Choosing a Dryer: Condenser vs. Heat Pump - Bosch WTB86201PL Opinions & Observations
santorynxd 5481 6
  • #1 17363446
    santorynxd
    Rate: 11
    Hello, I plan to buy a dryer in September. I have read a lot of topics and from what dryer users write, I can choose a dryer with or without a heat pump. The dryer will stand in a cold utility room so it can give off heat. The dryer will be used 1-3 times a week. I heard that the aforementioned heat pump is more energy-efficient, but in total, if it breaks down (and most often it fails), the costs are such that energy savings will not cover it.
    I saw this model: Bosch WTB86201PL (plus the sled, because it would stay on the washing machine)
    https://www.ceneo.pl/23196351
    I am asking dryer users for opinions and observations.
    arekb81
    Level 30  
    Help: 132
    Rate: 737
    If it is to be placed in a cold room, then only with the heat pump.
    An "ordinary" dryer will give off a lot of heat, and with it a lot of moisture that will condense on the cold walls, thanks to which you will grow a "beautiful" mushroom.
  • #3 17363628
    santorynxd
    Rate: 11
    What models do you recommend?
    PanAGD
    Help: 65
    Rate: 112
    With a reasonably priced heat pump and with good functions, eg Bosch WTH8520EPL .
  • #5 17366189
    Borutka
    Help: 125
    Rate: 414
    The basis is ventilation. If there is no ventilation grille in the room, it is better to buy with a heat pump if possible.
  • #6 17434699
    santorynxd
    Rate: 11
    I can make a grill, or ventilation in the ceiling, only a porch and so chilled to the max in winter. The little radiator is there, but it doesn't help much. Do you have any other models worth your attention? Maybe someone has :)
  • #7 17665477
    MikroPstryczek
    Rate: 22
    In my bathroom, 17-18 degrees Celsius and mechanical ventilation, which is better condensing or with a heat pump?
✨ The discussion centers around the choice between condenser and heat pump dryers, particularly in the context of using the Bosch WTB86201PL model in a cold utility room. Users emphasize the importance of heat pump dryers for such environments due to their energy efficiency and reduced moisture output, which can prevent condensation issues. Recommendations include the Bosch WTH8520EPL as a viable heat pump option. Ventilation is also highlighted as a critical factor, with suggestions for creating ventilation solutions if necessary.
