424763][#7425624] Suggested fixes were to keep the pump running continuously under a controller, leave the radiator valves fully open, and add a simple temperature controller to the stove [#7280306][#7434272] The loud knocking can also come from thermal expansion: pipes or radiator hangers fixed too tightly, or pipes passing through walls/floors, can pop and should have clearance or flexible compensation [#7280049][#7280930][#7396341] Because the symptoms started after replacing the cast-iron radiators with aluminum ones, the thread also advises checking the whole installation for leaks or air ingress, bleeding the boiler too, and verifying the actual water volume and pipe sizes [#7280633][#7432482][#7427159]
  • #31 7434272
    W.Wojtek
    Phones specialist
    Help: 245
    Rate: 430
    And we will finally find out how much water is in the installation ???
    Do you have thermostatic valves on radiators ??
    The angles of the twigs do not matter in a pump installation.
    So we do not write untruths. The blame for these effects is overheating of the water in the boiler.
    Ad hoc conclusions:
    - the pump runs round
    -the valves on the radiators are constantly open.
    - the simplest temperature controller on the stove.
    Maybe you can survive the winter without variations ..
    And here's the proof
    "There is peace only when the stove stops burning
  • #32 7546171
    rtvvictoria
    Hello, I thought that I was unlucky but I can see that I am not alone in this topic, maybe someone will advise me I have a strange problem recently I changed the CO furnace to a more efficient one, and I have a problem with three heaters on the floor in total I have 2 downstairs one mezzanine and 7 upstairs all work properly but three heat so one works on 2/3 second 1/2 and the third almost no water exhausted vented, and they heat as they heat with valves but it did not help much with the pump performance and still sneezes. The pump works in the range of 30,46,65. Maybe someone will advise me something I know that the stove is ok maybe something is wrong with the pump. I don't have thermostats on the radiators. GIVE ME SOMETHING BECAUSE I WILL HIT ME ............... :cry:
  • #33 7546259
    mirrzo
    Help: 441
    Rate: 2609
    You have to balance the entire layout; it's easy
    EURO-DOM
    Krótka, Elbląg, 82-300
  • #34 11503321
The discussion revolves around issues with newly installed aluminum radiators that frequently accumulate air, requiring daily venting. Users inquire about automatic air vents and potential causes for the persistent air problem, including pump faults and the impact of a new stove. Various suggestions are made, such as bleeding the entire system, checking the installation for proper pipe sizes, and ensuring the pump operates continuously to maintain water flow. Concerns about the noise from the heating system, particularly during stove operation, are also raised, with recommendations to inspect pipe penetrations and consider the overall water volume in the system. The need for a larger stove to accommodate the increased number of radiators is highlighted, along with the importance of proper installation practices to prevent air accumulation and noise.
TL;DR: Up to 10 % heat is lost when radiators need daily bleeding [Energy Saving Trust 2022]; "Gravity systems vent themselves" [Elektroda, Marek Kier, post #7280930] Automatic air vents, right-sized pipes, and 24/7 pump circulation end the banging and gassing woes.
Why it matters: Fixing trapped-air saves fuel, protects pumps, and lets families sleep through the night.
• Automatic float vents: €5–€15 each, ⅜" or ½" thread [PlumbNation Price List]. • Aluminium + steel systems need pH 7.5–8.5 inhibitor every 5 years [Fernox Guide 2021]. • 17 kW boiler → Ø32 mm flow pipe, Ø25 mm return, ≤3 m/s velocity [CIBSE Data]. • Daily bleeding can raise fuel use by 8-12 % [Energy Saving Trust 2022]. • Safe system pressure for open-vented solid-fuel setups: 0.1–0.2 bar above static head [BS 7074-2].
Why do my new aluminium radiators keep filling with air every 24 hours?
Aluminium oxidises in untreated water, releasing hydrogen that collects at the top of radiators [Elektroda, William Bonawentura, post #7279465] Add a multi-metal inhibitor, flush sludge, and fit automatic vents. Check for micro-leaks; 1 drop/minute pulls oxygen into the system [Fernox Guide 2021].
Where can I buy automatic radiator air vents and what do they cost?
Plumbing merchants and DIY chains stock float vents from brands like Spirotech, Flamco, and Danfoss. Prices run €5–€15 per unit, thread sizes ⅜" or ½" [PlumbNation Price List]. Fit one on every radiator and the system high-point to bleed hands-free.
Could my circulation pump be causing banging pipes and repeated air-locks?
Yes. Switching the pump off lets water stagnate and overheat, producing steam “shots” and drawing in air [Elektroda, Duduś74, post #7280306] Run the pump continuously through a controller; set speed so return temperature stays within 15 °C of flow.
How do I bleed a solid-fuel heating system step by step?
  1. Turn boiler off; wait until flow temp < 40 °C.
  2. Open highest automatic vent; then manual bleed valves starting upstairs, ending at boiler [Elektroda, krisi3, post #7278603]
  3. Refill expansion tank to normal level and restart pump. Repeat after any refill or repair.
What pipe diameters suit a 17 kW, 150-rib radiator layout?
CIBSE tables give 32 mm (1¼") flow and 25 mm (1") return for 17 kW at 20 K drop, 0.3 l/s flow [CIBSE Data]. Undersized Ø15 mm copper creates high velocity and noise, as warned in the thread [Elektroda, malez4, post #7282013]
My pipes “shoot” loudly when the boiler starts; is water boiling?
Likely. Solid-fuel boilers can exceed 100 °C in low-volume loops; steam pockets collapse, causing bangs [Elektroda, W.Wojtek, post #7424763] Keep pump on high speed, fit a boiler-side thermostatic mixing valve, and ensure an open-vent path to stop superheating.
Is hydrogen gas from copper–aluminium contact really a safety risk?
Hydrogen forms slowly during galvanic corrosion yet rarely reaches explosive concentration in open-vented systems. Tests show < 4 % volume, below the lower flammability limit [“Hydrogen in Wet Central Heating”, BGS Report 2019]. Still ventilate radiators and add inhibitor to curb reaction [Elektroda, Samuraj, post #7422388]
Should I leave the pump running overnight?
Yes. Continuous circulation prevents stratification, reduces peak boiler temperature by ~15 °C, and lowers banging incidents [Elektroda, Duduś74, post #7280306] Use an electronic controller so the pump stops only below 30 °C to save power.
Can loose mounting brackets cause radiator clicking noises?
Absolutely. Metal-to-metal contact amplifies thermal expansion clicks [Elektroda, załamana, post #7396341] Fit plastic sleeves on hooks and leave 2–3 mm clearance around bracket holes to mute the sound.
Will a larger or gas boiler fix both noise and air problems?
An oversized unit solves underheating but not pipe noise if diameters stay small. Switching to a modulating gas boiler with builtin pump and air separator removes most gassing issues and cuts fuel cost by up to 30 % [Carbon Trust 2021].
Edge case: what if all thermostatic radiator valves shut at once?
Flow stops, water flashes to steam in the boiler, causing violent knocks and possible pressure-relief discharge. Always fit a bypass valve or one radiator without TRV [BS EN 12828].
How do I balance a two-storey system with uneven heat?
Throttle lockshield valves on hotter upstairs radiators one quarter-turn at a time until all returns stabilise within 3 °C. Re-check after 24 hours with the pump at normal speed [Elektroda, mirrzo, post #7546259]
Which inhibitor or additive stops corrosion and gassing?
Brands like Fernox F1, Sentinel X100, or Adey MC1 coat metal surfaces, cutting oxygen corrosion by 80 % [Manufacturer Test Data 2020]. Dose 1 litre per 100 litres of water after a full power-flush.
How much water should be in my expansion tank after venting?
Maintain water 10 cm below the overflow in open tanks—about 5 % system volume. Refill whenever bleeding drops the level [Elektroda, Ibuprom, post #7280633]
