VW T5 Transporter 2008: No Brake Lights, Fuse Location & Diagram for Upper Stop Lamp Issue
Kamio91 47040 8
  • #1 17500459
    Kamio91
    Probably I made a short circuit today on the upper stop lamp (lamp) in the VW T5 bus. My brake lights stopped working. I checked the bulbs are fine. Would someone be so kind as to suggest to me where to find this particular brake light fuse? Bus 2008. I checked the fuses on the middle tunnel in the cabin and they are all ok. Can I find this particular one in the engine compartment? Maybe someone has a diagram with a description of fuses in this particular model? Thank you in advance for your help :)
  • #2 17500529
    piotrekwoj1
    Help: 947
    Rate: 3433
    At the time you wrote this post, you would have checked all of them twice. The tube in your hand and to work and you do not wait for administration on the tray.
  • #3 17500725
    andrzej20001
    Help: 1578
    Rate: 6669
    The fuse 9
  • #4 17501388
    Kamio91
    Nice friend, if I had enough time yesterday evening, I would check it, I did as much as I had time. Unfortunately, I was not able to check the next fuses yesterday, today I will continue to check and at the same time I will have more knowledge. I will look under the hood and therefore I asked what number this fuse could be marked with and where it is located exactly. I don't see anything wrong with that when I wrote a post that I wanted to save my time, especially since I would rather have my car done after work for today.
    andrzej20001 wrote:
    The fuse 9
    Where can I find it, around the battery, yes?
  • #5 17999972
    damys
    Rate: 36
    I have the same problem
    Stop lights are not working except for the additional ones in the tailgate.
    fuse checked ok! sensor on the pedal replaced and checked bulbs ok with a meter measured no voltage in both plugs.
    where to look further or where do the bundles come together?
  • #6 20153670
    rochmickiewicz
    For me it was the one in the circle.
    Additional information, the glow plug indicator was on.
    Greetings! VW T5 Transporter 2008: No Brake Lights, Fuse Location & Diagram for Upper Stop Lamp Issue
  • #7 21248681
    otekguzy
    Level 4  
    What is the issue good morning. Also my alloys are not working in my T5 and the spark plug paw light is on.
    What does this have to do with?
  • #8 21248737
    andrzej20001
    Help: 1578
    Rate: 6669
    The absence of a stop light is indicated by a candle lamp. Sensor. There are 4 pins. Two from the lights two to the ecu. Change the fuse or the sensor
  • #9 21248761
    otekguzy
    Level 4  
    Thank you very much
The discussion revolves around a 2008 VW T5 Transporter experiencing a failure of the upper stop lamp, resulting in non-functional brake lights. The user confirmed that the bulbs are operational and sought assistance in locating the specific fuse responsible for the upper stop lamp. Responses indicated that the relevant fuse is likely fuse number 9, with suggestions to check under the hood near the battery for its location. Additional users shared similar issues, including problems with the sensor on the brake pedal and the glow plug indicator being on, indicating potential electrical faults. Recommendations included checking the sensor and fuses, as well as examining wiring bundles for further troubleshooting.
