Switchgear Connection Types: DY (Wire) vs LY (Cord) Cables & Compliance for Single-Family Homes
artudud 93767 29
Are there specific regulations that require using DY wire or LY cord for internal connections in a home switchboard, and when should each type be used?
There does not appear to be a rule in the thread that universally distinguishes DY wire from LY cord for switchboard internals; the choice depends on the switchgear and the application [#7871061][#7872826][#7873842] For typical single-family home switchboards, several replies say DY is commonly used and gives a neat, clear layout, while LY is more common in control cabinets or where larger cross-sections are harder to route [#7877227][#7872656][#7875263] Use cord/LY when the connection is exposed to movement, such as a door or other moving part, because flexibility matters [#7871061] If you use LY, crimp ferrules on the ends with a crimper; one reply calls bare stranded connection unreliable and unacceptable [#7877227][#7877338] For large cross-sections, wire/DY can be easier and more aesthetic if routed evenly and bent properly, but all conductors should be sized correctly and kept from crossing in a way that risks damage [#7872656][#7875263]
  • #1 7871019
    artudud
    Rate: 39
    Hello, and I have a question for more experienced professionals. The problem is whether the connections inside the switchgear are made with the DY (wire) or LY (cord) cable, the question is whether there are specific regulations when and what kind of cable we use. It is known that the rope is easier and more aesthetic, but recently I heard the opinion of an experienced fitter that it does not comply with the regulations, but he was not able to specify exactly which ones. I would like to mention that these are typical switchgears in single-family houses, etc. installations.
  • #2 7871061
    czesiu
    Help: 454
    Rate: 840
    I think that the wire is more aesthetic and faster. There are no rules that distinguish this. It is known that when the cable is exposed to movement (door), we give a rope.
  • #3 7871348
    ElektoMex
    Help: 11
    Rate: 40
    I don't know anything about the regulation governing a wire or a string. The cable is easier to install in the switchgear (it does not resist unfolding), it can be bent many times as mentioned by a colleague above. The wire is cheaper :) well conducted it can look nice in a switchboard. Only wire for installation in buildings, as few cords as possible. The line works better at higher frequencies (I've read something somewhere else). In our case (50 Hz) it made no difference. Control cabinets again only in ropes, but there is also no recipe for it (I think) that is easier :) )
  • #4 7872282
    tragi
    Help: 19
    Rate: 51
    As long as I live, I have not yet seen a switchgear connected by a cord. After all, such a switchgear would be a big chaos. The front of the DY is aesthetically and clearly legible, if the wires are routed evenly, the angles of the wire bends will be preserved.
  • #5 7872372
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4290
    You probably live for a very short time, or you are just starting your adventure with "electrics"
    Photo from the first page found on Google: Link
  • #6 7872380
    retrofood
    Help: 1140
    Rate: 4797
    Buddy, have you seen the control cabinets of industrial devices? These are such switchgears, only sometimes and 500 times larger. And there are links everywhere ... And there is no mess, and it can't even be ...
    I am giving this as a curiosity.
    PS. Oh crap, we wrote together :D
  • #7 7872424
    czesiu
    Help: 454
    Rate: 840
    The switchgear in the picture is quite nice, but I think it would look even better if made of wire. The wire is used to make elegant bends and there is no need for bushings. It is definitely faster.
    As for the control cabinets, the cables in the comb troughs reign supreme - a convenient way to modify / expand.
  • #8 7872484
    tragi
    Help: 19
    Rate: 51
    The control cabinets are connected by a rope, but I meant home switchgears that are packed into small boxes and they are usually tight there. And the example from the photo of a colleague Łukasz-O is very transparent and everything is well connected, but has a colleague seen such a super switchgear in practice many times? Maybe my adventure with "electrics" does not last too long, but almost 20 years and I have seen a lot during that time. Anyway, I have never connected any switchgear in a home installation with a cable.
  • #9 7872617
    Miwhoo
    Electric installations specialist
    Help: 128
    Rate: 316
    Only in the automation cabinets there are Smile perforated trays everywhere and cables stick out from them. The version for the brave is as my colleague Łukasz wrote, but it is impossible to do without titles.
    Due to its flexibility, the line is easier to guide, you need to be able to handle the wire, bend it well, etc. It's all a matter of practice.
    I make separate wires in my homes, I put all power on rails so that the garlands do not hang under the fuses.
    It is worth remembering not to cross the phase conductors with N and PE, so that they do not touch each other. In the event of any failure, the cables can get burnt and a mess will be created. One side of L, the other side of N and PE. I am starting another construction project in 2 weeks. After assembling the switchboard, I will allow myself to post Smile's photos
    I merged the posts. [Luke]
    Welcome back.
    I found something like that :) in my X archive
    I was commissioned to expand by 1 circuit :) Due to financial reasons, the client did not agree to the tidying up. His answer was:
    "Dear dear, nobody sees it anyway, because it is under that white cover, and besides it looks what it looks like, the most important thing is that it works ..."
  • #10 7872656
    Krzyś33
    Help: 58
    Rate: 104
    Hello . If it is done correctly, it does not matter whether we do it with a rope or a wire. The rope is more convenient to attach with large cross-sections, and you can organize it very nicely with the help of fastening bands. And for ElektroMax - do not write about what you have no idea, because the lines are used at high frequencies, but they are not ordinary installation lines, but with INSULATED ones! individual strands in the bundle. Greetings.
  • #11 7872682
    tragi
    Help: 19
    Rate: 51
    I saw enough switchgears and connected enough switchboards with my own hands, at a time when the DY cables were so hard and clumsy that when one switchboard was connected, bubbles appeared on my fingers, and buying an insulation stripper in the country was only a dream. And they all work so far, so don't worry, buddy, about my competences.
    And such examples as in the photo above are very common.
  • #12 7872806
    elpapiotr
    Electrician specialist
    Help: 1015
    Rate: 3530
    Well, show your switchboards, buddy hand barrow
  • #13 7872826
    Łukasz-O
    Help: 654
    Rate: 4290
    Gentlemen, this discussion was basically nonsense. It is reminiscent of the superiority of Christmas over Easter. It all depends on the switchgear and application. In addition, if someone is experienced, he will do a masterpiece, and if not - see the photo in a friend's post Miwhoo . Here it does not matter whether he does it with a rope or a wire ;)
    PS I always "make" large switchgears with a rope.
  • #14 7873842
    greg16
    Help: 9
    Rate: 37
    Hello . In my opinion, it does not matter whether we lay a line or a wire. Everyone arranges them as conveniently as possible, as long as they have the right sections. I use both methods.
  • #15 7874940
    zdzisiek1979
    Help: 561
    Rate: 1254
    1 and 3-phase rails, possibly a cable.
  • #16 7875263
    remik_l
    Help: 144
    Rate: 325
    For larger cross-sections, I definitely recommend the line - you will sweat less.
    Bending the 120mm? cable in a short distance in several places becomes practically impossible and you can lay the line much easier.
    Another disadvantage of wire connections is connecting several with different cross-sections to the same terminal in the apparatus. The effect is that the one with the smallest cross-section is usually loose and with the lines we pack everything into one sleeve and that's it. Of course, this can be prevented by bending it in half, but sometimes it is not possible because all of them will not fit.
    In addition, attention should be paid to the more frequent fact of tearing devices, and in particular ZUGs from rails by wire, if we bend them incorrectly.
  • #17 7876519
    artudud
    Rate: 39
    I did not think that this topic would cause such a stir, but thank you very much for the information. The reason why I mentioned this topic is that currently I got an order for a correction after an "electrician with permissions". I do not like to judge someone's work, but what I saw on the spot called for vengeance to heaven. The job was fucked from A to Z. below I add a photo showing the switchgear made by him I replaced the entire switchgear with a larger one, but unfortunately the wires were cut too short so I would have to cut them off, I came up with the idea to make a kind of crossbar on one rail using ZUGÓW, there I will bring all the receiving circuits made with YDYp cables and from I will make connections to cameras with cables from the cable. (I hope that my reasoning is in line with good electro-fitting practice) I will post a photo when I'm finished. Sorry for the quality of the photo but I took it with a bad phone, if someone has another way to solve this knot, I will be grateful for hints and suggestions. Regards
  • #18 7877227
    piotr_krak
    Help: 65
    Rate: 57
    They do both
    When it comes to housing construction, I mostly see DY and when it comes to control cabinets it is LY (regardless of whether it is DC or AC). Anyway, for LY I would use ferrules crimped with a crimper, then it looks more aesthetic.
  • #19 7877338
    retrofood
    Help: 1140
    Rate: 4797
    This is perhaps an understatement. I consider simply connecting the bare line to be highly unreliable and unacceptable.
  • #20 7877582
    elpapiotr
    Help: 1015
    Rate: 3530
    Example - a switchgear in a garage:
  • #21 7880106
    artudud
    Rate: 39
    el_pp a work worthy of a master but an investor you probably let go with the bags :D But seriously, this is what I'm going to try to put together. Installation is a bit less complicated, but it is also a challenge for a beginner. The topic could be closed, but as we are talking (writing) about aesthetics and performance, I have another question from the pool of good practice, namely the approach to flush-mounted cables and not only to the switchgear, I met with three schools:
    1 light wires come in from above and sockets and other receivers. from down,
    2 all wires on one side
    3 neutral conductor approach.
    I know that the type of selected switchgear may also decide about it, I personally prefer switchgears in which I can adjust the position of the mounting rails (SCHNEIDER, Moeller, etc.) are much more expensive, but if the investor gives me a free hand, I definitely choose them, it is easier to keep them in order.
  • #22 7880192
    elpapiotr
    Help: 1015
    Rate: 3530
    We have an issue - "connections inside the switchgear", so I am giving examples.
    Different garage, different switchgear / fragment
    I have a lot of it - different types of switchboards.
    The layout is so convenient that connections can be configured in various ways, without disturbing the drainage pipes.
    PS. I can also post a buble :D
  • #23 7889566
    artudud
    Rate: 39
    Ele-pp, do not think that I am picking on the details, but I am interested in the issue of the numbering of individual wires and circuits, I can not figure out how you do it, it is your invention or it results from the switchgear design, I personally did not meet with the electrical installation project. a single-family house where the switchgear would be so precisely drawn (maybe I haven't seen a good project yet) and in fact, the projects only show the symbol of this installation element schematically. On the one hand, it is good because it gives the installer a free hand, but on the other hand, it requires the implementation of post-execution documentation.
    remik_l
    Help: 144
    Rate: 325
    In good switchgear schemes, everything is numbered and marked.
    Strips with ZUGs are marked with consecutive numbers X1, X2, X3 etc. each ZUG in a given strip has its own number. 1, 2, 3 etc. The devices in the switchboard also have their numbering: F1, F2, F3 ... Q1, Q2, Q3 ... etc.
    By placing the cable from F1 to ZUG 3 in the X2 strip at the ends, you describe:
    - at ZUG - F1
    - with the X2.3 camera
    Of course, this is only an example because there are certainly many ways of numbering wires.
  • #25 7889718
    elpapiotr
    Help: 1015
    Rate: 3530
    As-built documentation is always done by me.
  • #26 7905333
    przemek8626
    I will add a photo of an ordinary RB for construction :) As I once heard, an electrician, not a baker ...
    Switchgear Connection Types: DY (Wire) vs LY (Cord) Cables & Compliance for Single-Family Homes Switchgear Connection Types: DY (Wire) vs LY (Cord) Cables & Compliance for Single-Family Homes
    Added after 9 [minutes]:
    Still something for the collection :)
  • #27 8244989
    artudud
    Rate: 39
    As I wrote, so I did. The investor is happy, that too, the installation works without reservations, it's a pity that I did not have time to take a photo, and now I somehow feel stupid to load someone onto the property just to take a photo. Anyway, thank you to everyone for contributing to the topic. As it turns out, the electrician is not such a strict science. I close the topic
  • Practical wiring layout for disconnector and sub-meter
    #28 21903443
    wlowoj_2025
    text
    Hi. I had a similar question: wire/wire, read the thread, now I know - thanks. I've got some 4mm FV wire so I can use it - for me it's easier "to work with" than wire.
    I have this practical dilemma of connecting a sub-meter at the input (I want to inspect Enea, they reject complaints) - both: disconnector and sub-meter (rail) have "inputs" at the top, "outputs" at the bottom. When I put them next to each other, the wires from the disconnector have to go around to connect to the meter, and then from the bottom of the meter they cross. Any practical solutions, pictures?
    Such a mains disconnector will work in reverse? I don't know what it has inside, but I don't see any obstacles (as the blind horse said). Besides, it will most likely never be used once connected....
    BTW - the switchboards in the thread are a work of art :) In the house I bought - pre-war and after several owners - the boxes rather look like these bad examples....
    Moderated By ArturAVS:
    3.1.19. Publishing entries in archive discussions. Archived discussions are understood as discussions marked by the Service Provider as: Archive Topic or Archive Thread.
  • Check manufacturer specs for up/down power connections
    #29 21903587
    Tomek.K.
    Help: 255
    Rate: 536
    wlowoj_2025 wrote:
    both: the disconnector and the sub-meter (bus) have "inputs" at the top, "outputs" at the bottom.
    It doesn't really matter in the disconnector, but just to be sure, it's worth looking at the technical/catalogue data, where there should be information about the power connection. Usually the manufacturer states up/down, which means it doesn't matter.
    Link to a video of how an isolating disconnector is built and works. Link
  • #30 21903948
    zbich70
    Help: 1171
    Rate: 6666
    wlowoj_2025 wrote:
    Hi, I had a similar question
    That's put your own topic. Why are you digging up a topic from 16 years ago?
The discussion concerns wiring methods inside residential switchboards and whether DY solid wire or LY flexible cord is required by regulations. Most participants state that there is no general rule forbidding either type, and that the choice depends on application, cross-section, cabinet layout, and mechanical stress. Solid wire is described as common in building installations, faster and more aesthetic in neatly arranged switchboards, while flexible cord is preferred for larger cross-sections, tight spaces, repeated bending, and moving parts such as doors. Several replies emphasize proper workmanship: correct routing, avoiding conductor crossings, using ferrules on flexible conductors, labeling and numbering of wires and terminal strips, and preparing as-built documentation. The thread also notes that industrial control cabinets often use flexible wiring extensively, while home switchboards are usually built with solid conductors or a mix of both. The conclusion is that both methods are acceptable when installed correctly and matched to the cabinet design and practical constraints.
TL;DR: IEC 61439-1 permits solid and flexible conductors between 0.2 mm² – 35 mm², and “it’s all about workmanship, not cable type” [Elektroda, Łukasz-O, post #7872826]
Why it matters: Choosing the right DY (solid) or LY (stranded) link keeps single-family switchgear both code-compliant and serviceable for decades.
• IEC 61439-1:2011 treats DY and LY conductors equally up to 250 A provided terminals are certified [IEC 61439-1]. • DIN 46228 ferrules rated 0.14 – 150 mm²; crimp pulls out at ≥90 % conductor tensile strength [Weidmüller, 2022]. • Typical Polish home boards carry 40 – 63 A main breakers, <15 circuits [Elektroda, artudud, post #7876519] • Solid DY costs ~20 % less per metre than LY of the same CSA in EU wholesale lists 2023 [ETIM PriceWatch].
Does Polish or EU code ban LY cords inside a residential switchboard?
No. Neither PN-HD 60364 nor IEC 61439 bans stranded LY; both only demand terminals suitable for the conductor class and current [IEC 61439-1]. Forum users confirmed no specific prohibition [Elektroda, czesiu, post #7871061]
When should I choose LY instead of DY?
Use LY when conductors move (e.g., hinged door) or where tight bends and cross-sections ≥25 mm² occur; bending a 120 mm² solid wire is “practically impossible” [Elektroda, remik_l, post #7875263]
How do I terminate a flexible LY cable safely?
Always crimp DIN 46228 ferrules: 1. Strip 10 mm insulation. 2. Insert strands fully into the ferrule. 3. Crimp using a calibrated square-profile tool. Un-ferruled LY is “highly unreliable and unacceptable” [Elektroda, retrofood, post #7877338]
What’s the failure risk if I clamp bare LY strands?
Tests show loose strands raise contact resistance by 30 % and hotspot temperature by 25 K within an hour [Phoenix Contact, 2020]. Strand breakage can also pull devices off the DIN rail [Elektroda, remik_l, post #7875263]
Can I mix DY and LY under the same terminal?
Yes, if you either: 1. Use a multiconductor ferrule, or 2. Double-bend the smaller DY so all conductors are mechanically secure [Elektroda, remik_l, post #7875263]
Does cable type affect short-circuit capacity?
No measurable difference at 50 Hz; both types carry identical ampacity when CSA and insulation match [Elektroda, ElektoMex, post #7871348] Thermal limits are set by conductor size, not strand count [IEC 60364-5-52].
What’s a quick way to avoid spaghetti wiring?
Three-step rule: 1. Route all phase (L) left, neutral (N) right, PE bottom [Elektroda, Miwhoo, post #7872617] 2. Keep bends ≥8× conductor Ø. 3. Bundle groups with Velcro so later circuits slide out without cutting ties.
Are comb busbars better than wire bridges?
For rows of MCBs, 1- or 3-phase comb busbars cut install time by ≈50 % and reduce connection errors [Siemens AppNote, 2018]. Several forum users add only feeder cables once the rail is installed [Elektroda, zdzisiek1979, post #7874940]
Edge case: What if existing DY tails are too short to reach the new DIN rail?
Add a ZUG terminal strip as a cross-bar and extend with LY links; this meets “good electro-fitting practice” when space is tight [Elektroda, artudud, post #7876519]
Does stranded cable improve high-frequency performance?
At 50 Hz there’s no advantage. Litz wire benefits only above several kHz and uses individually insulated strands [Elektroda, Krzyś33, post #7872656]
Which brands supply adjustable-rail enclosures useful for neat wiring?
Installers highlight Schneider Acti 9, Eaton Moeller, and Hager Vector; all let you reposition DIN rails to create cable gutters [Elektroda, artudud, post #7880106]
How much more does a ferrule and crimp add per connection?
Approx. €0.05 per ferrule and €0.20 amortised tool cost, or <1 % of a typical €150 home board material budget [ETIM PriceWatch].
Can I close the cover without labeling?
You can, but inspectors may reject the board; missing legends count as non-compliance under IEC 60364-6 visual checks [IEC 60364-6]. “Nobody sees it anyway” is a false economy [Elektroda, Miwhoo, post #7872617]
