Logitech Z323 Subwoofer Activation Without Satellites: 9-DIN RCA Port Plug & Pinout Guide
jerzy11 13389 8
  • #1 15021740
    jerzy11
    Hello, I'm in my cupboard logitech z323 subwoofer without satellites I'd like to run
    Is there an easy way to make a switch that activates its amplifier by shorting the appropriate pins in the socket of the 9 din RCA port plug?
    In this subject line, provided the schematic and pinout for logitech x230
    Unfortunately, I can't find a similar one for z323 anywhere
  • #2 15023694
    jesion40
    Help: 100
    Rate: 127
    It does not have such a diagram, but I do not think Logitech complicates its life by defining a different pinout for each model on the same connector. If I were you, I'd take that risk and assume they're identical connectors.
    The bigger problem is that there are two contradictory information on this issue in the indicated topic. In post # 2 it was stated that to turn the system on, pin 6 should be connected with pin 8 and in post # 26 that pin 6 should be connected with pin 7. The latter looks more likely, because there is ground on pin 8 and power on pin 7.
    Try to connect pin 6 to 8 with a cable for a moment and if it does not start, nothing bad should happen, even if the connection is wrong for a moment.
  • #3 15028416
    jerzy11
    unfortunately, the connection of these pins does not work, I tried in various ways, I have to trace the paths because I got angry and quickly shorted others and something sparked
  • #4 15031226
    jesion40
    Help: 100
    Rate: 127
    Have you checked, if so, what voltage is there between pins 7 and 8?
  • #5 15039236
    jerzy11
    I'm sorry for the delay, my laptop graphics card has died and now it is my main problem
    Soon I will throw photos of the circuit board and measure the voltage of the "subwoofer"
  • #6 15379307
    Leo16
    Hey
    Was it possible to locate anything more with the list of pins ??
    I got just such a Z323 set in the settlement, but unfortunately there is no COM plug.
    Regards
  • #7 15389395
    jerzy11
    unfortunately, I was combining in many ways and it did not help
    by the way, the membrane was damaged, it ended up in the trash
    the topic can be closed / deleted
    thanks for showing interest
  • #8 15390298
    Leo16
    Do you have anything else from the set ??
    I need a cable (with a plug), even the plug is enough for me
    I mean the list of pins
    From what I understood from the description, do you need a connection diagram in the box ??
  • #9 17309610
    marianchocko
    I had a set of these speakers for repair with a damaged potentiometer in the satellites, it is pins 3 and 4 in the plug that need to be shorted so that the subwoofer works without two small speakers.
The discussion revolves around activating a Logitech Z323 subwoofer without its satellite speakers by utilizing the 9-DIN RCA port. Users seek a pinout guide to determine which pins to short for amplifier activation. Initial suggestions indicate connecting pin 6 to either pin 7 or pin 8, but conflicting information leads to unsuccessful attempts. One user reports that pins 3 and 4 need to be shorted for the subwoofer to function without the satellites. The conversation also touches on troubleshooting steps, including measuring voltage between pins and the need for additional components like cables or plugs.
