Neutralizing Car Battery Acid Spill: Suitable Alkaline Substances and Safety Measures
skaktus 46904 14
How do I neutralize and clean up car battery acid spilled on the battery tray and nearby plastic parts without damaging myself or the car?
Rinse the spill with plenty of water, then neutralize the remaining acid with a mild alkaline solution such as baking soda mixed with water; ammonia solution was also suggested, but avoid caustic soda or lime because they can cause burns if dosed incorrectly [#8302222][#8302243] Apply the neutralizer thoroughly, not just as a mist, because simply diluting the acid with water is not enough by itself [#8302243][#8302469] One user also reported using active foam diluted 1:1 with water and spraying it on for about 3 minutes, then rinsing very thoroughly, repeating this three times, while being careful with plastics and paint because it is strongly alkaline [#8303853] After neutralizing and washing, clean the corroded metal with a wire brush and sandpaper and repaint it if needed [#8302299] Also check why the battery overflowed, because the battery or charging system may need attention or replacement [#8302322][#8302537]
  • #1 8302210
    skaktus
    Level 37  
    Help: 89
    Rate: 315
    For unknown reasons, the battery in the car spilled on the base on which it stands and rubber-plastic elements around. It wasn't an explosion or anything like that.
    As some of the acid was left in the car, how to remove it? You can already see the erosion of the sheet metal and wrinkled paint. I want to neutralize the acid so that it can be rinsed properly, but now what is the best way to do it? From school knowledge, I know that it must be something alkaline to neutralize the acid, but what not to harm myself and the car?
    Please help.
    Regards
  • #2 8302222
    ociz
    Help: 1379
    Rate: 3486
    Water, lots of water and more water.
  • #3 8302231
    ziempiotr
    Help: 16
    Rate: 83
    acid base water and soap :)
  • #4 8302243
    JARO_17
    Rate: 26
    In addition to rinsing with water, you can neutralize it with an ammonia solution. It has a strong smell, so if you give it in excess, you will have to air it for a long time. I advise against using caustic soda, lime because you can get burns in the event of incompetent dosing, but I recommend baking soda (the kind from the grocery store). Whatever you neutralize it will not do as the predecessors wrote without rinsing, thorough.
    And with the water itself, it's a problem because you only dilute it and then what?
  • #5 8302260
  • #6 8302272
    pipałosia
    Help: 74
    Rate: 179
    Plenty of water.
  • #7 8302299
    skaktus
    Level 37  
    Help: 89
    Rate: 315
    Thanks for your help and tips. I will use baking soda mixed with water a lot + then super thorough rinsing with water. I think that after this treatment a wire brush + sandpaper and finally painting will do its job.
    If you have any other tips, please write, each is important.
  • #8 8302322
    Stary1952
    Level 32  
    Help: 164
    Rate: 242
    Hello .
    Nothing happens without a reason, in your place I would check the battery charging voltage. :?:
    The battery itself should not "boil over"
  • #9 8302347
    marian159
    Stary1952 wrote:
    Hello .
    I support check charging, you probably have too much and the battery is boiling;
    Greetings
  • #10 8302350
    skaktus
    Level 37  
    Help: 89
    Rate: 315
    Stary1952 wrote:
    Hello .
    The cause is unfortunately unknown. The battery has a charge of 14.3 volts during operation. Probably the fault lies with the battery, an unknown company and no one knows where.
  • #11 8302469
    JARO_17
    Rate: 26
    Of course, a solution of soda water. And as for thinning, maybe it's right that it can be almost completely rinsed, but still, I recommend neutralizing it with something mild + thorough rinsing first.
    Of course you should do it ASAP. And not some kind of sprayer, just pour it normally. If you have boiled over a large part of the electrolyte, use more baking soda.
    If I were you, I'd watch out for the battery now. It may be advisable to replace it with another one.
  • #12 8302537
    Stary1952
    Level 32  
    Help: 164
    Rate: 242
    With such a value of 14.3 V, which is correct, the reason is rather obvious - the battery needs to be replaced. :cry:
  • #13 8303853
    binges
    I went through this recently too...
    to neutralize the effect of the acid, I made a solution of active foam with water in a ratio of 1:1 + flower sprayer, from which a thick foam was made, it is a strong alkaline solution, so you have to be careful with plastics and varnish on the outside of the body,
    I sprayed for about 3 minutes, then rinsed thoroughly with water and then repeated it 3 times (foam for 3 minutes + washing with water)
  • #14 8304456
    skaktus
    Level 37  
    Help: 89
    Rate: 315
    The battery has already been put aside, interestingly, the car on it normally "could give advice" so unfortunately I do not know which side is the cause.
  • #15 8305504
    Stary1952
    Level 32  
    Help: 164
    Rate: 242
    One cell in the battery could be shorted, the summer period, it's warm, the starter "rotated" with 10V without any problems. The consequence of this is automatically overcharging the others combined with electrolyte leakage - this is my hypothesis, perhaps
    I'm wrong. :D
The discussion revolves around neutralizing a car battery acid spill and the appropriate safety measures to take. Users recommend using baking soda mixed with water as a mild alkaline solution to neutralize the acid, followed by thorough rinsing with water. Some suggest using ammonia solution or active foam, but caution against caustic substances like caustic soda or lime due to potential burns. The importance of checking the battery's charging voltage is also highlighted, as overcharging may lead to electrolyte leakage. Users emphasize the need for immediate action to prevent further damage to the vehicle's metal and paint.
