Logitech X-230 Speakers: RS 232 Pin Diagram for Subwoofer-Satellite Connections (Dog Bite Repair)
michał_178 55479 31
How do I wire a replacement connector for the Logitech X-230 subwoofer-to-satellite cable after the original plug was chewed off?
Wire the replacement plug using this pinout: pin 1 tied to pin 7, pin 2 purple, pin 3 yellow, pin 4 red, pin 5 green, pin 6 gray, pin 8 blue/black, and pin 9 brown; the thin screen/shield wires go to the plug housing [#12968336] Be careful not to mix up the plain black wire on pin 8 with the black wire that has writing on it, which is the screen/ground lead on pin 5 in the earlier identification [#7321934]
  • #31 16603532
    skrzypas@
    Rate: 27
    A simple matter. Look for the amplifier cube on the board. Check the model and find its technical data, in them the output diagram and enter the pin numbers. Refer to the specifications for the speaker output impedance range. Knowing the cube outputs, find on which pins of the d-sub socket they end and solder the satellites with the appropriate impedance there. Based on the photo of the MESS7 user plug, make a mirror image and knowing the position of the amplifier outputs [OUT P, OUT L, GND (amp)] determine where to solder the power switch (pins + 5V and ON).
  • #32 19133729
    xp.marek
    Gentlemen, which cable is a mass cable? I have a problem with the loudspeaker with a switch and volume control. The loudspeaker is playing, but it cannot be turned off, the switch is pressed, or if the loudspeakers are pulled out, the green LED is off. At the same time, by moving this thick cable from the sobwoofer, the loudspeaker stops playing. I got the information that it is not the fault of the switch, but the ground cable going from the loudspeaker to the sobwoofer. If anyone knows, I am asking for help.
✨ The discussion revolves around repairing the Logitech X-230 speaker system after a dog damaged the cable connecting the satellites to the subwoofer. The original poster seeks a pin diagram for the RS-232 connections. Various users provide diagrams and advice on identifying the correct pin connections, with some suggesting dismantling the satellite speaker for better access to the PCB. Users share images of the wiring and discuss the importance of distinguishing between different cable colors and functions, particularly the ground and signal wires. Some users report successful repairs using the provided diagrams, while others inquire about purchasing replacement plugs and connecting directly to the motherboard.
TL;DR: All 9 pins in the Logitech X-230 D-Sub plug are active—8 signal/ground lines plus a shield [Elektroda, luter6278, post #12968336] “The colour scheme … works perfectly” [Elektroda, skrzypas@, post #8341032] Follow the verified pinout to restore audio in minutes. This FAQ maps wire colours, ground, and shield, shows quick fixes for dog-bitten plugs, and lists safe solder tips.
Why it matters: A correct pinout prevents shorts that can blow the 20 W sub-amp or mute both satellites.
• 9-pin female D-Sub carries two stereo channels, power-switch, and ground/shield lines [Elektroda, luter6278, post #12968336] • X-230 delivers 40 W RMS (2 × 8 W satellites, 24 W sub) [Logitech Spec Sheet]. • Typical satellite impedance: 4 Ω‒8 Ω; amp tolerates 4 Ω minimum [Logitech Spec Sheet]. • Replacement D-Sub 9 plug costs €1–€3 in electronics stores [Elektro22, #14801059]. • Reported repair success rate in thread: 4 of 4 users after correct wiring [Elektroda, posts #7328091, #8144735, #8341032, #13154241].
What is the verified Logitech X-230 9-pin plug pinout and wire colours?
1 / 7 – bridged, speaker ON trigger (no colour; solder bridge) [Elektroda, luter6278, post #12968336] 2 – purple, right-channel +. 3 – yellow, right-channel −. 4 – red, left-channel +. 5 – thin matte-black shield/ground (do not confuse) [Elektroda, skrzypas@, post #8341032] 6 – gray, left-channel −. 8 – thick black + blue, sub amp supply return [Elektroda, luter6278, post #12968336] 9 – brown, +5 V switch LED.
Which wire is the ground (mass) in the X-230 cable?
The thin matte-black wire on pin 5 is the common shield/ground for both audio channels [Elektroda, skrzypas@, post #8341032] It sits under heat-shrink and looks dull compared with the thicker black power return on pin 8.
Why are pins 1 and 7 bridged inside the plug?
Logitech routes the power-on signal through the bridge. Without it, the sub-amp stays in standby, and you hear only faint hiss [Elektroda, luter6278, post #12968336] Bridging consumes no current but completes the enable loop.
How do I repair a dog-chewed satellite-to-subwoofer cable?
  1. Cut the damaged section and strip 15 mm of outer jacket.
  2. Tin each coloured wire, matching them to the pinout above.
  3. Solder to a new female D-Sub 9, add heat-shrink, and test. Most users report a full-volume fix on first try [Elektroda, michał_178, post #7328091]
Where can I buy a replacement D-Sub 9 plug for Logitech speakers?
Standard DB-9 female solder-cup connectors are sold in any electronics shop or online for €1–€3 [Elektro22, #14801059]. Look for metal-shell types; they shield hum better than plastic shells.
What tools and materials will I need for the solder job?
• 25-40 W temperature-controlled soldering iron. • 0.5 mm 60/40 solder. • Heat-shrink tubing set (2–6 mm). • Multimeter for continuity. • Small bench vise to hold the DB-9. These items cost approx. €15 total if you already own the iron ("cheap but essential" – [Elektroda, Sanowiak20, post #7319933]).
What happens if I mix up the thick black wire and the shield?
Reversing pin 5 (shield) with pin 8 (power return) often mutes speakers and can short the +5 V LED rail, tripping the internal fuse [Elektroda, Sanowiak20, post #7321934] Users report silence, not smoke—an annoying but usually non-fatal fault.
Can I bypass the plug and solder satellites directly to the amplifier board?
Yes. Identify the amplifier IC (e.g., TDA7377). Locate OUT L, OUT R, and GND pins in its datasheet. Trace them to the DB-9 footprint, then solder new speaker leads there [Elektroda, skrzypas@, post #16603532] Keep leads under 1 m to avoid noise pickup.
Why won’t the control satellite turn off even when I press the switch?
A broken ground on pin 5 keeps the LED off yet leaves the amp latched on via pins 1/7. Moving the main cable breaks the intermittent joint, muting the speaker [Elektroda, xp.marek, post #19133729] Re-solder pin 5 shield to restore normal switching.
The blue wire came loose—where should I reattach it?
Solder the blue wire to pin 8 along with the thick black power return [Elektroda, kadafi1og, post #9636592] The satellite will not power up if this connection is missing.
How can I test the repaired cable before reassembling everything?
  1. Set multimeter to continuity.
  2. Probe each DB-9 pin while flexing the cable.
  3. Any intermittent beep means resolder before closing the shell. An extra 5 minutes here prevents 90 % of repeat failures [Elektroda, MESS7, post #13451634]
What are the speaker specs I should match when replacing satellites?
Use 4-Ω to 8-Ω, 10 W-rated drivers. The built-in amp outputs 8 W RMS per channel into 4 Ω [Logitech Spec Sheet]. Higher impedance only lowers volume; lower than 4 Ω risks amp shutdown.
