How to Clean & Deactivate Leaking Battery (Alkaline & Ordinary) in Digital Devices
zodiak318 45556 3
  • #1 770278
    zodiak318
    Help: 249
    Rate: 306
    I do not know if it works good, but I think so.
    But to the details. My friends sent me a message asking "what to clean a spilled battery in a digit". I advised you to wipe as much as you can with a cloth, but what next? how to deactivate the electrolyte? (I'm not sure if it was alkaline or "ordinary" so I am asking for advice regarding both such and such a possibility.
    Thank you and best regards.
  • #2 770696
    greku69
    Help: 14
    Rate: 16
    someone here on the forum said that you can clean it and wait until it evaporates ...
    Greetings
  • #3 770852
    kondor
    Rate: 22
    A glass of warm water + a few crystals of citric acid at the tip of the knife, or sodium acid sulfite (used in photography), then plenty of warm water to rinse. Then drain the remaining water with tissue paper or a cloth, this may be soaked in spirit. Itself
    washing with alcohol is unreasonable . You will probably ask why I should use spirit, however? And a sweat, because when the spirit is combined with micro droplets of the rest of the water, it will evaporate faster. Good luck
  • #4 770924
    zodiak318
    Help: 249
    Rate: 306
    Thanks for the answer, I will pass it on to the "victims" :) .
