Factory Reset Nbox Recorder: Disk Formatting for TURBO 500GB Version - Alternative Methods
mzmaniek 79461 5
  • #1 7967844
    mzmaniek
    Help: 7
    Rate: 13
    I have a question, how to reset with nbox disk formatting record from platform n, I mean TURBO 500GB version .. ??
    Option via remote control and setup does not work:
    - setup and press 0359157 from the remote control and select RESET ...
    Does anyone know any other solution ... ??? :cry:
  • #2 7968196
    matzg
    Help: 308
    Rate: 358
    Hello, you tried to "press the buttons on the front panel one by one while holding down the previous ones
    [EPG] + [REC] + [up arrow] hold for 15s "
    Greetings
  • #3 7969023
    netTv
    Level 32  
    Help: 193
    Rate: 579
    The correction is reset by simultaneously pressing and holding the buttons: EPG, RES and the arrow right All buttons should be held down for quite a long time, even up to 20 seconds, until the following message appears on the decoder display: TEST. Alternatively, try several times in case of unsuccessful attempts. After a factory reset, the decoder will reinstall all settings. M. in. it will automatically turn on in SD1 resolution.
  • #4 7970366
    mzmaniek
    Help: 7
    Rate: 13
    But it will not format the disk ... and that's what I mean ... what you write is a soft reset and the decoder behaves in the same way when we unplug it ...
  • #5 8229709
    gebe14
    Rate: 23
    yeah ... I'm also looking for help ... how to totally restart nbox
  • #6 8229960
    netTv
    Level 32  
    Help: 193
    Rate: 579
    An alternative method is to use the hidden menu, which opens after selecting the key combination on the remote control: "SETUP 0 3 5 9 1 5 7". Then confirm the selection of the "FACTORY SETTINGS" option.
    Keys on the remote control should be pressed slowly and repeated as long as it does not work the first time.
    ATTENTION: in case of nbox recorder the procedure deletes the contents of the disk!
    Doesn't run on turbo.
