Mastercook SKTD 6710 vs Traditional Condenser Dryers: Differences and Space Efficiency
~wac 33602 11
Is a top-loading condenser dryer worth buying for a cramped kitchen, and does it dry differently from a traditional front-loading condenser dryer?
If space forces your choice, a top-loading condenser dryer like the Mastercook SKTD 6710 can work just like a normal front-loading condenser dryer; otherwise, a front-loading model is preferred. One reply advises buying a front-loader only when you are not limited by space [#7629966] Another user tested the Mastercook top-loader and said it dried well and did not differ in any way from a normal-size condenser dryer [#7643714] In that test, with a 600 rpm washing machine and the "Mixed Dry" program, the drying time was reduced to 55 minutes from an initial 1 h 40 min setting [#7643714] So for a cramped kitchen, the top-loader seems to be a practical space-saving choice without an obvious drying-performance penalty [#7629966] [#7643714]
  • #1 7629812
    ~wac
    Help: 17
    Rate: 166
    I have a question, is it worth buying a top-loading condenser dryer or is it better to open it from the front?
    Does drying in such a dryer differ from traditional condenser dryers?
    What do you think of the Mastercook SKTD 6710 top loading dryer?
    It is needed for a cramped tenement house for 2 elderly people. Every cm of space counts
    I am asking for advice
    Regards
  • #2 7629966
    popey111
    Rate: 73
    If you are not forced (lack of space), buy a front-loading one.
  • #3 7630618
    ~wac
    Help: 17
    Rate: 166
    It's bad with the surface and so you need to cut a piece of the corner in the kitchen. I think we will have to choose a top-loading one.
    Does such a dryer dry longer than a traditional one?
    I hope it does not differ from ordinary front dryers.
    If there was a top-loading washing machine, then the traditional dryer would fit, but the old and trouble-free Bosch Maxx 4 WFC 1200 does not want to break down. It has been working for 10 years.
  • #4 7632731
    popey111
    Rate: 73
    I understand that you can not put the dryer on the washing machine?
  • #5 7634262
    ~wac
    Help: 17
    Rate: 166
    It is impossible, because this washing machine is narrow and the kitchen is quite small, without a window. Next to the washing machine there is a fridge. There is this dryer in Media Markcie in Rzeszów. I'll go order it. There is no opinion on these dryers anywhere
    Added after 26 [minutes]:
    I have also found the Hoover STH W 759 dryer, it is more expensive, and about the quality, I do not know myself.
  • #6 7636705
    ~wac
    Help: 17
    Rate: 166
    I ordered this Mastercook. It will be on Friday. We'll see how it works
    Regards
  • #7 7639900
    zwykły człek
    Rate: 81
    Write how it works, because nobody has checked it yet. For some year, I have had their front dryer with an ironing function and I praise myself a lot. I'm curious how it looks in tops.
  • #8 7640033
    ~wac
    Help: 17
    Rate: 166
    Ok. This dryer is for my grandparents. I think there will be something to wash on Friday
  • #9 7640922
    manana
    Rate: 9
    It's nice that you have already ordered this dryer. I am also curious how it will work, so when you have your laundry, write about how it did ... was it a good purchase ??? I am also wondering whether I should buy a dryer for myself and I would love to hear the opinions of someone who already has such equipment ;)
  • #10 7643714
    ~wac
    Help: 17
    Rate: 166
    The dryer arrived the day before and I have already tested it.
    It did great. I have washed dark clothes, such as a fleece sweatshirt, fleece jacket, tracksuits, socks, cotton shirts, etc. I would like to emphasize that the washing machine is only 600 rpm.
    I set the drying to the "Mixed Dry" program. The start time is 1.40 hours. The dryer itself shortened the drying time to 55 minutes.
    Summarizing the whole:
    Synthetics 40 washing program (duration 45 minutes)
    Drying program Mixed dry (time 55 min.)
    1 h 40 min. and the laundry already hidden in the wardrobe
    Comparing my old Whirlpool that I have at home, the Mastercook top-loading dryer does not differ in any way from a normal-size condenser dryer.
  • #11 7648930
    zwykły człek
    Rate: 81
    Thanks for the description! So they are good in supercharged dryers too. And how much did you pay for it if you can know?
  • #12 7650135
    ~wac
    Help: 17
    Rate: 166
    I paid 1750 zlotys for it in a local household appliances store near my house
The discussion revolves around the comparison between top-loading condenser dryers, specifically the Mastercook SKTD 6710, and traditional front-loading condenser dryers. The user seeks advice on the practicality of a top-loading model for a small living space, particularly for elderly users. Initial responses suggest that if space allows, a front-loading dryer is preferable. However, due to space constraints in the user's kitchen, a top-loading dryer is considered. The user ultimately decides to purchase the Mastercook SKTD 6710 and reports positive results after testing it, noting that it performs comparably to traditional dryers in terms of drying efficiency and time. The drying process for various fabrics was effective, with a significant reduction in drying time compared to previous experiences with other models.
