AAA battery electrolyte leak in voice recorder—cleaning and preventing further damage
pyged 16012 7
  • #1 4451891
    pyged
    Dear,
    I left AAA batteries in the voice recorder and, disaster - as in the subject.
    Perhaps the leak reached the components, e.g. I am not sure if the "play" button works properly - for now I have dismantled everything and wiped it dry. Traces only on the plate, from the battery side and corrosion on the internal structure and on the contacts at the lid closing the battery compartment.
    Is the detected failure tantamount to gradual destruction of the voice recorder?
    Is it possible to somehow preserve the components to better clean them?
    That's all for now. I'm going to the newsstand for new batteries and when I turn it, I'll know something else.
    Please advise.
    Greeting,
    Ged
  • #2 4452371
    bogdan-pe
    Help: 37
    Rate: 55
    Corrosion will continue, even after wiping. What to do, I already wrote. Use "search". Regards
  • #3 4452796
    pyged
    Hmm, thanks, but trying to find a clue:
    have not yielded any result :cry:
    Kiss,
    g
    Added after 46 [minutes]:
    Does anyone know how to efficiently/effectively find the cryptic post written by: bogdan-pe :?:
  • #4 4454584
    bslaw
    Help: 16
    Rate: 67
    Once, in a similar situation, intensive washing helped me - often changed ear buds and distilled water.
  • #6 4464281
    bogdan-pe
    Help: 37
    Rate: 55
    Wash well with rubbing the spilled places with warm soapy water. It is alkaline and neutralizes the acidic electrolyte in the battery. The longer you wash and rinse, the better. It is good to soak the entire plate in soapy warm water for a few hours (if the construction allows it). Finally, dry it well, even for a few days. Solder the flooded soldering points with tin and rosin (because they could get dirty by pickling "cold" solder. Finally, brush the entire board with silicone oil. This will protect against tin oxidation (you can spray with hairspray). And in the future, do not use carbon cells, only alkaline ones ( they will not spill out.) Regards.
  • #7 4468246
    pyged
    Thank you very much for all the advice - I can start working.
    cordiality,
    Ged
  • #8 4473105
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4258
    I once repaired a tape recorder for a friend, in which the batteries leaked - so much rust in places that the mechanism was not visible.
    I removed the rust mechanically, maybe with petroleum jelly, then whatever was suitable, I covered it with hot paraffin (by heating
    transformer soldering iron so that the water evaporates) then I scraped off the paraffin with rust, and so several times - the whole job was
    a few days, because there was a short circuit in the motor), finally it was clean and the tape recorder was working, with some slippage, because the belt got dirty.
The discussion revolves around the issue of electrolyte leakage from AAA batteries in a voice recorder, leading to corrosion on internal components. Users suggest various cleaning methods, including washing with warm soapy water to neutralize the acidic electrolyte, soaking the circuit board, and using silicone oil for protection against oxidation. Mechanical removal of rust and applying paraffin for further cleaning are also mentioned. The importance of using alkaline batteries in the future to prevent leakage is emphasized.
