Radiators – only heat at the top, cold at the bottom, what to check?
rosenrot1987 68898 31
Why do my radiators heat only at the top even though the supply is hot, the return is cold, and I have installed a circulation pump?
The radiators are most likely starved of flow, not air: if the supply is hot and the return stays cold, the water is not passing through the whole radiator, and the cause is usually a silted/clogged valve, blocked branch pipe, or badly balanced piping that makes the pump take the easiest circulation path instead [#11842624] [#11850860] Check that the supply and return valves are fully open, and if there is a thermostatic valve, unscrew the head and inspect the presetting/insert under it; one user fixed a similar half-heating radiator by moving that adjustment, and another reported better heating after replacing the supply valve so more water could pass [#11842100] [#11843156] [#11903240] Try throttling or closing the other radiators to see whether the weak one starts heating better, because the installation may be badly balanced and the pump may be sending water through the shortest loop instead of through both radiators [#11846222] [#11850723] [#11850860] If the pipe run goes up and then down, or has sharp bends and small cross-sections, that can also restrict circulation; photos or a diagram and pipe diameters would help confirm it [#11842506] [#11842336] [#11849017]
  • #1 11842079
    rosenrot1987
    Rate: 27
    Hello, warmly, I am new here and I am asking for your understanding.
    I have a problem, I started to make living quarters in the basement, a specialist from one riser on the power supply made a stub pipe (pipes went under the return and supply ceiling) and pulled it down to the made (new two-plate radiator). Then he pulled the power supply to the next room at the same height and the return also at the same height (i.e. from the bottom) to the second radiator in the other room (which was used) just behind the wall of the other room on the tee on the return made a return on the ground which at the end of the room it goes about 40cm up then through the wall and again about 80cm up and goes back to the stove. Of course, the heaters were previously installed (such spirals at the ceiling and they heated great) and the current ones are a bit lower than the level of the central heating furnace. Both heaters only heated at the top. Today he made a pump and even after connecting it (i.e. the pump), I only heat the top of both radiators. There is no air in the radiators, because we even unscrewed the return at the radiator exits (after the regular venting at the top of the radiator) and water was flowing under quite good pressure.
    I apologize for mistakes but I am a layman in this topic and I am asking for understanding and help as soon as possible. I greet everyone
  • #2 11842100
    W0jtek92
    Help: 469
    Rate: 1257
    And are the supply and return radiator valves fully open?
  • #3 11842124
    Grzegorz Siemienowicz
    Level 36  
    Help: 146
    Rate: 600
    Advertise the service, a professional will not leave a badly done job.
    PS
    Not enough readable data to start analyzing it at all.
  • #4 11842175
    rosenrot1987
    Rate: 27
    valves unscrewed to the max
    a friend writes that he writes too poorly, what else should I add to help you in the analysis?
  • #5 11842336
    W0jtek92
    Help: 469
    Rate: 1257
    Give me a diagram of this installation or some photos. Pipe diameters that the plumber used and what system it is ..
  • #6 11842396
    rosenrot1987
    Rate: 27
    pexal wavina there was 20 ...
    I would like to add that the return is very cool, while the power supply at the radiator is hot and it is very, and yet it heats the top
  • #7 11842506
    sjbar
    Help: 6
    Rate: 34
    There may be air in the pipe if they are placed in a strange way, eg the pipe "goes" up then descends, in this bend there is some air left at the top and restricts the water flow. If there is a pump and there is no cross-section limitation somewhere, it must heat up.
  • #8 11842624
    Zbigniew Rusek
    Help: 394
    Rate: 1542
    If the supply is hot and the return is completely cold and the radiators only heat up with the top (the bottom is colder), the reason is not air pockets, but a bad flow of the heating medium through the radiator. There may be a silted orifice, a clogged (or stony) twig (feed or return, or both), bad crusting. What valves are there on these radiators? If it is modern (with a thermostatic head), it is possible to change the coating without draining the water, after unscrewing the head (there is a pre-setting under the head, which acts as a cone). If there are old valves, then the matter is more difficult, because to clean (and even more so change) the orifice you have to drain the water. What was written in the post by sjbar may be true if the pipes were made so strangely (the twig goes up and then down), but the description in the first post does not show that they are arranged in this way (it would be better to infer from the drawing whether photos). Yes, the description shows that the installation is not very well done (there is no way to work on gravity, but the pump should handle it).
  • #9 11843099
    rosenrot1987
    Rate: 27
    There may be a silted orifice, a clogged (or stony) twig (feed or return, or both), bad crusting. What valves are there on these radiators? If modern (with a thermostatic head), the change of the coating is possible without draining the water, after unscrewing the head (there is a pre-setting under the head, which acts as a cone)
    so how do I push it away or fix it?
  • #10 11843156
    fox99
    Hello. I recently had a problem with the radiator that heats up to half temperature, even though the head was unscrewed to the maximum. Bleeding it was useless. So I unscrewed the head and there is an additional adjustment underneath. I shook it a little and the radiator heats up all over. Maybe that's the problem. Regards
  • #11 11843232
    Level 36  
    Help: 146
    Rate: 600
    I think you paid for the service. So why should you fix it? Advertise.
  • #12 11843546
    rosenrot1987
    Rate: 27
    It is like this:
    when the pump is connected to electricity, after about an hour, the smaller radiator in the smaller room heats up as needed (in this radiator I turned the valve under the head) and heats, in the other room with a larger radiator, after connecting the pump it heats up to 3/4 from the top (but in this particular radiator under the head there is no regulation with numbers from 1 to 6) after turning off the pump 10-15 minutes and the radiators only heat up at the top (practically only the grille is quite warm, the rest is cold. that you have to vent or that it heats because it has to heat only halfway up, it makes me an idiot and talks to him like that; /, the pump is certainly not too weak because it is grundson (I think it is written) and it is in the 3rd gear 90 or 100W and it is on this course all the time.
  • #13 11843583
    Level 36  
    Help: 146
    Rate: 600
    As for me (and it should be for you too), the radiator can be completely cold, so you have to reach the right temperature in the room.
    For this reason, you advertise that the room does not reach the right temperature and he has to do everything to achieve it. :D
  • #14 11845115
    Radzik_D
    my specialist said that this is what it is supposed to be and I can kiss him on the ass, sorry, because he said that everything is ok, so I have to deal with this problem on my own
  • #15 11845136
    W0jtek92
    Help: 469
    Rate: 1257
    So you came across the company cockerel-Spartolił i ucik. Give me some pictures of this layout. It will be easier for all of us to determine what is the problem of non-heating ..
  • #16 11845285
    Radzik_D
    the photos will be added tomorrow morning
  • #17 11846222
    Pittt
    Level 32  
    Help: 148
    Rate: 213
    Tighten the valves of the other radiators and tell if the underheated one started to heat up. The soonest you have it, you now have badly balanced flows in the installation. And through this radiator, the water flows too slowly (many bends, siphoning, small cross-sections). And if so, it is the plumber's fault, unless you wanted to have it cheap and not good.
  • #18 11847306
    rosenrot1987
    Rate: 27
    I wanted to have it well, of course, with the fact that I asked him if I would give the radiator under the window if everything would be ok, he assured me that it was, of course, it was not so for the next day we bought the pump because he assured that everything would be great as the pump was, we set up the pump and just the above-mentioned effect. This morning, when I lit the stove (until I turned on the pump), the radiators throughout the house were hot and in my beer cold as fix. only after turning on the pump they started to heat, I will attach photos in the next answer
    Added after 1 [hours] 53 [minutes]:
    I have a very important question:
    Does it matter how a total of 7 radiators go to one riser and only 2 radiators go to another riser?
    because I think to plug the return from my two radiators to the riser to which in total 4 radiators will be connected (along with my)
  • #19 11849017
    W0jtek92
    Help: 469
    Rate: 1257
    It is essential. But it largely depends on the cross-sections of the pipes on the risers and the individual branches for the radiators ...
  • #20 11849332
    rosenrot1987
    Rate: 27
    I plan to recruit my foreman tomorrow to mount the heaters 40mm higher, because at this height the pipe is still warm (coming from the power supply mounted under the ceiling) and to rework and connect to this return, there are currently only 2 radiators supported
  • #21 11850278
    W0jtek92
    Help: 469
    Rate: 1257
    It's hard to say if this will help ... You could ask millions of questions when you are not dealing with this installation. What will you get by lifting the radiators when the pipe below is cool? It follows that you have no circulation. This will not change the fact that the radiator is cold. And if it's a pex pipe, isn't it sometimes broken somewhere on the bends?
  • #22 11850346
    rosenrot1987
    Rate: 27
    rather there is a breakdown on the folds from what I was looking at.
    so it turns out that the pressure is too weak and if I hook these radiators to the riser to which there are only 2 radiators and now 7, it can help, the previous spiral heater was higher and the heating was great
  • #23 11850395
    W0jtek92
    Help: 469
    Rate: 1257
    And have you tried to turn off other radiators to see if they will heat up? Often it is a question of crucifixion. And since the radiators are in the basement, they have the greatest pressure due to the water column.
  • #24 11850489
    rosenrot1987
    Rate: 27
    yes, and they heat up more, but as I wrote above, one has this numbering from 1 to 6 under the head and the other does not have it and I do not know how to set it there
  • #25 11850579
    W0jtek92
    Help: 469
    Rate: 1257
    It may not have a ridge. That's why these numbers are missing.
  • #26 11850723
    irus.m
    Heating systems specialist
    Help: 122
    Rate: 453
    Quite important. The sum of the individual flows must be equal at the input and output of the individual circuits. Otherwise, pressure differences will be generated between the circuits, which will be equalized by the shortest path for them (connected vessels), not always desirable for us.
  • #27 11850799
    rosenrot1987
    Rate: 27
    can it be written more clearly? for I am glabem
  • #28 11850860
    W0jtek92
    Help: 469
    Rate: 1257
    The pump catches a simpler circulation so you do not have circulation through the radiators .. It cannot be easier to explain.
  • #29 11850869
    rosenrot1987
    Rate: 27
    thanks beautiful,
    it can be because after assembling the pump I have a less efficient boiler (one bath at home and lukewarm water) and there was a bathing for 3.4 people in front of the pump go ahead
  • #30 11903240
    rosenrot1987
    Rate: 27
    Gentlemen, a slight refreshment of the topic:
    One macher came and plugged in the WILO 4.5 W circulation pump and it started to heat up nice, but as he changed the valve on one of the radiators, because, as he said, what I had in a large radiator, very little water passes through, and after changing the valve at the power supply, the radiator started to heat up even better. of course, after disconnecting the pump, the problem returned, but it was smaller, because when it burns in the stove, in the 1st gear, with the pump on, I have a small heater almost all hot and a large one 1/3 hot (in the second gear 2/3 hot and adds that it is very big radiator)), and my question, from the power supply from another riser (which goes horizontally), there are probably 1.5 inch or 1 inch pipes and the connector that leads the power to my radiator is welded at an angle of 90 degrees (the power goes horizontally) and is 1/2 inch, is it because the ferrule is welded at an angle of 90 degrees and has a much smaller diameter than the supply diameter, the heaters do not heat up as they should? If I was welding the outlet at an angle of, for example, 45 degrees, would the pump better not push hot water to my radiators?
    I greet everyone and thank you for the answers
    ps please take a look at my lame picture Radiators – only heat at the top, cold at the bottom, what to check?
The discussion revolves around issues with heating radiators in a basement living space, where the radiators only heat at the top, indicating poor circulation. The user describes a setup involving two radiators connected to a riser, with a pump installed to improve flow. Responses suggest checking the radiator valves, potential air pockets in the pipes, and the possibility of clogged or silted orifices affecting water flow. Users recommend providing diagrams or photos for better analysis and suggest that the installation may be poorly balanced, leading to inadequate heating. The conversation also touches on the importance of proper pipe sizing and circulation dynamics in heating systems.
TL;DR: “Up to 75 % heat output is lost when radiator flow drops below 25 L/h” [CIBSE, 2021]; “the pump catches an easier circulation” [Elektroda, W0jtek92, post #11850860] Balance valves, clear blockages, and keep pipe Ø ≥ 20 mm to restore full warmth.
Why it matters: Poor flow wastes energy, shortens boiler life, and leaves rooms cold.
• Typical ΔT for panel radiators: 20 °C between flow and return [CIBSE Guide B, 2021]. • Minimum design flow: 30 L/h per 1 kW radiator output [Viessmann, 2022]. • Ideal pump head in small homes: 1–2 m (≈10–20 kPa) [Grundfos, 2021]. • Sludge can cut radiator capacity by 15–25 % in one heating season [Energy Saving Trust, 2020]. • Balancing can save 6–8 % on annual heating bills [EST, 2022].
Why do my radiators heat only at the top?
Hot flow enters, cool return stalls. Restricted valves, sludge, or undersized ½-inch branches throttle water, so heat stays near the header and the bottom stays cold [Elektroda, Zbigniew Rusek, post #11842624]
Could trapped air still be the cause even after bleeding?
Rarely. If supply is hot and return stone-cold, flow—not air—is the issue. Air causes gurgling and total coldness, not half-hot panels [Elektroda, sjbar, post #11842506]
Does pipe diameter matter when adding basement radiators?
Yes. Dropping from 1 in (25 mm) riser to a ½ in (15 mm) take-off can cut flow by 60 % at the same pump head [CIBSE, 2021].
Can a 90° ½-inch stub starve the radiator?
Sharp 90° bends add up to 1 m equivalent pipe length. With a small bore, velocity rises, pressure drops, and the pump diverts elsewhere, so heat delivery falls [Elektroda, rosenrot1987, post #11903240]
How do I tell if balancing is the real problem?
Close other radiators. If the cold one warms fully, flows are unbalanced. This field test confirmed the issue for the poster [Elektroda, Pittt, post #11846222]
What is the quick 3-step way to balance my system?
  1. Fully open all lockshield valves, run boiler 15 min.
  2. Starting nearest the boiler, close lockshield half a turn, then move outward repeating.
  3. Aim for 12–20 °C drop across each radiator; adjust in ¼-turn steps.
Should I upgrade my circulator pump?
Not necessarily. A Grundfos on speed 3 (≈100 W) already gives 4–5 m head; poor distribution means plumbing changes, not more watts [Elektroda, rosenrot1987, post #11843546]
Is a broken PEX bend a possible culprit?
Yes. Kinked PEX reduces cross-section up to 70 % and can stop flow entirely. Inspect and replace damaged loops [Elektroda, W0jtek92, post #11850278]
Do unequal numbers of radiators on each riser hurt performance?
Yes. A 7-vs-2 split creates large pressure differences; water follows the short, low-resistance path, leaving the long branch under-supplied [Elektroda, W0jtek92, post #11849017]
How often should I clean the pump filter?
Every heating season. Sludge buildup of 3 mm on the strainer can cut flow 20 % [Energy Saving Trust, 2020].
What edge-case causes half-hot panels even with new valves?
Thermostatic heads sometimes stick after summer. The pin under the head seizes, restricting flow. Removing the head and tapping the pin frees it [Elektroda, fox99, post #11843156]
Will raising the radiator 40 mm help?
Height alone won’t solve flow issues. Temperature stratification in basement loops is minor; focus on pipe sizing and balancing instead [Elektroda, W0jtek92, post #11850278]
What statistic shows the benefit of balancing?
Homes that balance radiators save 6–8 % on gas each year [EST, 2022].
