Dell D630 PC764 11.1V 56Wh – how to reset charge, which EEPROM?
ktf 10250 4
  • #1 7584845
    ktf
    Rate: 12
    I have a battery that 'holds' only about half an hour.
    The BIOS has information that the battery will end soon and I will buy a new :)
    The links are good, May after 4.03V. I would like to reset the batch to keep it longer.
    The systems are:
    BQ20857DBT and BQ29311PW
    EEPROM: CEA F53
    Dell D630 PC764 11.1V 56Wh – how to reset charge, which EEPROM? Dell D630 PC764 11.1V 56Wh – how to reset charge, which EEPROM?
    Although I'm not sure about the EEPROM, because nowhere on the electrode I have found such ...
    My question is this: if I would bite into this EEPROM charge, could someone reset it for me, and is there any chance that the battery life will be longer?
  • #2 7584931
    misiozol
    Help: 233
    Rate: 641
    bq2085 has integrated flash eeprom, reset with SBW full or BEW also in full version, and you must have hope that the password on the eepromie does not have
  • #3 7591190
    ktf
    Rate: 12
    Maybe in this case someone from the forum members has SBW full and for a small fee would be the reset eeprom? :)
  • #4 7592264
    misiozol
    Help: 233
    Rate: 641
    You can pay for a small fee from the producer for activations on SBW "Time limited version: $ 15.95 (Limited with 3 activations only)" or BEW "full power of B2Works for $ 10 only.
    Limitations: 3 runs within 3 days only. "
  • #5 7593395
    ktf
    Rate: 12
    Ok, and can you check if there is a password on the eeprome before buying the program, or is the full version will inform me about it?
